Fog on windshield?? - Diesel Forum - TheDieselStop.com
Old 03-12-2008, 10:48 AM   #1 (permalink)
Fog on windshield??
Returned home from fishing last week, towing a 20' bass boat 120 miles (maybe 4100lbs.) I noticed mileage sucked 10.2 usually around 13.5. I let turbo cool for 8 minutes and shut down. Twenty minutes later I moisture had developed on my windshield. HGs?? Heatercore?? No I do not have a programmer. Way to scared of problems for that, even the exhaust is stock. Truck has 36100 miles. Any ideas??
Shef
06 F250 CC 6.0 4x4
Sheff is offline
Old 03-12-2008, 10:58 AM   #2 (permalink)
Send a message via AIM to Larry202br
Shef
06 F250 CC 6.0 4x4
If you had coolant leaking from the heater core, you'd smell it. My guess is you just had some condensation due to high humidity. Don't know why the mileage was so low.
2004 F-250 Lariat, srw, short bed, 4x4, Purchased in Feb. of 2006. 6.0, auto, 3.73.
Larry202br is offline
Old 03-12-2008, 12:42 PM   #3 (permalink)
MikeL46's Avatar
My Photos: (14)
were you running the AC or the defrosters on the way home? Either on turns on the AC. And if the drain tube is blocked, moisture will build up and can fog your window when you stop.
Find AC drain tube ( water drips out of it when you use the AC - or at least it is supposed to) and try and blow air up it.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 03-12-2008, 01:43 PM   #4 (permalink)
AC Drain is fine nor was enviromental system used.
Shef
Sheff is offline
Old 03-12-2008, 04:45 PM   #5 (permalink)
I noticed today that I had exta coolant in the degas bottle. Usually its at the low mark and now its over the max mark. Is it getting ready to puke?
Shef
Sheff is offline
Old 10-27-2009, 08:50 PM   #6 (permalink)
Found this after doing some digging. I have the same issue, fog on the windows. I don't smell anything however. A couple times recently, I have been told it smells funny when getting inside. Sweet almost... I am guessing the heater core, however I do not have any puddles anywhere...
How hard is this to do on an Excursion?
04 X, 4x4, 6.0, V and Mod B codes, Rear Ford Sway Bar, Poly bushings front and rear on sway bar/end links.
Tony2Co is offline
Old 11-02-2009, 11:04 PM   #7 (permalink)
More info...
The smell is a little more noticeable now, but not a huge difference. What I have noticed is normally I keep the temp control set at 60 to 70... Slight smell sometimes. When I turn the temp up so actual warm to hot air comes out, the smell is not there. What does that mean?
Any info would be helpful, already in the middle of head gasket replacement on a Toyota. Don't have time for this... What is the saying, rains it pours...
Tony2Co is offline
