fuel filter change - Diesel Forum - TheDieselStop.com
Old 11-16-2009, 10:27 PM   #1 (permalink)
fuel filter change
hey guys quick question i work on some of the larger trucks and when we change the fuel filters we usually add some atf to the filter to clean out the nozzels and keep everything going strong would that be a bad idea on my smaller trucks? i havent done it yet just want your input not sure if it would hurt it because of the tight tollerances these small trucks have thanks!
strokerman11 is offline
Old 11-17-2009, 09:59 AM   #2 (permalink)
teamroper60's Avatar
I would not run it through an HEUI injector.. I know this used to be the practice years ago but HEUI injectors have too tight of tolerances to stand having detergents and things run through them that will reduce the already marginal lubricity of our fuels. Besides, diesel fuel is something of a solvent itself (I have used it to cut tar). If the truck has been properly maintained and you are using a good quality fuel, there should be no need to run any kind of cleaner through an injector.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
