fuel additive - Diesel Forum - TheDieselStop.com
Old 09-04-2005, 10:52 AM   #1 (permalink)
fuel additive
I used to add marvel mystery oil to my fuel in my old 7.3 to keep my injectors clean, but am hesitant to do the same with my 6.0. Any thoughts... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 CrewCab Short Bed,turboback w/cat mbrp,
Bak Rollbak Tonneau
mavrickracer5 is offline
Old 09-04-2005, 11:28 AM   #2 (permalink)
My Photos: (5)
Re: fuel additive
Thought 1 is that FOMOCO does not approve of anything other than Stanadyne. That is stated in the owners manual. Actually the diesel supplement I think.
John T
2005 F350 Arizona Beige Lariat SRW CC LWB 6.0L PSD Torqshift Loaded
100% Disabled US ARMY Veteran ('86-'90)
HighTech67 is offline
Old 09-04-2005, 02:21 PM   #3 (permalink)
Re: fuel additive
Rusty1,
FOMOCO has their own now. I don't know if they make it or if some other co. makes it for them. I have two bottles sitting here, one says cetane booster and performance improver and the other says anti-gel and performance improver. Both bottles are 20oz. and they say they treat up to 125gal. I don't know how much they cost, they were given to me for trial. Right now I use Stanadyne performace and have, since the truck was new. I have 154,500 miles on the motor right now with original injectors and o-rings. Al
'95 F350 Red cc,zf5,157k miles,3"dp with 4" exhaust,Di Pricol egt and boost gauges,DP-Tuner F5,295/75/R16 BFG AT, SD IC, 1.0 A/R,IC pipe kit, and Stage 1's from GTS, South Bend smfw with the con O from BDP.
alpena is offline
Old 09-05-2005, 01:45 PM   #4 (permalink)
Re: fuel additive
RUSTY1,
Yes STANADYNE is the best and as it is recommended by FOMOCO I would highly suspect that is what they are selling under thier own brand.
A lot of us use POWER SERVICE's DIESEL SUPPLEMANT & DIESEL KLEEN
It is available at your local WAL-MART.
POWER SERVICE'S website claim thier additives are the most used diesel additives IN ALL THE WORLD...that's a pretty bald faced claim to make if you can't back that kinda talk up so I am inclined to suspect they are talking true.
I add the DIESEL FUEL SUPPLEMENT whenever I tow & I add DIESEL KLEEN at every oil change.
My old 94' IDI 7.3 injectors cost me $23.95 each when I replaced them.
My 2002 7.3 PowerfulStroke injectors I heard go for $125.00 a throw.
But someone some time ago ssaid the injectors for our 6.0's.....
$300.00 each !!!!!!!!!!! That'll be a $2,400.00 bill due on or about 120,000 miles for our trucks!!
So I am trying to keep 'em clean and make 'em last as long as they can....
~Mack
Hayward, Ca
sillsmack@neteze.com
03 F350 SC FX4 SRW 6L 5SP
03 Jeep Wrangler Sport
sillsmack is offline
Old 09-06-2005, 08:34 AM   #5 (permalink)
Re: fuel additive
Thanks guys, I think I'll look up some stanadyne. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Bak Rollbak Tonneau
Old 09-06-2005, 02:33 PM   #6 (permalink)
Re: fuel additive
Rusty,
Anything w/ alcohol in it is a big NO NO for any high pressure injector system. You can't go wrong w/ Stanadyne, but I perfer 5g of biodiesel / tank to help keep it clean & lubricated.
OMCUSNR is offline
Old 09-06-2005, 02:52 PM   #7 (permalink)
Re: fuel additive
This being my first diesel (6.0), is a fuel additive really necessary?
2005 F-350, CC, SB, 6sp
PowerMax Turbo
Blue spring Kit
Diesel Site Coolant Filter
Fleetrite ELC
CIIWelding is offline
Old 09-06-2005, 04:02 PM   #8 (permalink)
Re: fuel additive
Maybe yes, maybe no. If you're in a cold area, you might add an anti-gel. Might add some stanadyne ever once in a while. Might use B-20 on a regular basis. It'll help keep the system clean & lubricated.
If you've got a good fuel dealer, you probablly don't need it.
OMCUSNR is offline
Old 09-06-2005, 05:06 PM   #9 (permalink)
Re: fuel additive
Has anyone used Gumout Diesel Additive in their 6.0L?
David
RaceWorksInc is offline
Old 09-06-2005, 05:20 PM   #10 (permalink)
stateboy776's Avatar
Re: fuel additive
The Motorcraft stuff is 8.99 local, I tried it in my 01 and can't really tell a differance. I too got it free and will switch back to Power Service next time.
2001 Crew PMT1 PCM,
Short Box Lariat,Auto,4X4,F350
Black with Tan Leather,Updated 2003 headlights and corners,Walker BTM, B&W Turnover Ball and Companion Fifth wheel hitch pulling a 2007 Pilgrim Legends,
BUILD DATE 08/00
stateboy776 is online now
Old 09-06-2005, 05:51 PM   #11 (permalink)
Re: fuel additive
I've been using Stanadyne in both tanks now for 2 years. I really think it runs better and I've had "0" problems since new.
Member: CO PowerStroke Club/Good Sam/Camping World-
2004 F250 Lariat 6.0 SD LB SC Wedgewood Blue Build date May 2003 with latest flash 05/26/05, 4" cat back with afe proguard 7 air filter, 50 gal. transferflo with tool box & Trax Command, LineX, "Brite Box", Pyro,Boost, &Tranny Gages "piller mount", C'Betr Mirror's, Cab Fresh Cabin Filter, Fumoto Drain Valve. Superchip Programmer, Timbrens, BrakeSmart, Garmin NUVI GPS.. Other: 2005 35ft. Gulf Stream Prairie Schooner
lheebie is offline
Old 09-06-2005, 07:16 PM   #12 (permalink)
Re: fuel additive
I added Stanadyne to my new 06 with 700 miles and can't tell the difference. If anything, the engine seems louder on cold starts. No increase in MPG. I get anywhere from 13 - 20 and average 15. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
RAR442 is offline
Old 09-19-2005, 09:47 PM   #13 (permalink)
Re: fuel additive
1st mistake was you added it on top of a full tank of diesel.
2nd mistake is you never take you're foot out of the floor board.
Regardless in the long run its going to help with the life of you're diesel.
Stanadyne has my vote!
J. Maley
2004 Grey Lariat Crew Cab - 6.0L FX4 w/Grey Leather Interior
6" EDGE Suspension Lift
36x14.50x16.75 Interco TrXus STS
16.5x9.75 Weld Mountain Crusher Wheels
Bushwacker OE Fender Flares
Edge Juice Box
Magnaflow Exhaust
Line X Bed Liner
yankspanker is offline
Old 09-19-2005, 11:31 PM   #14 (permalink)
FamilyRide's Avatar
Re: fuel additive
Run it when it gets cold and you'll see a difference. I planned on running it year around but after 2 tanks in warm months (it's hot here) I didn't notice anything noteworthy so I'm waiting for the cold weather again.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 09-20-2005, 12:42 AM   #15 (permalink)
Re: fuel additive
Marvel mystery Oil is no mistery.
It is mineral oil with a wintergreen scent and red dye added.
It might have a little benefit in removing buidup in carbureated gas engines using 1960's fuel standards but won't do one dand blamed thing to improve the cleaning characteristics of of #1 or #2 or especially biodiesel fuel.
It is nothing but snake oil. Just like Motorcraft Cetane Booster and Motorcraft Lubricity Improver. They are nothing more than Kerosene with a little shot of lighter fluid.
Stanadyne's product has a definite blend of ingredients that acomplish what it is labeled for. Unless you use bad fuel regularily of let it set in the tank and system for a whole season you aren't going to need anything most likely.
05 Lariat 4X2 Dualie Powerstroke
telestar is offline
