Power Service Diesel Kleen. Find it cheapest at Walmart. If your winter temperatures are cold enough, switch to Power Service Diesel Supplement in the winter (it has an anti-gelling additive).
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Every gallon of fuel that I have burned has been treated with Power Service Diesel Kleen. Does it make a difference -- from an engineering standpoint the added lubricity and cetane are good for the engine and injectors. The truck has almost 50K miles on it with no fuel related engine problems. It also creates a less hospitable environment for algae to grow in the 105 gallon service tank in the bed of the truck.
I've run Stanadyne until recently when I ran out and bought a couple bottles of the Ford additive from the dealership. Have not noticed a difference btw the two as far as performance or fuel mileage.
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
We have several International trucks with DT 466's and 2 ford 6.0's and since we have been running Stanadyne We have had no fuel related proplems. And my operators can tell a difference in power and fuel economy.
i just went to walmart and once again california pulled it off the shelf erlier this week
Same here in Memphis TN. Went on Diesel Kleen's web site. Found out that it can still be purchased at Tractor Supply Co. Walmart said they temporarily pulled it because of the label not meeting the new ULSD requirements. According to Diesel Kleen, the additive itself is ULSD compliant, it is just the label does not say anything relating to being compliant.
At TSC, I pay the same (give or take 10 cents) as I did at Wally World.
Larry
2006 F350 (Lariat - KR Trim) Crew Cab Dually
6.0L Torque Shift
Tow Command / Tow Boss / Slide In Camper Package
13,000 GVW / 26,000 GCWR
2006 Keystone Everest 345S FW Trailer
We already went through this mickey mouse circus in Texas and my local Walmarts are now again stocking the Diesel Kleen with the new ULSD compliance label. You should have it back on the shelves in the near future.
