Fuel filter water drain plug allen key stripped. Help! - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-28-2006, 11:03 PM   #16 (permalink)
Re: Fuel filter water drain plug allen key stripped. Help!
if the guy who tried to remove the plug in the first place used the correct metric allen wrench, you wouldn't be going through all this.
why people try force something they are not equiped to do is beyond me...
agreeably so the other way sounds like a hack job
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 08-29-2006, 07:12 AM   #17 (permalink)
..says the guy who never had one sieze up on him! Your truck is probably new enough to have come with the steel plug so you won't have problems, but those of us who had the original brass plugs have pretty much all had them strip out by now. I ain't STOOOOOOPID, I know how to read the number "6mm" on the side of a wrench, I know how to keep it square in the hole, how to use gentle pressure, etc. but the third time I went to take the plug out, it was no go. The hole went round and it was all over.
Ford replaced it under warranty, using a steel plug this time around. Check out the archives here, hundreds of people just on this site have had the exact same problem. We're not all just using the incorrect allen wrench.
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
frobozz is offline
Old 08-29-2006, 07:38 AM   #18 (permalink)
I DID use the correct METRIC allen wrench and I'm VERY well equipped to handle such a mundane task. I have more tools in my garage than some mechanics and am very adept at using all of them.
I posted this question besause I am pretty sure that if I had this problem, someone else did too and may have a good solution. As it turns out, I was right. Thanks to the kind people here I've discovered two great ways to remove the old plug and was able to purchase a better plug from Diesel Manor yesterday.
It's not my fault the plug was stuck and the material it is made of is too soft. In case you aren't aware diesel fuel acts like glue on threads and mating surfaces..that's why fuel filters are sometimes tight getting off.
Do you understand where I'm coming from or is it still beyond you.....
2004 6.0 PSD CC Lariat FX4, Bulletproof Diesel EGR Cooler upgrade, Scangauge II, High Idle Mod, Tow Package, Air Lift Bags, 2006 Jayco Eagle 325BHS 5th Wheel
KokDiezel is offline
Old 08-29-2006, 07:42 AM   #19 (permalink)
buy a cheap single allen wrench, use a good two part epoxy to "super glue" it into to stripped out plug, let it dry overnight, re-inforce with tape ect if needed, (after obtaining the new improved drain plug) remove and toss both into the garbage! might try JB weld also!
Genius! That falls into the "why didn't I think of that" category. I will try it as soon as the new plug comes in. If it doesn't work then down comes the front drive shaft.
Thanks to all for the great info!![img]/ubbthreads/images/graemlins/grin.gif[/img]
Dave
Old 08-29-2006, 11:32 AM   #20 (permalink)
Hit it with carb clean before you glue it to degrease the plug.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, 200 amp large frame alternator replacement, 2 batteries; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors and replaced brake pads for 1st time 1/7/12 101K miles
Ford06 is offline
