FICM Voltage - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 08-18-2010, 05:52 PM Thread Starter
FICM Voltage
I just got my new Auto Enginuity cable today. The check engine light is not on, and there are no FICM codes. Tht AE Live Data Meter says that my FICM voltage is 47.5V, is that too low? The check engine light is not on, and there are no FICM codes.
04 F-350 XLT, 6.0L Power Joke, 6 speed, SC 142"WB, Arizona Beige, FX4 manual hubs, trailer tow mirrors, MBRP cat-back exhaust
350camaro is offline
post #2 of 6 (permalink) Old 08-18-2010, 06:36 PM
Its low when its well below 48V which is stock.
1999 F250 2WD RC/LB posi AIS, Superchips DPI propane, 4" turboback exhaust, gauges, Edge Evolution tuner [looking into a Propane chip]
SMOKESKULL is offline
post #3 of 6 (permalink) Old 08-18-2010, 07:38 PM Thread Starter
I took the truck for a ride, most of the time the voltage was at 47.5V but several times I saw it drop to 46.5V. When I have, I will have to take the FICM apart to check it out for the bad solder connections.
post #4 of 6 (permalink) Old 08-19-2010, 08:31 AM
Paul H's Avatar
My Photos: (10)
Does it run rough or miss any? low on power or responce?
All would be considered a suspect FICM but 47 volts is not that alfull bad, some drop to 32 volts
Paul H
OWNER
2004 Ford F350 6.0L Dualie 273.000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty EGR delete running ELC all stock
1996 Ford F350 7.3L Dualie 343,000 Tony Wildman custom burn,5 inch stacks, good ole girl(in Avatar)
1995 Ford F250 7.3L Regular Cab 255,000 miles Sled Puller
Paul H is offline
post #5 of 6 (permalink) Old 08-19-2010, 11:08 AM
CAMPINGTOM's Avatar
I think Ford spec is 45v or above. I would say that yours is fine.
2005 F-250 6.0
4" Straight Pipe, CCV Reroute, Coolant Filter, Sinister EGR, Insight Monitor, SCT X3 (Tuned by Innovative)
Blue Spring, Atlas 40 FICM Tune
CAMPINGTOM is offline
post #6 of 6 (permalink) Old 08-19-2010, 04:06 PM Thread Starter
Last night I read on another board that Ford the spec is 45V. I am going to leave it alone for now, it sounds like it is ok. When I get some free time I may take it apart to check out the soldering, but that won't be anytime soon.
