Old 09-07-2009, 06:37 PM   #16 (permalink)
I just paid $1058.00 for a FICM and programing.
I noticed that when I put my meater on the battery it don't start charging right away.
it takes a few seconds after the truck starts.
but then it goes up to 13.6 v. could my altanator be going bad and if so would that have shown up when they checked the FICM
21xdbullet is online now
Old 09-07-2009, 07:33 PM   #17 (permalink)
69cj's Avatar
Glow plugs pull current for a minute or two and then the voltage will climb. 13.6 to 14.5 is normal.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 10-29-2009, 02:27 PM   #18 (permalink)
I wonder
Originally Posted by rock_doctor View Post
...although, the dealer will insist on the $100 anyway like mine did... A bad FICM seems to generally follow a bad set of batteries or a bad alternator. Thing is way to fragile...
I just replaced my alternator with a NAPA lifetime guaranteed unit, 3 months later, it went out again and was replaced last week, under the parts warranty. Now the truck is in the shop getting the FICM replaced. Is there any way to prove the alternator caused the outage? Any chance of getting NAPA to pay the FICM bill?
DupuyDog is offline
Old 10-29-2009, 03:53 PM   #19 (permalink)
Strokin' 6.0's Avatar
FWIW, and this is direct from my stealership, there are NO new FICMs, they are all reman'd units....some might just look newer than others.
International will not sell you a FICM, if they know you're buying it for a Ford...at least the International shop here in town won't.
SFC Fred Lynes
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch Package
Herrin Hauler Package
5R110 Torqshift
4.10:1 Dana 80 Trac-Lok
9,200lbs GVW
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Wishin' I still had my '05 2500HD CTD Ram
Strokin' 6.0 is offline
Old 10-29-2009, 04:55 PM   #20 (permalink)
dikkstarr's Avatar
Why such a swing in prices then? Mine cost me 1400, and the dealer said it was a new one, my invoice didnt say reman FICM. A reman is new internals with the old shell or casing, like trannies or alternators?
I wonder what part of it breaks and what they do to fix it? So it will just break the same way again in the future? Whatever goes bad inside them.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38s on 17 10s, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
Old 10-29-2009, 10:05 PM   #21 (permalink)
Same here DK...I got hosed for $1400 last month for a FICM. $700-$900 sounds like a steal compared to what we paid.
bulletbob is online now
Old 10-31-2009, 01:27 PM   #22 (permalink)
I was told that the VIN determines the price....crock of crap. I think the stealerships charge what they think they can get away with.
My indy mech tells me that heat is the killer of FICMs, which makes sense, if you think about where it's located. Engine heat, turbo heat and coolant heat are a recipe for disaster. It's not if your FICM is going to give up the ghost, it's when. If there are circuit boards in the FICM, which I'm pretty sure there are, then it's a sure thing that the heat will crystaline the solder, fry a diode, etc.
I personally would love to find a new place to mount the damned thing, but the biggest problem I see with that is getting a harness extension. The next viable solution is to duct cold air straight to the FICM.
SFC Fred Lynes
King Ranch Package
5R110 Torqshift
9,200lbs GVW
Old 11-01-2009, 03:22 PM   #23 (permalink)
Here is an interesting post on testing your FICM.
http://*****************.com/forums/######.php?t=43705
In place of the *'s, enter as one word "powerstroke nation" (without the quotes).
Also, in place of the #'s, enter "showthread".
SWAMP also says he can repair them cheaper than the replacement cost ($350):
Swamp's Diesel Performance
Mark
'06 F250, CC SB ESOF FX4 Lariat 3.73LS, 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; Racor CCV filter
Fumoto valve; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; Britebox; DashDAQ
Quadzilla recon XZT Fuel Pressure; BB mod
Synchromax in transfer case; Reflashed
Line-X, CPOhighway Prod. tool box; tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
Updated EGR valve; PIE adapter; 24" wiper blades
bismic is online now
Old 11-01-2009, 04:00 PM   #24 (permalink)
F250crazy's Avatar
Link not working for me.
F250crazy is offline
Old 11-01-2009, 09:26 PM   #25 (permalink)
fxdwgi's Avatar
Even if you buy one off of Ebay or somewhere else, you still have to have a PMI (Programmable Module Installation) done at the dealer. It consists of remove your program off your old FICM and installing it on your new one. If that doesn't work then the dealer needs to load as-built data from Ford into the module, if it will take it.
A new FICM comes without a program in it.
Also, heat is not the enemy of the FICM, unstable input voltage is (bad battery, alternator, jump starting a crane etc. You get the idea)
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Front Bull Bar w/ K.C. Daylighters * Draw Tite Fold Over Gooseneck * Gauges whited out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM *
Sitting in garage waiting to install: 6.0 IC
The REAL toy....
http://community.webshots.com/album/561972003NGydsT
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 11-01-2009, 09:46 PM   #26 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
swamps diesel. the original post was from powerstroke nation. it gives a great post on diagnotics for a bad ficm. and heat is not the main killer. it is the heat flash that would pump out 48 volts for up to 2or 3 minutes that caused the boards to overheat since they were designed for short bursts not long ones. swamps also offers a upgrade to up the voltage to 58 volts which is a popular mod on the older 7.3 idms that helps with starting and idling. very good post that all should read.
2004 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
sct x2 with custom tunes
315/75/r16 bfg km
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 11-01-2009, 10:41 PM   #27 (permalink)
Originally Posted by fxdwgi View Post
...Also, heat is not the enemy of the FICM, unstable input voltage is (bad battery, alternator, jump starting a crane etc. You get the idea)
While I agree with you about unstable input voltage, I respectfully disagree with you about heat. Heat will crystaline and crack solder....crack the solder and you get bad or no electrical connection. A good example of this is the UniVolt converter in an Airstream travel trailer (ask me how I know), and there is less heat generated by the UniVolt than there is by the turbo, degas bottle and engine of a 6.0.
The heat that comes from the area where the FICM is located will eventually be responsible for or help cause failure. No electrical component can survive that much heat for thousands or tens of thousands of miles, whether it be constant-driven or not.
I submit that the two (electrical and heat) are both culprits.
on edit: I read the Swamps article, Lubbock...good read. The one question I had was why bump up to 58v...thanks for the answer.
By the way, I never said it was the main reason, just one, as explained to me by my mech who's been doing this for a few decades.
SFC Fred Lynes
King Ranch Package
5R110 Torqshift
9,200lbs GVW
Old 11-02-2009, 08:26 AM   #28 (permalink)
I looked at that site and could not find any info on FICM repair - where should I be looking?
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
Old 11-02-2009, 01:59 PM   #29 (permalink)
Email him most likely. He said he offers rebuilding but it is like a week turn around time.
2004 f250 4x4
crewcab short bed
lariat 6.0psd
315/75/r16 bfg km
else
Old 11-02-2009, 04:38 PM   #30 (permalink)
Wouldn't bumping the FICM up to 58v fry it quicker?
SFC Fred Lynes
King Ranch Package
5R110 Torqshift
9,200lbs GVW
