Filling oil filter canister with oil? - Diesel Forum - TheDieselStop.com
Old 03-09-2005, 01:23 AM   #1 (permalink)
Was changing the oil tonight when I got to thinking... Could I fill the engine with oil by filling the oil canister (the thing that houses the filter)? This way when I start the engine for first time after changing the oil, the oil cooler as well as oil canister and filter wouldn't have to fill with oil before oil started circulating through the internals of the motor. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Also, I finally installed my fumoto... I am gonna love this thing, I can tell already. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
maps
Just my 2¢ Take it for what it's worth!
________________________________
2003 F250 4x4 XLT Supercab SB 6.0L/TorqShift, FX4, Add On's: 285/75/16 BFG AT's, MBRP turbo back, Dieselsite coolant filter, Isspro gauges on the A-pilar, remote start, RhinoLiner, Prodigy, Husky floor liners, Husky mud flaps, Firestone Ride Rites #2071, fumoto valve, Weathertech Weatherflectors
maps6874 is offline
Old 03-09-2005, 01:36 AM   #2 (permalink)
My Photos: (6)
Re: Filling oil filter canister with oil?
As soon as you take out the filter, a valve opens up on the bottom of the canister dumping the oil into the crankcase (the reason to remover the filter before draining). Refilling at the oil filter canister is only going to save you from opening the oil fill tube and give you a slightly larger filling hole with out a funnel. You will love the fumoto.
-Rich
'04 F250 Lariat PSD CC FX4 SWB, Auto, Dark Green Satin, Med. flint, Heated captains, ESOF, Remote start, AIC w/ wood grain cover, Chrome cab steps, Reciever hitch, Power rear slider, Clearance lights, Rubber mats, Rhino, Extang bed cover, XM Roady2, Brakesmart , PIE
'05 Isuzu NPR flatbed dump
'04 Isuzu NPR diesel flatbed dump
'90 F350 box dump
Kubota L4240 HST (Front loader, Harley rake, Rototiller, Brillion Seeder, pulverizer) , Perma Green Centri (ride on spreader), Walker Mowers (the best), Shindaiwa and Stihl
Toys:
36' Pacemaker Sportfish
'90 Mustang GT 5.0
'90 Jeep Wrangler 4.2
'72 Triumph Spitfire
15' Boston Whaler 70hp Yamaha
Yamaha GP760
Sunfish
1Chavez is offline
Old 03-09-2005, 08:38 AM   #3 (permalink)
When I had my '03, I was able to install the filter without the cap which closed the valve on the bottom of the cannister. The oil then was poured over the filter and did fill the cannister and stayed there. After it was full, I would gently screw the cap on and the filter would lock into the cap. Result was a "primed" oil filter.
On the '04, the spring on the valve is strong enough to push the filter back up when it is installed this way, allowing all the oil to drain back into the pan. End result, I can't prime the filter on the '04.
Try the priming method on yours to see if it will work. It has been said many times before, these trucks are snowflakes; no two are alike. Yours may allow you to prime the filter, thus making the initial startup after an oil change a little less painful to the internal parts.
And yes, the fumoto valve makes life much easier when it is time to change the oil.
Aaron
2004 F250SD 4x4, XLT Sport, FX4, Crew Cab
6.0L PSD, Torqshift, 3:73ls
Dark Shadow Grey, Power Cloth Captain's Chairs
Reverse Sensors, Heated Switched TT Mirrors,
Adjustable Pedals, Covermaster CMX Series Topper,
Bedrug Bedliner, Prodigy Brake Controller
Hensley Arrow Hitch, Ride-Rite Air Bags, Dashmat
X-Monitor Digital Gauges, Tach 1200 High Idle Mod Harpooned
Born on 1/21/04,
My Photo's
ABrown134 is offline
Old 03-09-2005, 09:31 AM   #4 (permalink)
just curious what is a fumoto valve????????
2008 F450 lariat 4X4 offroad 430 gears, dark pearl blue with gold trim everything but navigation, 92 mustang lx 5.0 coupe 375 hp wild strawberry, 03 harley road king classic,06 mustang gt (mrs pstrokes car) 2001 newmar kountry star 35ft triple slide (our beach house)....
LENSPSTROKE is offline
Old 03-09-2005, 12:13 PM   #5 (permalink)
It is a valve that replaces the drain plug in your oil pan. Allows for clean oil change and allows you to take oil samples between oil changes if you like. Picture of one can be seen here: <font color="blue">[fumoto].
maps
maps6874 is offline
Old 03-09-2005, 12:13 PM   #6 (permalink)
It's a valve used for easy draining of your oil. It takes the place of your drain plug.
Try a google search.
...Rich
08 F350
Loaded Lariat 4x4 CC Long bed, backup camera
Kenwood DNX-7100 dvd/navigation/sirius
richgann is offline
Old 03-09-2005, 12:28 PM   #7 (permalink)
AllOutFirefighter13's Avatar
Is is quicker to poor oil into the filter housing, or using the oil fill tube?
Joey
* '04 F250 XCab LWB 4X4 w/ FX4 *
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
AllOutFirefighter13 is offline
Old 03-09-2005, 01:03 PM   #8 (permalink)
thanks for the info, ordered one today.....this forum is great :
Old 03-09-2005, 01:08 PM   #9 (permalink)
Anything I can do to help you spend your money! LOL My fiance calls me a diesel addict. Welcome to the site!
maps
maps6874 is offline
Old 03-09-2005, 01:09 PM   #10 (permalink)
I use a funnel in the oil fill tube. Works like a charm.
I have never poured any oil in the oil filter canister.
Just seems like a waste of time and if you're not careful,
you could have an accident pouring the oil over the filter.
My oil change takes 15 minutes max.
Tincan
<font color="red">[b] 2003 F250
6.0 PSD XLT, 4x4 SC FX4 LT265's 3:73 LS/Torqshift
LineX Bedliner Hog Catback Exhaust Virtual Billet Grill Tranny tune by ID
<font color="blue">05/05/03 Build date
<font color="blue"> Anchors Aweigh
tincan is offline
Old 03-09-2005, 01:14 PM   #11 (permalink)
Thanks for the info. I think I will try this with my next oil change. I like the idea of having the oil filter "primed" on the first start up.
maps
maps6874 is offline
Old 03-09-2005, 05:37 PM   #12 (permalink)
I'm a new diesel owner too. What is a Fumoto?
Forget the question. I read further and got the answer to my question.
Thanks anyhow.
Paul
pdame is offline
Old 03-09-2005, 07:42 PM   #13 (permalink)
dbennett48's Avatar
Here it is: www.fumotovalve.com.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 03-09-2005, 07:47 PM   #14 (permalink)
OT
OT's Avatar
Curious..I'm gonna try again, but can't figure out how to hold filter down &amp; get cap on without some oil draining. Or is it, some o. does drain but not all which seems more realistic? Just asking...
OT [img]/ubbthreads/images/graemlins/smile.gif[/img]
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 03-09-2005, 08:49 PM   #15 (permalink)
OT
Like I said, on the '03 the filter fit tight enough on the center post that it held down and closed the drain. The cannister would be full up to the threads when I would put the cap back on.
The '04 has either a stronger spring on the drain valve or a smaller center post, cause it just doesn't work. I'm hoping with time it might get a little weaker and work like the other one did.
Wow, never thought I would have found something I actually liked about the '03... [img]/ubbthreads/images/graemlins/blush.gif[/img]
Aaron
Born on 1/21/04,
My Photo's
