FICM location - Diesel Forum - TheDieselStop.com
Old 01-15-2010, 06:51 AM   #1 (permalink)
FICM location
Where can I find the FMIC? I am having some cold start problems and would like to check it.
'06 F250 sd 6.0 PSD
Procomp 2.5" leveling kit
Nitto Terra Grappler 285/70/18
Bootguy is offline
Old 01-15-2010, 07:06 AM   #2 (permalink)
I believe the FICM is mounted on top of the valve cover next to the turbo under the degas bottle... but im not 100pct sure. Anyone back me up on this?
1985 6.9L F350 4X4 extended cab dually
2005 6.0L F350 4X4 crew cab dually flatbed
gaughan30 is offline
Old 01-15-2010, 09:45 AM   #3 (permalink)
alexb's Avatar
Yes. On top of the left side valve cover.
Proud to be a member of Ford Doctors Diesel Technician Society
alexb is offline
Old 01-15-2010, 12:31 PM   #4 (permalink)
on the drivers side valve cover/rear
Ford Senior Master Diesel Tech
floden is offline
Old 01-16-2010, 06:26 AM   #5 (permalink)
does any one have any clues what to look for?
'06 F250 sd 6.0 PSD
Bootguy is offline
Old 01-16-2010, 07:36 AM   #6 (permalink)
FMTRVT's Avatar
My Photos: (16)
This isn't going in a good direction.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
Old 01-16-2010, 08:44 AM   #7 (permalink)
Pics:
Page 10: Component Locations
Page 13: Component Locations
Remember - left side of engine is the drivers side.
Mark
bismic is offline
Old 01-16-2010, 11:46 AM   #8 (permalink)
A good diesel mechanic.
Fomoco365 is offline
Old 01-16-2010, 02:14 PM   #9 (permalink)
teamroper60's Avatar
Honestly, and not be demeaning but if you can't find your FICM or don't know how to check it, you probably do not need to be trying. I recommend you take it to a competent tech and let him do the checking. Otherwise, you are likely to either kill the FICM or yourself (via electrocution).
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
