Fuel Injector Control Module (FICM) - Diesel Forum - TheDieselStop.com
Old 08-30-2009, 08:51 PM   #1 (permalink)
Received code P0611 today. Found out what it was ( Fuel Injector Control Module) (FICM). Truck has 90432 miles on it . Was wondering if it was covered under the 100000 warranty? Just replaced both batteries and alternator within the last month.Any thoughts about why this code keeps coming back?
2005 F250 Fx4
First Diesel And Loving It
bpathfinder is offline
Old 08-30-2009, 09:03 PM   #2 (permalink)
Yor FICM works hard to amplify the system voltage from 12V to 48V. If you operate with bad batteries and/or charging system, then you can ruin your FICM. It is under your 100k 5yr warranty. I believe it is even under your emissions warranty - so ZERO deductible.
Under emissions warranty, you will not be charged for labor, diagnosis, or parts for any emissions control device or system for 100k (ie no $100 deductible):
Air flow sensor
Air Fuel Feedback control System and sensors
Cold start enrichment system
Electronic engine control sensors and switches
EGR system
Exhaust manifold
Fuel Injection System
Intercooler Assembly - Engine Charger
Power Train Control Module
Turbocharger Assembly
Also covered by the two emissions warranties (Emissions defect warranty and Emissions performance warranty):
All emisssions-related bulbs, hoses, brackets, tubes, gaskets, seals, belts, connectors, non-diesel fuel lines and wiring harnesses that are used with components on the list above.
Mark
bismic is online now
Old 08-30-2009, 09:34 PM   #3 (permalink)
rock_doctor's Avatar
...although, the dealer will insist on the $100 anyway like mine did... A bad FICM seems to generally follow a bad set of batteries or a bad alternator. Thing is way to fragile...
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 08-30-2009, 09:53 PM   #4 (permalink)
This happens way too often. I admit that the language in the warranty manual is a little vague, but it is worth making the dealership call Ford - while you are there listening to the call. The intent from Ford was zero deductible. It seems like many (maybe even most) dealerships avoid this topic and take the $100 ........... disappointing.
Basically the manual says you will not be charged! If you are not charged, then how can there be a deductible??
Mark
Old 09-04-2009, 10:09 AM   #5 (permalink)
Took it in this morning had it checked they pulled same code I did. They said Ford makes them reprogram the (FICM) and try it again. Same thing again, it was bad. Put new one on and it was covered under the emissions warranty, so I got lucky and did not have to pay a deductible.
2005 F250 Fx4
Old 09-04-2009, 10:24 AM   #6 (permalink)
Roosterq's Avatar
That's nice. I'm glad to hear that you didn't have to pay the $100. I like to think there are some good guys out there intending to do the right thing.
2006 F350 SD Crew 6.0 stock, except I did add floormats.
Roosterq is offline
Old 09-04-2009, 12:33 PM   #7 (permalink)
Truck11's Avatar
My Photos: (6)
Must be nice to still have a warrenty. I just had to fix mine out of pocket. $910.
2005 CTD, BD tranny, bully dog outlook, muffler delete
SOLD-04 F-250 PSD AEM intake, Muffler Delete, gauges, LOTS OF PROBLEMS
Truck11 is offline
Old 09-04-2009, 04:45 PM   #8 (permalink)
fantastic! Did they volunteer the "no-deductible" or did you have to remind them?
Mark
Old 09-04-2009, 05:10 PM   #9 (permalink)
InetDev's Avatar
Wow. I just paid $550 for my reman FICM at the dealership plus $170 to relash it. Out of pocket.
2005 F350 turbo diesel Lariat 4x4 ext cab, short bed, SCT x2, MBRP turbo back, WeatherGuard box, the "beagle hauler".
1965 Factory Five Spyder GT, the 2nd one built out of 39 total. No top, no windows, no radio, no mufflers. Yeah, it's sweet.
InetDev is offline
Old 09-04-2009, 06:59 PM   #10 (permalink)
He told me he ran my vin number and it was covered under emission warranty. I did not have to ask about it. All I had to do was sign the paper work. These should already programmed when you buy it right?
2005 F250 Fx4
Old 09-04-2009, 11:32 PM   #11 (permalink)
InetDev's Avatar
Nope, has to be programmed when installed in the vehicle.
InetDev is offline
Old 09-05-2009, 03:31 PM   #12 (permalink)
Just had a similar alternator diagnosis with my truck from the dealer. I have been experiencing surging idle and engine stalls on a couple occasions. 1st time (about a month ago) dealer advised on "excessive carbon build-up". They did a repair, labor cost was: $1400. ESP plan covered major parts (turbo rebuild, EGR, etc.) but not labor. Next day lost turbo boost EBP sensor failed, dealer repaired. Last Wednsday, again surging idle and engine stall. The new diagnosis revealed alternator has intermitten voltage drop which inturn affects the FICM signals, thus the surging and stalling (according to them). My point is, I brought to their attention (the dealer) FICM wiring harness issues that surfaced early in 2005 and pressed the issue with them to run an OASIS report on my truck (no recall campaign was present). I feel that prompted them to take a better look at my electrical system. Why didn't they do a more thorough check the first time. Now again I must pay a $50 deductible and wait a few days to get the truck back. There are 2 additional issues they are also repairing a leaking oil bypass or turbo oil line (they refer to it as a turbo duct connection) and the MASS air plastic conduit which both were damaged when re-installed incorrectly during the first repair a month ago. Just thought I would share this little adventure with you all...
2004 F250 Lariat XLT S/D 6.0L C/C L/B FX4, White exterior with Gray leather interior. Mainly stock except for some cosmetics. Warn Transformer Grill/Brush Guard with receiver winch mount, Northern Tools polished diamond plated tool box. Factory Ford splash guards and chrome step bars. Extang Tonneau bed cover, fumoto valve and finally air horns. Truck was ordered with all the goodies except moon roof.
crusincrew is offline
Old 09-07-2009, 07:23 AM   #13 (permalink)
Where can I buy one without having to buy it from the dealer? Dealer wants around $700.00 for it.
2005 F250 Fx4
Old 09-07-2009, 07:34 AM   #14 (permalink)
The International dealership is cheaper than Ford. I have seen some on Ebay.
Mark
Old 09-07-2009, 03:24 PM   #15 (permalink)
InetDev's Avatar
Ask the dealer for the re-manufactured one to save money, that's how I bought mine last Friday. It was a little over $500 plus $100 core. International didn't have one. Be wary of the ones on eBay as they may be untested.
InetDev is offline
