Flushing the 5R110W Transmission questions - Diesel Forum - TheDieselStop.com
Old 01-07-2008, 05:27 AM   #1 (permalink)
Hello all up here in the 6.0 forum. I don't post here much as I have a 7.3 with a 4R100 transmission. I have a new neighbor a good guy that is also a PSD owner. His is a 2003 6.0 and his transmission is just about due for its first flush. I believe his transmission is a 5R110W. We were talking about it and I agreed to help him with it. I looked up some flush procedures on the net. They seem similar to the flush procedure for the 4R100 procedure, let the unit self flush using it internal pump to pump fluid out one end as you put fluid in the other. With the 4R100 you just unhook the return line and pump it through the clear line until you see bubbles in the fluid, stop the engine refill the transmission, start it again and do that three times and the entire system is flushed. Only big deal is to start with a warm transmission and do it in the summer so the cooler is purged. I have done the 4R100 flush on my truck and others several times. In the 5R110W procedure I ran across in Truckblog it makes an issue of keeping the special SP fluid very hot and measuring the going out as you put the new in. Not certain if that was meant to be literal, pour fluid in one end as it is pumped out the other end. And how important is keeping the new fluid hot, and how hot? Is that the way to do it, put new in as the old is pumped out? Anyone have any tips on this procedure or know where another flush procedure is on the net, or has one they can e-mail me? Thanks, 106
2002 F250 7.3L PSD, bought new now at 195K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
Old 01-07-2008, 08:05 PM   #2 (permalink)
Re: Flushing the 5R110W Transmission questions
Wow, 65 views. Guess no one knows anymore than I do.
Oneof6 is offline
Old 01-07-2008, 08:25 PM   #3 (permalink)
The torqshift has a thermostat and if you don't keep it hot enough - I think 160 - 165, it won't pump it out to the cooler.
As the torqshift as a built in external filter, it may be just fine with a drain/replace and new filter. It won't get it all out, only about half, but the need to flush depends upon the condition of the coolant. Mine is still in good shape after 30k, so I just drain, replace filter, and add approx 8 quarts to top it off.
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
4x4Mark is offline
Old 01-07-2008, 08:31 PM   #4 (permalink)
I did mine same as the 4R100 and worked fine. Yes be sure to use SP fluid in a 5R
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
firesoutmatt is offline
Old 01-08-2008, 07:00 AM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: firesoutmatt</div><div class="ubbcode-body">I did mine same as the 4R100 and worked fine. Yes be sure to use SP fluid in a 5R </div></div>
Thanks, that is what I wanted to know.
Oneof6 is offline
Old 01-12-2008, 10:18 PM   #6 (permalink)
Mark Kovalsky's Avatar
There is a thermostat in the TorqShift. It will return about 90% of the cooler flow back to the trans and not to the cooler until the trans is over 165F. If you don't have the trans hot you're just mixing the old and new fluids. You're changing a mixture of old and new fluids. It's REALLY important to have it hot when doing the flush!
Mark
Mark Kovalsky is offline
Old 01-13-2008, 12:09 AM   #7 (permalink)
How the heck do you get it over 165 then? Mine never goes that hot with just normal driving.
New truck
2008 F250 6.4L, fully stock
Old truck
2004 F250 6.0, 4" T-back MBRP, AFE Stage II/PG7, CFM+ Largemouth, Snow Stage II Meth injection, Pyro, Trans, Boost pillar mount, SCT running Extreme Street, ITP reg return, AirDog, Oilguard bypass, CCV mod, Diesel Site coolant filter, harpooned, 08 Diff cover, Daystar levelling kit, Viair onboard air with Siege train horns, heated mirror switch, Hella 500 Driving and Fog lights behind Billet grille, back-up lights, Kenwood 7019 in-dash DVD, Alpine S in the doors, 2 10" JL subs with Alpine amp.
ryano2121 is offline
Old 10-12-2009, 12:40 PM   #8 (permalink)
Bumping this oldie toward the top:
I've got an 08' PSD coming that is due for the ATF change. Short of hooking up a heavy trailer and running uphill on a hot day, it will be tough to open the thermostat.
I was thinking it might work best to put a hot air gun on the part of the oil cooler where the thermostat is, and just keep that really hot. Has anyone tried that?
Or is there another connection on the oil cooler that I can open to drain the cooler side of the system?
dgeesaman is offline
Old 10-12-2009, 01:06 PM   #9 (permalink)
Interesting idea, and it would probably work if the thermostat was anywhere near the cooler. It isn't. It is inside the transmission near the pump. You're not going to get a heat gun anywhere near it without tearing down the transmission.
Draining the cooler is easy. Disconnect one of the lines at the trans and it will run out. You'll get a quart or two.
The question remains what about the 10 quarts or so that you don't get out of the transmission and torque converter without doing a flush?
Mark
Old 10-12-2009, 06:54 PM   #10 (permalink)
patrickrc51's Avatar
Sounds like to much work. The dealer only charges like 175 to do it and your gonna pay like 100 for all the fluid. Besides they use a flusher and filter system to do it.
Thats where mine went for the flush and I do all my own work...
06 F-250, 6" Rize Lift w/ 13.5" of travel, Dirt logic 14" Travil Shocks, 325/65/18 Hancook DYNAPRO MT, 4.30 Motorsport Gears, 5" Shop Diesel Turbo Back Exhaust, 55 Gallon Fuel Tank, 4x9inch HID lights on a Custom (Custom=Redneck) Winch Bumper, Autometer Electric Gauges, SCT (Best Mod Yet), CFM BigMouth intercooler pipe and intake, 10k miles to go before the power is unleashed...
patrickrc51 is offline
Old 10-12-2009, 07:28 PM   #11 (permalink)
Good enough reason. On my RX-7 the oil cooler is thermostatically controlled and I'm told it's right at the base of the cooler.
Yeah, now I see the point if the balance of the fluid is hanging out in the trans not the cooler. But still a quart or two out of the cooler helps.
I was thinking about filling with Amsoil's Mercon SP ATF but at $9/qt it will be quite expensive to do partial fills and drains to get it to clear out. Sounds like the helper pouring in fresh fluid while shifting gears and draining method is best.
Fortunately if the thermostat is deep within the transmission, it might not take a mountain climb to get it super hot. If it's deep within the transmission it will stay warm for a little while. Maybe running the hot air gun over the transmission cooler might help keep things generally hot.
David
