Fuel injector cleaning - Diesel Forum - TheDieselStop.com
Old 08-24-2006, 02:59 PM   #1 (permalink)
I have a 2005 F250 6.0 and I was told that the reason my engine doesn't start immediatly is because the injectors need to be cleanes. The truck has 32000k. I got some fuel injector cleaner from Napa, and no difference, so the next tank I tried Sea Foam, no difference. Can someone tell me what I should use or do? Thanks
stumble97 is offline
Old 08-24-2006, 03:20 PM   #2 (permalink)
Send a message via ICQ to agdodge4x4
Re: Fuel injector cleaning
The reason it doesnt start immediately is because there is no oil pressure to fire the injectors. There is nothing wrong with your truck.
Jason
Texas A&M University
Class of 2002
2005 F-250 4x4 (FX4), Lariat Arizona Beige/Black two-tone, 5 spd Auto, 6.0L.
agdodge4x4 is offline
Old 08-24-2006, 03:44 PM   #3 (permalink)
i would also be VERY leary of putting anything through the fuel system. i imagine the injector "cleaner" was made for a diesel right? not a normal gas injector right?
2003 6.0 Ext cab FX4 loaded XLT
March 03 build with 57,000 trouble free miles (so far)
4" turbo back SS MBRP (ohhh that whistle!), RSX3.5 alarm
8" Superlift with Bilsteins
37" Nitto Mud Grapplers on 17x10 Mazzi Hulk rims
weraracer is offline
Old 08-24-2006, 03:58 PM   #4 (permalink)
The injectors require high pressure oil generated from the high pressure oil pump before they will inject fuel into the combustion chamber. It may take several seconds after the engine starts to crank before the oil in the high pressure oil system builds up to allow the injectors to inject fuel.
04/04 F250 6.0L Torqshift CC SB FX4
Turbo Cooldown Timer
Diamondback bed cover
Manual idle-up switch
(placing power onto PCM PTO wire)
Fumoto valve
Skweeker is offline
Old 08-24-2006, 04:54 PM   #5 (permalink)
Welcome to TDS -
Now the bad news. If you used "sea foam" in your diesel truck, you have probably caused damage to all the injectors. Do not use ANY additive to your fuel that contains alcohol, or is made for gasoline injectors. The alcohol will attract water to it which will make it past the HFCOM, and to the high pressure injectors where it will flash into high pressure steam. This will toast your injectors in a VERY short time.
OMCUSNR is offline
Old 08-24-2006, 04:55 PM   #6 (permalink)
beachbumcook's Avatar
Could be the following as well... may not be injector problem!!
1) Clogged or clogging fuel filters (one or both) - low fuel pressure.
2) If fuel filters were recently changed, the cap may be loose and allowing air to enter the fuel system... once air is purged, it starts.
3) Was the oil filter recently changed? If it was overtightened it could have a crack... if the wrong filter was used or did not seat properly, it may be allowing oil to drain out of the oil filter canister... which delays oil pressure to build and fire injectors. Some have commented that some WIX/NAPA oil filters have caused a "drain-back" issue.
Do any of these things sound like they mey be a contributor?
03 Excursion 6.0L PSD - 4X4 Limited
Pioneer Airware XM2GO Statelite Radio
Racor By-Pass Oil Filter
Magnefine P/S Fluid Filter
Dieselsite Coolant Filter
Fumoto Oil Drain Valve/Plug
Marinco AC Block Heater Plug Mod.
Bilstein Shocks
Rancho Steering Stabilizer
Brite Box Headlight Module
24" Wiper Blades
beachbumcook is offline
