Fuel lubrication additives----- What are you using?
So, what are you using to add to the ULSD to help with lubricity? And where is the best price to get it?
Thanks for your help!!!
2003 F250, ex cab, short bed, 4X4, 6.0 Torque shift. 12/02 build date. currently 57k on the OD. Original injectors, 2nd turbo, Air Raid Intake, Magnaflow turbo back, triple pod ultra light gauges, rhino lined.
94 Ranger "Black STX" 7" lift, 35" BFG MT's. 4.56's, Locked F+R, Caged, winch, Onboard Air, to much to list
Re: Fuel lubrication additives----- What are you using?
Stanadyne just released a new formulation for ULSD. I've been using the old formula (which you can't get anymore) since day one. I just started using the new stuff a couple weeks ago. Don't know what the difference between to old and new, but I'll bet they had to take out and/or replace something so the new PM filter won't blow up.
I buy the 1/2-gallon jug from Diesel Injection Service for about $20 + shipping.
My html Version of the 6.0L Bible Now with 2005 Updates $5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
BlackSTX,
We stock all the Stanadyne products in 16 OZ and 1/2 gallon sizes. Call us if you have any questions. By the way the Performance formula and JR formula do have some lubricity properties and all their products are now ULSD formulated. Plus Stanadyne is OEM approved too, don't think any of the competition is?? If you buy some places you might still get some of the old non ULSD formula, FYI.
I buy Power Service in the big jug from WallyWorld(though the price for the big jug has risen recently, $4 more I think), gray or white bottle, not sure which color for cold weather. I have to read the bottle. Add the stuff every fill up, probably add too much, truck runs great, starts right up every time. Might start up and run just as well with the stuff, but if it helps an injector last longer, money well spent. Stuff sure stinks though, awful if it gets on your hands. I am sure the other brands work well, Power Service is sitting right there on the shell, short walk from the toilet paper aisle.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
Sea Ray 240 Sundeck http://community.webshots.com/user/C...host=community
Marvel Mystery Oil
2005 F-350 LARIAT 6.0 PSD SRW AUTO FX4 (removed) CC SB White, International emblems, Tow Command, Upfitters, Line-X, ScanGauge, Pioneer Appradio, Banks Technicooler and intake w/Zoodad, Dieselsite coolant filter (w/RMI-25), braided 4x4 lines, Mag-Hytec trans pan & diff covers, Fumoto oil valve (Motorcraft 15W-40), Knurled HFCM drain plug, Britebox, EZ-Down tailgate, BedStep, MBRP 5" cat-back (6" tip), Putnam class V hitch with 1upUSA bike rack, TransferFlow 30 gal toolbox tank + 46 gal midship tank = 76 gals total with Stanadyne Performance additive and FPPF cetane improver... the rest is all stock you nig-nogs. 64k miles, 1600+ hours.
Waiting for "BigTurbo" to help me install: Dieselsite Trans filter kit.
Stanadyne for me too, but lately I've been using the Ford additive as I too am waiting on DIS to get restocked.
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
I use power service as well. White is for winter, grey for summer. Only difference I believe is an anti-gelling agent.
Does anyone know if power service will be refining their additive for USLD?
2003 350 Lariat FX4 Short Box 6.0L *SOLD*
2008 FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
2007 Keystone Raptor 3712TS PICTURES
I also use Power Service. I use the white bottle year round. For me its just easier than switching back and forth, plus I get a better deal on the white bottle.
As far as I have been told Power Service products are already compliant with ULSD. There website confirms this.
__________________ '04 F-250 Harley-Davidson 6.0L CC SB
howes diesel additive here.. made localy
early 99 F250 cc 4x4 auto.. gages on the pillar, tymar intake, 5" MBRP exhaust, dp tunner 60,80,120, 30 gallon gravity feed aux. fuel tank, putco chrome on all handles and mirrors, GOS racing headlight harness, clear headlight and corners, accetone badges, blue ovals pelled, zoodad mod
First post, been reading for quite some time, decided to join up to chime in here.
When I first saw this thread I figured someone would bring up BioDiesel. Since I haven't been real happy with how ULSD runs in my truck, my plan was to keep a 5 gallon can in back of the truck, fill it with B99 and every time I have to fill up with ULSD add about a gallon of B99.
Hopefully at some point soon more stations around here will have the various blends and I won't have to go so far out of my way to get it.
FYI, Stanadyne is made in CT.
And 1 more vote for it. Been using it since 9/00 and 0 problems or gel issues.
Mike
2004 F350 SC Lariat "CX" SB swr 6.0 auto loaded ordered 12/22 built 2/2/04 So far So good!
DR leveling & adj track bar, Bilsteins, heated signals,XM, Retraxx,Line-X.
2001 Excursion LTD "FU" PSD 4x4 L/S EBM 3 B&B SS exh. XM. "U" codes,4" blocks, Bilsteins,285 Nitto's.
2000 FLHTCUI sin blue
1996 WX3 in BBB
