Fuel filter water drain plug allen key stripped. Help! - Diesel Forum - TheDieselStop.com
Old 08-28-2006, 07:43 AM   #1 (permalink)
The "water in fuel" light came on this weekend. I got under the truck to open the drain on the fuel filter only do discover that the allen key hole in the plug is stripped and now I can't get the plug out. I bought the truck in December (used) and never had the plug out.
Anyone have any ideas how to get the plug out without removing the entire filter system from under the truck?
Thanks,
Dave
2004 6.0 PSD CC Lariat FX4, Bulletproof Diesel EGR Cooler upgrade, Scangauge II, High Idle Mod, Tow Package, Air Lift Bags, 2006 Jayco Eagle 325BHS 5th Wheel
KokDiezel is offline
Old 08-28-2006, 08:58 AM   #2 (permalink)
Re: Fuel filter water drain plug allen key stripped. Help!
You can try and drive a flat blade screw driver in there to get enough grip, or try and turn it out by tapping with a hammer and chisel. Next steps would be to drill and use an extractor.
I have a new plug sitting in my toolbox right now from International that is knurled for easier removal. It is going in my next oil change. They say it helps in keeping the fuel from going everywhere also when you remove the factory plug.
Steve
2006 F250 Lariat CC FX4 6.0 PSD Torqshift, Line X, Viper 791XV, IssPro Pyro. Engine Build June 6, 2005. Truck Build June 16, 2005
skroesen is offline
Old 08-28-2006, 09:34 AM   #3 (permalink)
I think Craftsman(Sears) sells a tool to remove stripped screws. It might work on the drain plug. When you get it out get the IH drain plug and your future problems are solved.
sickofford is offline
Old 08-28-2006, 10:13 AM   #4 (permalink)
Thanks all. Where can I find the Int'l drain plug. Any web sites? Anyone have a part #?
Old 08-28-2006, 10:53 AM   #5 (permalink)
Knurled HFCM Plug 2589259C91
If it's worth Shooting, It's worth shooting twice.
Ammo is Cheap... life is EXPENSIVE.
2003 6.0 Crewcab/Auto/Shortbed. AirRaid Intake. Autometer Nexus H2O, Tranny, EGT and Boost Gauges.
BB PIN
32ADB170
LSC_Ya is offline
Old 08-28-2006, 10:56 AM   #6 (permalink)
Who's part number? Ford or Int'l. Thanks
Old 08-28-2006, 11:10 AM   #7 (permalink)
jonrjen's Avatar
As it has been posted many times, most Ford Parts departments will say the number is no good, tell them to cross reference the number with the commercial truck division. The first part that the dept ordered for me was an exact duplicate of the OEM poor design, the second part was the new and improved "Get R Done" design.
Cost was around $13 for the latter greater much improved design.
2008 F-550 Regency Conversion Hauler 6.4 PSD
2006 Ford F-250 XL V-10 6-Speed
2006 Ford F-150 Crew Cab XLT
2005 Lincoln LS Sport
1977 F-600 Cab-Chassis V-8 4-Speed 2 Speed rear
1997 Travel Supreme 40' triple slide 5th wheel
38 +or- head of Texas Longhorn Cattle..."REAL COWS Have HORNS"
jonrjen is offline
Old 08-28-2006, 12:20 PM   #8 (permalink)
I believe that is an IHC part number.
2010 F350 CC, SRW, SWB, 4x4, V-10,Torqshift, 4.10LS, XLT, Bright Red, Med Stone 40/20/40 Pwr Seats, Single CD with Sirius and Sync, Tow Command, Pwr Scope Mirrors, ESOF, FX4, Chrome Tube Steps, Cab Lights, 18" OWL A/T Tires, Forged Aluminum Wheels, Snow Plow Prep Pkg, Reverse Sensors, Advance Security Pkg.
Remote Start, Rhino Liner.
2005 Open Road 357 5th wheel.
Reese 20K Select Series 5th wheel hitch w/ round tube slider.
shark1955 is offline
Old 08-28-2006, 12:24 PM   #9 (permalink)
That is correct. I paid ~$14 for mine at the IH dealer.
Steve
skroesen is offline
Old 08-28-2006, 12:41 PM   #10 (permalink)
Clicky
04 F250 Lariat 6.0l S/C S/B Torqueshift 4x4
XM Radio
MBRP Cool Duals
Isspro Gauge's
scott650 is offline
Old 08-28-2006, 01:04 PM   #11 (permalink)
Clicky
Awesome, thanks. Now I just need to get the old one out..... [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 08-28-2006, 01:56 PM   #12 (permalink)
Dave,
You are probably going to need to drop your front drive shaft to get an easyout or screwdriver in there. If you have a 2wd, you're OK. If the plug is stripped, most just get a new cover or gasket kit, remove the cover plate with the stripped plug. If you've got a new plate, just install it. If you are trying to salvage the old plate, you can now work on it on the bench. Either way, you'll need the new gasket/o-ring.
OMCUSNR is offline
Old 08-28-2006, 03:30 PM   #13 (permalink)
buy a cheap single allen wrench, use a good two part epoxy to "super glue" it into to stripped out plug, let it dry overnight, re-inforce with tape ect if needed, (after obtaining the new improved drain plug) remove and toss both into the garbage! might try JB weld also!
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
My Truck
2004/1997 Powerstroke Pics, Ford 9N Tractor,6.0 Bible
dwelch1 is offline
Old 08-28-2006, 05:44 PM   #14 (permalink)
Heck of an idea! It never ceases to amaze me, the things i pick up here! [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
traildog
Rear main engine seal replaced @ 13,500 miles. Engine pulled for Bed Plate Leak @ 28,500 miles, hasn't leaked a day since (57K now)
2005 F350, 4X4, FX4, DRW, CC, Lariat PKG, Tow Boss, bone stock.
60K oil cooler, egr cooler, degas bottle, hoses.
traildog is offline
Old 08-28-2006, 10:59 PM   #15 (permalink)
if the guy who tried to remove the plug in the first place used the correct metric allen wrench, you wouldn't be going through all this.
why people try force something they are not equiped to do is beyond me...
2005 F-250 4door crew cab 6.0 XLT 4x4
Fx4 Torqueshift [img]/ubbthreads/images/graemlins/laugh.gif[/img]
snoeproe is offline
