finally got her top off - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 11-10-2012, 11:22 PM Thread Starter
A word of advice before you go in. PRESSURE WASH lots. If you dont have one spend 5 bucks on the engine alone. Hit every corner and oriface you can find. Hit the exhaust manifolds hard. Wire brush em. As soon as you lift those heads the scale on the manifolds will drop into your cylinders. BAD..
Has anyone seen a chart like they have in the back of Haynes manuals with spark plugs but for injecors?
I am working on a base engine fault 0278 which I suspect was a bad gasket since #6 and #4 kinda sucked contributuion wise. Pistons look awsome. Cylinders still have hach marks.
Need to magnoflux the heads for cracks and go from there.
Is the HPOP rebuildable or do I buy a new one?
I'm off to chase moose in a 7.3l for the next few days. Take a moment on the 11th for the boys that fell for you.
04 f350 ext cab 4x
95 psd 4x,5sp, down piped, 10,000lb warn, hydro bumper,tymar type intake, 285/75/16 at2 yoki geolanders, custom boat rack with 12' aluminium on top, kawi kdx in the box,
fastford is offline
post #2 of 3 (permalink) Old 11-11-2012, 12:15 AM
fordnatic68's Avatar
Buy a new hpop. Im just in teardown mode myself. In Langley.
03 F350 6.0 XLT Lariat Born 12/21/02 Crew cab short box loaded to the nuts
Autometer Guages - Pyro, Boost, Tranny, Oil Temp, Oil pressure,F & R Diff Temp,Voltage, Fuel & HPOP
Custom dash mods to clear up clutter ontop and eliminate blind spot at A pillar
Edge juice w/ attitude ( unlocked)
Banks Intercooler, Hi ram intake n tubes
Twin Optima yellow tops
BD 5" exhaust
Snow Performance Water/Methanol injection w 7 gallon tank (water only)
EGR Delete Kit
Silverline twin 8" slash cut stacks
New stock Ford Hpop
New stock Ford oil cooler (waiting for BD's version of remote cooler filter kit)
Garrett Powermax GT3788VA Turbo
Airaid cold air intake
Zoodad mod
10.5 " Procomp lift (really 8.5 w some mods)
42" good year wranglers w Kevlar sidewalls
5" Bushwacker cut out Flares
Goodhood Dual ram air fiberglass hood from US body
90 F250 Extended cab long box 460 auto
57 Mercury stepside
fordnatic68 is offline
post #3 of 3 (permalink) Old 11-11-2012, 09:31 AM
I wish both of you good luck with your rebuilds. I have been there but had someone else do it and it was expensive that way, hopefully your work will be cheaper. The shop I used is a cab off only place.
baddna is offline
