Failed fuel filter - Diesel Forum - TheDieselStop.com
Old 08-04-2009, 08:26 PM   #1 (permalink)
DieselVirgin34's Avatar
Failed fuel filter
So here it is. After two months and 500 miles back and forth to the dealership a failed primary fuel filter was the reason for all of my problems. Service manager said that the primary filter looked like a smashed pop can. There was not a single shred of filter left in the cage. Consequently, the secondary filter got so plugged up that after the engine got warm and the filter swelled it would shut the fuel delivery off. Especially when more fuel was being asked for. A fuel pressure diagnostic test was finally run and after 20 minutes the fuel pressure dropped 20 psi. ***!! It sure would have been nice if that would have been one of the first things that was checked. I am fast becoming educated in the ways these dealerships work. They are not allowed to make educated guesses to try and diagnose problems. My guys were on the verge of putting in a new manifold, turbo, injection system, and more. You can imagine the relief on their part when it was a couple of filters and a flush job that makes all ok. I'm stoked to have my rig back and running strong, but the hassle was almost too much.
The service manager said that he has never heard of a failed fuel filter. I trust the guy, but I am still skeptical that the filters were even changed. Warrenty work says that they were, but the jury is still out.
DieselVirgin34
2006 PS CC 6.0
All stock
DieselVirgin34 is offline
Old 08-04-2009, 09:03 PM   #2 (permalink)
A failed filter is very common - especially if the wrong filters (aftermarket) are installed. Your dealership has heard of it.
Ford has their own training material on it.
http://www.fordtechservice.dealercon...aintenance.pdf
http://turbodieselforums.com/diesel_3.pdf
http://turbodieselforums.com/diesel_6.pdf
Mark
bismic is offline
Old 08-04-2009, 09:52 PM   #3 (permalink)
The photos of the fuel filter just sold me on the Air Dog, been considering it for awhlie, but now its a done deal. Thanks
PSD2004 is offline
Old 08-04-2009, 11:03 PM   #4 (permalink)
I hear ya! I do think everyone needs a fuel pressure gauge!!
Mark
bismic is offline
Old 08-05-2009, 07:23 AM   #5 (permalink)
FTG-05's Avatar
My Photos: (25)
_Ford Documents\Presentation_Fuel system maintenance and Air Management and Injector Spool Valve Sticking Reflash.pdf
_Ford Documents\Presentation_Fuel Delivery and HPO System Diagnostics.pdf
You're last two links don't work for me.
the first one was good and proves that Ford should have known of the fuel filter issues.
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
Old 08-05-2009, 07:30 AM   #6 (permalink)
bmiller's Avatar
So getting an airdog 100 gives a lift pump and more filtering. How about fuel pressure? I heard a guy running an extra hfcm to get his fuel pressure up cheaper I guess!
Does the airdog 2 incorporate fuel pressure? What is the difference between airdog100, airdog 2 and Fass systems?
2006 CC 6"procomp, 35's on 20's, Zoodad mod, harpoon mod, Silverline 4" Turboback exhaust w/stock cat. in place, Hi-idle mod, Coolant Filter, Edge Insight gauges, and SCT Tunes from ID.
bmiller is offline
Old 08-05-2009, 07:44 AM   #7 (permalink)
Links have been repaired!
Mark
bismic is offline
Old 08-05-2009, 08:19 AM   #8 (permalink)
I put a holly Black pump in line between the tank and the frame mounted pump. Put it on a switch but run it all the time, it keeps my pressure up there and was much cheaper then an airdog.
85 F-350 single cab 4x4 6.9
99 F-350 4 door dually 4x4 7.3
04 F-250 4 door single rear wheel 4x4 6.0
06 F-350 4 door dually 4x4 6.0
adamschuh is offline
Old 08-05-2009, 09:37 AM   #9 (permalink)
69cj's Avatar
If you have a defective filter all the extra pressure will just jam more filter media into the system faster. Side point here, Filters should have been the 1st item checked with a performance problem. I'd be real leary about this dealer. Point #2, you may have damaged some injectors, Only time will tell.
69cj is offline
Old 08-05-2009, 09:59 AM   #10 (permalink)
Originally Posted by 69cj View Post
If you have a defective filter all the extra pressure will just jam more filter media into the system faster. Side point here, Filters should have been the 1st item checked with a performance problem. I'd be real leary about this dealer. Point #2, you may have Only time will tell.
YEA IF HE RAN IT LONG WITH FUEL PSI THAT LOW HE WILL BE REPLACING SOME INJECTORS BEFORE LONG.
CHANGING THE FILTERS WITH (MOTOR CRAFT) ON A REGULAR BASIS SEEMS EXPENESIVE BUT WHEN YOU START CHANGING INJECTORS FROM FUEL STARVATION AND DIRTY OIL THOSE FILTERS DIDNT COST THAT MUCH PAY A LITTLE NOW OR A LOT LATTER
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 212,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 85,000 on the clock
JOHN 3:16
timbo2 is offline
Old 08-06-2009, 01:05 PM   #11 (permalink)
FTG-05's Avatar
My Photos: (25)
Thanks, that's good stuff!
Writeup on adding a pre-pump fuel filter to the standard-issue 6.0 PSD:
http://www.rocketcityrockcrawlers.co...2008-02-25.pdf
FTG-05 is offline
