Old 06-22-2009, 10:40 AM   #1 (permalink)
Finished the oil/egr cooler swap
I just wanted to post this for the people that are considering doing the swap by themselves. It took me a week of 3-4 hours a night after work to complete the swap. The kits came with all the o-rings and gaskets that were needed to complete the task, I didn't have to run out in the middle of the project to try and find any parts. The project was tedious but not difficult. Everyhting came apart without struggle and went back together the same way. I am glad I took on this challange and saved myself a few thousand bucks. Here is a list of what I changed and the price:
Oil cooler = $475 + sh
Egr Cooler = $330 +sh
Degas Bottle = $60.28
Thermostat = $30 something - cant remember
Coolant Filter = $160 with valves, extra filter and shipping
4 gallons FORD Gold coolant = $48
Oil change = $55
Torque wrench = $100
Rough total:$1260
2004/04 F350 Lariat CC LB 4X4 SRW, Dark Toreador/Arizona Beige, 6.0L/Torqshift, 3.73LS, Heated seats, Clearance Lights, TT mirrors, Captian Chairs, Moonroof, ESOF, 12K Receiver
4" MBRP T-409 Cat Back
BlackMax Tonneau
Prodigy Brake Controller
2007 Prowler 3102 BHDS
2000 TERRY EX 27F (Sold)
2001 F250 SC 4X4 5.4L (Sold for '04)
My Pictures.
3gees is offline
Old 06-22-2009, 09:30 PM   #2 (permalink)
hey 3gees,
if you dont mind me asking why did you change out all these components did you have problems before. What kind of coolant filter setup did you get.
06 f350 cc lb dually 6.0 4x4 6speed lariet. Straight piped,S&B cold air intake,timbrens.B&W hitch,rihno lined.
02 softail deuce
07 articat 700 le 4/4
06 silverback fth wheel 36 foot
DieselDoctor22 is offline
Old 06-23-2009, 08:50 PM   #3 (permalink)
dieseldoctor22,
I had problems with a clogged oil cooler so while I had it apart I did the egr cooler too. As far as the coolant filter I bought it from "Dieselsite.com" as recommended by others on this forum.
BlackMax Tonneau
My Pictures.
3gees is offline
Old 06-25-2009, 02:39 PM   #4 (permalink)
Why did you choose not to do the EGR cooler delete?
thebozman is offline
Old 07-03-2009, 05:54 PM   #5 (permalink)
3gees,
do you have any links or instructions on how to do this change out? I have the preliminary signs that something is up. There appears to be the puffing sound and sings of coolant coming out of the degas bottle. I just had the system flushed, but it is still making the puffing sound and has the signs of leaking around the degass bottle cap.
boulder is offline
Old 07-03-2009, 06:11 PM   #6 (permalink)
Way to go 3gees!
Mark
'06 F250, CC SB ESOF FX4 Lariat 3.73LS, 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto valve; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & Britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
bismic is offline
Old 07-04-2009, 10:36 PM   #7 (permalink)
Did your oil cooler blow up? Mine did! The ERG cooler is stopped up. When this happens Ford dealers flush the entire cooling system with 3 gallons of Simple Green (I assume to get rid of the oil thru the system and clean the heater coil of all the oil that went thru the cooling system. They also send the radiator out to a radiator shop to boil it clean too.
Geez, I'm looking $3600+ as of last Friday, and I told them go ahead replace the fuel filters.
Bo McCarty, REALTOR
2003 F250 6.0 Turbo Diesel.
theboman@theboman.com
theboman is offline
Old 07-06-2009, 09:15 AM   #8 (permalink)
My oil cooler didn't blow up or even leak in to the coolant. The only symptoms i had was venting coolant out of the degas bottle, but only when towing. At first, i thought head gaskets, but then i did some more research on this site and read about the clogging of the oil cooler. This seem to fit my situation better than head gaskets for these reasons: (1) I towed the TT in October 08 with no issues with the coolant (2) During the winter i only used the truck maybe once a week or two weeks (3) I towed the TT in April 09 and had the coolant issues. I am not a mechanic by trade but it seemed to me that the head gaskets/bolts would not go bad from October to April with limited use, but a clogged oil cooler made sense due to the fact of that muddy coolant just sitting in the engine for the most part of the winter. I hate paying labor for somthing I think I can do myself so I went for it and so far so good.
BlackMax Tonneau
My Pictures.
3gees is offline
Old 07-06-2009, 09:21 AM   #9 (permalink)
Originally Posted by boulder View Post
3gees,
I do not have instructions. I identified the location of the oil cooler and just started removing stuff until i revealed the cooler. I refered to the 6.0 bible for some helpful pics and definitely the torque specs and bolt tightening sequences on the intake manifold. I just took my time and labeled every plug or bolt that i removed.
BlackMax Tonneau
My Pictures.
3gees is offline
Old 07-06-2009, 10:00 AM   #10 (permalink)
Thanks for the response 3gees. I sent you a PM, but for others benefit could you tell me where you ordered your parts from? specifically the 2 coolers. Also did you have to remove the intake manifold to remove the EGR cooler and then get to the oil cooler? I am pretty sure that the turbo has to come off but you may be able to confirm that as well.
thanks again.
boulder is offline
Old 07-06-2009, 10:05 AM   #11 (permalink)
I bought the oil and egr coolers from Welcome to PartsCentralUSA Check your pm for the rest. Hope it helps!
BlackMax Tonneau
My Pictures.
3gees is offline
Old 07-27-2009, 08:13 PM   #12 (permalink)
Update: I took the TT for a trip for the first time since replacing the egr/oil cooler and everything seemed to be ok. The trip was a 200 mile trip from southern NJ to CherryStone CG in VA. There was a lot of stop and go with traffic lights (Rt 13 if your familiar) and all seemed to be ok. I was more nervous about the trip because I did all the work myself and this was the first time I have done such invasive work on a newer vehicle. So far so good!! I just wanted to put that out there.
Thanks for all the help and guidance from this site.
BlackMax Tonneau
My Pictures.
3gees is offline
Old 07-28-2009, 08:19 AM   #13 (permalink)
Albin's Avatar
My Photos: (25)
Do you still have the old oil cooler as it came off the engine? Anyway to take pics of it?
Here's what I did to a friend's oil cooler and what was plugging it up.
Al
'06 F-350 SRW 6.0 PSD
Albin is offline
Old 07-28-2009, 03:38 PM   #14 (permalink)
NU2Diesel2006's Avatar
Albin,
that is pretty gunked up. What the h**l is that stuff?
2006 F350-Lariat, CC/SB 4X4 SRW-Wedgewood blue
6.0L PSD, Auto, 'with all the goodies' except the moonroof, born 23/3/06
BCP mod-switch #4, CAC tube secured
Zoodad
LEER Canopy and Chrome stepbars, Draw-Tite 18k Signature Series hitch
Line-X bedliner
Sirius Satelite Stereo
Alarm/Remote start
2000 26 ft Frontier Plainsman fiver - 11k loaded
Looking to add LCD monitor/gauges, back up lights and intake elbow soon
NU2Diesel2006 is offline
Old 07-28-2009, 06:39 PM   #15 (permalink)
rsd
What years do you have to worry about casting sand in the coolers?
'03 F-250 Crew Cab 6.0PSD
rsd is offline
