"Free" oil change, problem??? (sorry long post) - Diesel Forum - TheDieselStop.com
Old 06-02-2005, 07:57 AM   #1 (permalink)
Had my 1st oil change yesterday, the "free" one at the dealership. Stuck my head in the door while the oil swapper was doing the work.
He had the truck up on the lift when I got there. He drained the oil and re-installed the plug. Then he lowered the truck, loosened & removed the filter, then replaced the filter and refilled with 3x 5gallon jugs of Motorcraft 15W30 CI4 oil.
I thought I read that the oil filter should be loosened before draining. Also, many have posted here about only using 14 qts.
Checked the dipstick when I got home and to tell the truth I really couldn't see if it was overfilled. Then again, that dipstick is hard to read. Will check again this morning before I leave.
Does removing the filter after draining allow the dirt trapped by the filter back into the system? Should I just change it again myself? I have everything on hand to do it now.
2005 F350 PSD, TS Auto, Lariat Luxury, CC, SRW, Short Box, 4x4, ESOF, 3.73 LS rear, Tow Command...
Born On: 4/26/05
Heads replaced at 12,700 miles under warranty.
Added: LineX, Isspro gauges in the A Pillar, Reese Titan hitch, AIC enabled thru upfitter switch. A.R.E MX series cap, Fumoto valve, KC backup lamps thru upfitter switch. Everything else stock.
MrMike is offline
Old 06-02-2005, 08:00 AM   #2 (permalink)
Re: "Free" oil change, problem??? (sorry long post)
Yup, they did it wrong. The manual clearly states that you must remove the filter while the drain plug is removed. The problem is that oil is trapped in the filter housing until you open the housing. The guy who did your oil change allowed that trapped oil to fall into the oil pan and then get mixed with the new oil.
louzonr is offline
Old 06-02-2005, 09:18 AM   #3 (permalink)
Are you sure he hadn't already loosened the filter cap some before raising the lift? If he didn't have to wrench the cap off after lowering the lift, then he probably had it draining before you started watching.
As far as the POS dipstick issue, try pulling the dipstick out and let it stay out for about 30 minutes (cover the tube with a cloth). Then wipe off and reinsert the dipstick just to where the bottom of the T handle is about an inch and a half or so above the top of the steel tube, then pull it out again and wipe it off. Repeat this 3 or 4 times and you'll clean most of the oil out of the tube. Then reinsert the dipstick until the bottom of the T handle just meets the top of the steel tube and then read the oil level. It should be below the MAX mark. If it's over MAX, then it's overfilled.
(Personally I think it should be below MAX with the thing fully inserted, but that's already another POS dipstick thread. [img]/ubbthreads/images/graemlins/bleh.gif[/img] )
2004 F-250 Lariat CC, Short Bed, 4x4, 6.0L, TorqShift, FX4, Metallic Green/Arizona Beige, Medium Parchment Leather, Fumoto, B&W Turnover, A.R.E. LSX Tonneau, Built 4/01/04
MoeB is offline
Old 06-02-2005, 09:58 AM   #4 (permalink)
The guy had to loosen up the oil filter cap with a filter wrench and I saw the cap spring up about an inch and a half. This was after he lowered the truck. [img]/ubbthreads/images/graemlins/depressed.gif[/img] Who trains these guys?
After sitting all night, the oil was definatly over the MAX mark on the dip stick.
I think I'll call the service dept and ask to speak with the service mgr. Don't want to bad mouth the guy who did the work, he was nice enough, but it is now apparent he hasn't been trained on these engines (or couldn't pass the test). Assuming the filter holds about a quart, I now have 15 qts new and 1 qt old oil in there. Perhaps they will re-do the job. Otherwise I will have to do it myself this afternoon.
Is it just a the old oil that drains back into the engine when the filter is loosened, or does the gunk that was filtered drop out too? If the gunk stays trapped, is there a way to drain off a quart or so without draining the whole thing?
Born On: 4/26/05
MrMike is offline
Old 06-02-2005, 11:49 AM   #5 (permalink)
FamilyRide's Avatar
What is "3x 5gallon"? Did he refill with 3 gallons = 12qt's?
You'll always leave about a quart to a quart and a half in that you can't get out. If he didn't pop the filter first, you likely have some additional old oil in it but it's not that big of a deal.
You can try to drain some off but you better be quick. [img]/ubbthreads/images/graemlins/laugh.gif[/img] That's where the Fumoto valve comes in really handy. If you do drain some off. Do it when it's cold and has sat overnight. You may get more crud out that could settle to the bottom, and it'll flow slower making it easier to drain a small amount and get the plug back in. Just be careful and don't try to rush the plug. You could strip it pretty easily, then you'll be draining 3+ gallons whether you want to or not. [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 06-02-2005, 12:02 PM   #6 (permalink)
Then he clearly did it wrong. Good luck getting them to re-do it.
Mostly just oil. The stuff that the filter is designed to trap will be stuck in the pleated media. A little of the surface gunk from the element may have gotten into the new oil, but the new filter will catch it again. Just do your next change a little earlier if they won't re-do the job.
I drained oil out of mine after the dealer overfilled it by slowly loosening the drain plug, then when I got to the last thread, I quickly moved the plug away from the hole for a few seconds, then put it back in real fast. Like FamilyRide says, do it while it's cold and it won't flow real fast (or burn [img]/ubbthreads/images/graemlins/eek.gif[/img]), and have a rag handy to wipe your hand. If you use a clean catch pan, you can let a few quarts drain out, then add back enough to bring the level up where you want it (half way between MIN and MAX is how I prefer it).
MoeB is offline
Old 06-02-2005, 12:48 PM   #7 (permalink)
MrMike
Did they put in 15 gallons?
I installed a Fumoto valve and just do the oil change myself and don't worry about the lowest paid guy at the dealer making a mistake. I would change my oil, if I were not sure.JMO
TasMan
2004/04 Engine,King Ranch,F-250,4x4,SWB,3.73 LS, Adjustable pedals,Reverse sensor,Moon roof,clearance lights, Power rear window,Heated seats,Bedliner, DPPI T-409 Turbo Back, AFE Pro-Guard7, C-Bet'r mirror, Fumoto drain valve, AIC, Extange Tonneu, Lund SS Interceptor, Siver Star Bulbs, Harpooned tank, SUV double wiring harness, Bright Box, Clifford RS 3.5 alarm, 3" Edge Plush Ride, Bilstein Shocks, Westin Sportsman CPS Grille Guard, XM Commander wired in with a PIE Adapter, Eagle 137 series rims and Bridgestone Revos 285/75-16, Husky Liner Mud Flaps.
http://community.webshots.com/user/tasman3721 UpDated 27 October 2005
Retired Chief Warrant Officer 4
tasman is offline
Old 06-02-2005, 01:02 PM   #8 (permalink)
Hope you meant to say 3 jugs of 5 quart oil. And I also hope it was 15W40 not 15W30.
2003 6.0L F250 XLT S-Cab 4x4 FX4 White/Black
my97TJ is offline
Old 06-02-2005, 02:00 PM   #9 (permalink)
You are correct. Gotta remember to have at least 2 coffee's before trying to communicate [img]/ubbthreads/images/graemlins/ooo.gif[/img]
Thanks for the help guys.
Born On: 4/26/05
MrMike is offline
Old 06-02-2005, 03:57 PM   #10 (permalink)
My dipstick solution - Take a piece of fine sand paper and rub it gently over the dipstick end. This takes the shiny surface off of it without affecting the high and low marks on it. Now with the dull gray surface, I can easily read my oil level.
06 F350 SC LB 4X4 FX4 Lariet 6.0 Torqshift, True Blue Clearcoat, tow command system. Toyo Mud-Terrain tires size 35/12.50//18 on stock wheels, Mag-Hytec rear differential cover, Bilstein shocks, and Alpine 9833 head unit, Kenwood Excellon speakers, and an Alpine V12 4 channel amp with 80 watts per channel RMS.
ronk54 is offline
Old 06-03-2005, 04:43 PM   #11 (permalink)
Tried the sandpaper on the dipstick bulb. Worked awesome, thanks!!
MrMike is offline
