FICM repair - Diesel Forum - TheDieselStop.com
post #1 of 23 (permalink) Old 04-13-2012, 03:12 PM Thread Starter
Thumbs up FICM repair
It's probably been said a dozen or more times before on this site, but I've got to say a big thanks to Ed at FICMrepair.com. Really fast turn around time, and he loaded the PHP Atlas 40 program on my FICM. Highly recommended.
cygnus is offline
post #2 of 23 (permalink) Old 04-14-2012, 11:13 AM
OT
OT's Avatar
C..what is the "PHP Atlas 40 Program"? TIA
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #3 of 23 (permalink) Old 04-14-2012, 01:24 PM Thread Starter
You'd have to go to the PHP website to get the specifics, but for my truck I noticed a quicker throttle response and maybe a touch more power. I haven't had a chance to put too many miles on the truck yet, but the feel of the truck is definitely different.
cygnus is offline
post #4 of 23 (permalink) Old 04-14-2012, 02:26 PM
PowerHungryPerformance FICM tune.
I just installed it - has good responsiveness, not sure on the fuel economy yet.
Mark
bismic is offline
post #5 of 23 (permalink) Old 04-14-2012, 09:20 PM
buster12's Avatar
Ditto. No more cold start warm up issues. Rockets out of the driveway now. Thanks Ed
buster12 is offline
post #6 of 23 (permalink) Old 04-18-2012, 11:28 AM
Although I have not yet formally tested my FICM with volt meter, my engine shows all the obvious symptoms of a bad FICM.
I've previously discussed this on here & it's been suggested that I send it out to a pro for repair.
That said, I'm an Electrical Engineer by trade, I solder frequently and am very proficient with a reasonable amount of soldering tools available at my disposal. I was really planning on testing it, verifying that it was indeed a bad FICM and repairing it myself, however these tunes sound interesting.
One thing I hate is the spool up time, does this ATLAS 40 really make a huge difference?
I rarely pull anything over 1 ton with my truck, typically it's only what I can fit on my small 5X8 utility trailer, occasionally I'll bum a trailer and haul some wood or what ever up to my cabin in Northern PA, however I'm not coming close to using the full towing ability of my truck.
Is it worth sending it out and having Ed replace components and tune it?
I don't plan on buying a tuner for my truck, it's a grocery getter and I'm not about to drop mega bucks into this (and I don't want to blow it up with a crazy tune), but if I can get a bit more power and make it more fun to drive by sending out the FICM & not sacrifice reliability, I'd consider it.
For the record, it's studded & EGR deleted, those are the main things done to keep it from self destructing.
2004 F250 Lariat
ARP Studs
Motorcraft Gasket
EGR Delete
Bone stock otherwise...
DustyRoads is offline
post #7 of 23 (permalink) Old 04-18-2012, 09:05 PM Thread Starter
There is a difference in my truck, with regards to spool up on the turbo. It does feel a little more lively. Check out Ed's site for specifics on the FICM repair, I opted for the 2 year warranty repair and the tune. I feel it's well worth the $475 spent, considering what Ford wants for a FICM.
cygnus is offline
post #8 of 23 (permalink) Old 04-18-2012, 10:32 PM
100% agree! The extra $150 for the tune is worth it.
Mark
bismic is offline
post #9 of 23 (permalink) Old 04-18-2012, 11:08 PM
buster12's Avatar
An electrical engineer huh? I am a civil and structural engineer with a PHD and I design the largest bridges in the world. If I am low bidder I get to build them. My F250 is a beast and there are 3 things that have added years to my life: my wife, my IPhone and Ed's tuned FICM. What are you waiting for?
buster12 is offline
post #10 of 23 (permalink) Old 04-29-2012, 01:06 AM
With your permission, I'd like to add that last line to my website. So very glad to have helped you, cygnus, and Bismic out!!
Awesome!!
Ed
2005 Ford Excursion with Hercules FICM tune
A1 Studded
EGR Delete
MBRP T409 4" turboback
Coolant filter w/ Delo ELC
Upgraded oil cooler
SS ESOF hoses
RAS
SCT SF3
Edge Insight CTS, pyro, diesel timer, fuel pressure
Rancho 9000XLs
Blue Spring upgrade (reg return coming soon)
External transmission filter
Amsoil bypass oil filter
The list goes on and on...
5030tinkerer is offline
post #11 of 23 (permalink) Old 04-29-2012, 08:36 AM
buster12's Avatar
Go ahead Ed.
buster12 is offline
post #12 of 23 (permalink) Old 04-29-2012, 11:53 PM
Done. Thanks!!
Ed
A1 Studded
EGR Delete
Upgraded oil cooler
SS ESOF hoses
RAS
SCT SF3
Rancho 9000XLs
post #13 of 23 (permalink) Old 04-30-2012, 05:39 AM
Ed recently repaired and added the PHP Atlas 40 program to the FICM on my 2004 F-350. I've been driving it about 10 days now, and the overhead mileage calculator went from 14.4 mpg to 16.4 mpg. I also noticed an improvement in turbo lag time. If the mpg improvement is real or close to it then I'll recoup the extra $150 for the program in no time. I definitely recommend Ed and the Atlas 40 program.
jmjackson is offline
post #14 of 23 (permalink) Old 04-30-2012, 08:47 AM
Ed, what's your website?
Nevermind. Found it.
GusHauler is offline
post #15 of 23 (permalink) Old 05-04-2012, 02:52 AM
I recently bought an 06 super duty with a 6.0, and I am trying to determine if I have an FICM issue for sure. Mine smokes at start up and up until it gets warmed up. If I give it some throttle durning that time it really smokes a bluish white smoke. Hooked up a scaner and have ocassional drops in FICM voltage, down to 46.3v. Not totally sure thats the true problem. Have good voltage everywhere else and good connections as well. Any information?
sallee2626 is offline
