Did a lot of reading on FICM voltage issues but couldn't really get a good answer on one thing. Does the voltage drop/fluctuate with temperature. (oil viscosity too I guess).
Lately been about -30c around here and have had the truck plugged in. Last week let it sit for few days then plugged it in for 5 hours - no start and the batteries were dead. Recharged for the day and it fired up.
Next day, start up and go for a burn - after a couple miles starts running rough, no power so pulled over. Cleared itself up in about 30 seconds and then ran fine.
No CEL but code P0275 (cylinder 5 contribution/balance) was present. Has run fine since.
Checking FICM voltage via the Edge CS and the Key On/Engine Off voltage is fine @ 48.5 volts. Fire it up and drive then it drops to around 30V and progressively gets better as the engine warms up until its back to ~48V at idle but drops under accelleration as power is put to the injectors.
Is this normal for FICM voltage?
I've always thought my truck billowed a lot more white smoke in this type of cold than other 6.0l so still suspect that injector 5 might have always been wonky and you can hear the 'miss' from that bank on initial start so I'll check that anyway. Seems to be more of a tinge of blue to the white smoke too and possibly some raw fuel out the tailpipe (which I previously thought was just condensation).
Insights, suggestions before I talk to my usually wrench-pullers later?
Your FICM is toast send it in to Ed, anything under 45v anytime (going bad). http://ficmrepair.com/ My choice
Plus you need to get some new batteries 850CCA then see what you have
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
You need a Syn 5w40 oil use Ford or Racor filter only and if plugged in it starts better and your FICM is under 45v its bad. Pull it and send it in to Ed. If you need to call him his number is in the link.
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
Yeah, I've dealt with cold weather operations for years, no issue with the oilweight or filters (Ford only), batteries, block heater, battery blankets etc.
I've just never watched the FICM voltages before so wasn't sure with fluctuations.
Penhall, the varying FICM voltage you describe is not normal and it is indicative of a failing module. A good FICM should hold voltage steady withing 1V during any condition. The drop to 30V is way below specification and as recommended you should repair or replace it before it leaves you stranded. I have observed this very behavior when diagnosing FICM's many times over the years.
__________________ . Ford Master Diesel Technician Diesel Technician Society Diesel Mentor Directory
Perfect thank you. I'm definitely going to replace it now as I can afford the time to park the truck for bit to get it done. Strange that it didn't throw any codes though (other than probably taking out the one injector)
I've recently replaced my ficm with a rebuilt unit from ficmrepair.com. Got the upgraded version, with 2 yr warranty, and the atlas 40 tune. The truck drives a lot better now, smoother acceleration, plus the extra power is nice. Holds 47.5-48.5 volts during all conditions.
I just had Ed repair my FICM and added the Atlas 40 tune. My fuel mileage has increased by about 3-4 MPG. I average 21.9 MPG today at 65-70 MPH. Overall average for the last 4 days with 1000 miles hwy and 75 city was 20.3 mpg. I am running Rotella T6 synhetic for the first time with 111k on the clock. I just replaced the EGR and Oil coolers and cleaned the EGR valve and boiled the intake. Added the Blue Spring Mod as well. I believe the FICM was my greatest improvement. Call Ed he will help you and will not recommend the 58V upgrade.
I am happy as a lark about my latest repairs.
PS: I am also using the Ford MC Cetane boost. 4 oz to 25 gallons
2004 F250 Crew Cab King Ranch Lariat FX4 Saddle Leather 6.0 L FUMOTO Valve
AIRAID 4" straight No CAT No MUFF
Nitto Terra Grapplers All Terrain LT285/75R16 10 PR Everything else pretty much stock
NEW Ranchos installed 8/15/2010
WORK IN PROGRESS - R&R EGR COOLER, OIL COOLER, THERMOSTAT, TURBO BOLTS, GASKETS, ORINGS, and adding a COOLANT FILTER WITH NEW COOLANT AND FLUSH
Anyone Got Birds? Will Travel to Hunt!
We are all just Village Idiots,
Enamoured with our own shadow,
Oblivious to the setting sun!
Reason: PS
SWEET Great post, Eds the man
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
just jumping on the band wagon too. I had to replace my FICM as well. Sent it to Ed. i asked him about the 58v upgrade and he sternly advised against it.
My FICM had two (of four) bad power supplies. He fixed those and added the Atlas 40 programming from PHP. Same results as above with mileage and greater low end response (seat of the pants).
One other thing I did do under Ed's advice is replacing the crappy stock alternator with an upgraded one from DCpower. Ed told that is what probably helped zap my FICM. No worries now!!
2005 F-250 Lariat CC FX4 4WD, 5th Wheel hitch, 5 inch Turbo back Cat/ Muffler delete, FICM Rebuild from FICMRepair.com w/ Atlas 40 from PHP, 220 amp Alt from DC Power, IPR EGR Delete, IPR Up=pipe, '08 banjo bolt mod, Blue Spring Fuel Pressure Regulator mod, AMSOIL oil bypass filter, Dieselsite Coolant bypass filter, Zoodad mod, High idle mod, CCV mod routed to left rear, Rotella T6 5w-40 Synthetic Oil, Recon Blacked out third brake light/ side mirror turn signals, 7in Screen Double Din AM/FM/CD/DVD/ iPod ctrl/ NTSC TV eBay special, Rear 56" 5 way light bar...
