Fluid change in a 2004 Diesel f350. - Diesel Forum - TheDieselStop.com
Old 11-15-2009, 01:12 PM   #1 (permalink)
1. What does it take to change the fluid in the automatic tranny for 2004 diesel?
2. Does it have a filter?
3. Is the pan gasket reuseable?
4. What fluid is recommended?
My truck is stock and I am tired of paying Ford 200.00 for this service.
2004 6.0 Liter F350 4x4 stock.
Always_Workin is offline
Old 11-15-2009, 02:11 PM   #2 (permalink)
69cj's Avatar
1. To do it properly and get all the fluid out of the torque converter you need a heated flush machine.
2. Yes an external filter, ft-145, behind the front bumper pass. side.
3. yes, but the int. filter only needs changing when rebuilding trans. It stops trees and boulders.
4. Mercon SP only.
Tranny should be flushed every 30,000 miles. I do the ext. filter every 10 to 15,000 miles for peace of mind.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-20-2009, 01:43 PM   #3 (permalink)
Soooo
What you are saying is that I need to have a shop do this? Most only drain the pan. Therefore, I figure I will end up at FORD paying the 200.00.
Old 11-20-2009, 02:07 PM   #4 (permalink)
i suspect if you were to just drain the pan, and replace that fluid every 10-20K - of course assuming the fluid isnt burned to start, and replace the external filter, that would be pretty good.
2011 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Sterling Gray Metallic
SOLD:2005 F350 XLT 4x4 FX4 SRW SC SB 6.0 PSD/TS Med. Wedgewood Blue, Dual Alternators, Tow Command, Bypass Coolant filtration.
djousma is offline
Old 11-20-2009, 03:58 PM   #5 (permalink)
69cj's Avatar
Since it's an 04, I would say it's too late for that. And if it is just coming up I would bet the ext. filter is loooong past due. The tranny has an internal t-stat and to properly flush it you need a heated flushing machine. It's the only way to get the old oil out of the torque converter. Draining the pan only gets approx. 8 qts. out leaving app. 10 qts. in the system. I just had mine flushed and the dealer charged me $133.00. Wasn't worth my time or trouble for that price. In fact I would still have them do it if they charged 200. Don't forget Mercon SP fluid only.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-20-2009, 06:14 PM   #6 (permalink)
MikeL46's Avatar
My Photos: (14)
Mercon LV is approved for the TorqueShift, and may be the only fluid the dealer will have or use.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 11-20-2009, 06:44 PM   #7 (permalink)
69cj's Avatar
Mike
That is new and yes is possible. Was not available 4 weeks ago when I had my tranny flushed.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-20-2009, 09:17 PM   #8 (permalink)
LV has been out for close to 2 years...the dealer may not have stocked it.
djshum is offline
Old 11-21-2009, 11:07 AM   #9 (permalink)
69cj's Avatar
If he's not stocking it then it's not available!
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-21-2009, 02:09 PM   #10 (permalink)
My dealer which is a fairly large one with a separate parts warehouse up the road has no LV in quarts. I bought a case of SP last week and wanted to try the new fluid.
Ljutic SS is offline
Old 11-21-2009, 02:16 PM   #11 (permalink)
Register with "my Ford" site and you will be able to print out discount coupons for service work such as fuel filter changes, trans flush, coolant flush etc. I just got a coupon for trans flush for $145 but I change my trans oil (8 qt.) every 10,000 miles.
Old 11-21-2009, 02:57 PM   #12 (permalink)
69cj's Avatar
Don't know where you live but Fritts Ford in Riverside, Ca. did mine 4 weeks ago for 133 with no coupon. The next closest dealer wanted 169.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-21-2009, 08:39 PM   #13 (permalink)
If there a new car dealership....and all the new vehicles are using it....t.hen they SHOULD stock it....OR be able to get it...DUH.
djshum is offline
