Re: Fuel lubrication additives----- What are you using?
Tried them all recently and really don't see any difference, they even smell the same. The Ford product looks the thinnest. Of course it really doesn't get as cold here as it does in other parts of the country and so far my fuel has been good. I will say that Power Service is by far the most readily available. I have had Standayne on backorder through ShopDiesel for a month now, I may just have to cancel that order and move on.
2006 Ford F250 XLT 4x4 Super Cab Short Bed
6.0L PSD w/Torqshift Transmission
Shell Rotella 15W-40 Engine Oil
Built July 2005
With a 6 - 8 week delivery, DIS should be able to deliver its winter formula by spring!
Hmmm.... That's interesting. I ordered some two weeks ago and the guy in the Brown van dropped it off a week later.
If 6 to 8 weeks in too long, could you please enlighten the rest of us where we can get some sooner?
My html Version of the 6.0L Bible Now with 2005 Updates $5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
I have used Redline a couple of times and it did do what it supposed to do.I only put it in when ever I remeber to gets some or have the extra green backs.
2004 F-250 (FX4) 4x4 XLT Crew Cab Short Box with a "6.0L Powerstroke Turbo Diesel".All stock.
The Difference between men and boy's are the size of there toys.
My Daily Driver is a 99 Nissan Altima 4 door.
Which stanadyne product are you guys using? I'm interested in something to make up for the lower lubricity of the USLD and wondered whether performance formula covers that as well as the cetane, or if you would have to use the lubricity formula to get good protection?
Right now I'm running power service since I could get it locally. I don't have any complaints so far, but figure if the stanadyne is oem approved I ought to give it a try. Need to figure out which one to use.
06 F350XL rc,lb,manual 4x4, 6.0 PSD, 6 speed
Upfitter Switches
BCP Idle Control
55 watt halogen back up lights (4)
200 psi 5 gallon air system
Diesel Site Coolant Filter
HELLA FF50 Fog Lights
Custom Headache Rack
Custom Shovel Rack
Weatherguard Saddle Box
Weathergaurd Wheel Well Box
Herculiner wheel wells and rocker panels
Edge Insight with EGT and Fuel Pressure
Matt_Shade,
Stanadyne has a Performance formula that has lubricity and cetane improvement as well as s Performance JR that has no cetane changes but does have lubricity add packs. Then they have a lubricity only formula and a winter blend as well. Most folks get the Performance formula as it has cetane and lubricity properties. We have all of them sitting here avaialble to be shipped at any time, no wait time and such etc!!
By the way we are LOOOOTs less costly than the link that was posted aboev too!
Plus Stanadyne is OEM approved too, don't think any of the competition is??
What exactly does this mean? If I'm not mistaken Ford oil is OEM approved, but I wouldn't use it and does that mean I couldn't use it in a dodge or chevy. I guess what I'm asking is how does a manufacturer get that OEM endorsement. Is it actually decided through extensive testing by Ford or is the approval given by Ford after each additive manufacturer supplies an internal report. The reason I ask is because if you line up brochures from all the top additives, they all have the #1 product. I owned a Dodge before and actually used there OEM approved additive and still had both pumps replace twice before 100k. I spoke with a guy at the diesel pump the other day and he swore by his additive of choice, tranny fluid. 1/2 quart in each tank. Don't get the wrong idea here. I use my additive of choice and I guess it works. But I don't honestly know, it just became a ritual, I guess.
2005 Ford Excursion 6.0 PSD
Arnott airbag kit
You dont need any. ULSD is supposed to have them in it already and meet standards for older engines.
[img]/ubbthreads/images/graemlins/laugh.gif[/img] 2004 / 04 F350 CC PSD 4x4 Chestnut Brown King Ranch, Quad Captains, DUALLY [img]/ubbthreads/images/graemlins/laugh.gif[/img], long bed, auto, 4:10LS
Goodies added.
Retrax bed cover [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Reese bed rails, bolt on frame install kit
Viair 550C air compressor and 2.5 gal tank
Grover 34 and 36 inch air horns
Pro Flap mud flaps
Autometer cobalt gauges with under cubby pod
Galaxy 95T CB, Wilson 5000 roof mount antenna
DPPI Cat Back Dual Exhaust [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
I have been using power service.I run the white bottle in winter and grey in the summer. I have been draining the HFCM and have yet to see any water.They claim it is a great product for lubrication,cetene boost,prevents gelling. 32oz treats 100 gallons.Cheap insurance I guess and peace of mind.I can't say I see any milage gains but a friend of mine swears by this stuff.I bet all these products are similar
Thanks for all the great info guys!!
I have been using power service and it seems to be working well.
I have become more concerned with this recently with the last tank of LSD being about 4 tanks ago, and immediately noticing my fuel pump being louder after running some ULSD in the engine. So just trying to find some products to help minimize any affects ULSD my have on my engine.
As we all know 6.0's need all the help they can get [img]/ubbthreads/images/graemlins/grin.gif[/img]
2003 F250, ex cab, short bed, 4X4, 6.0 Torque shift. 12/02 build date. currently 57k on the OD. Original injectors, 2nd turbo, Air Raid Intake, Magnaflow turbo back, triple pod ultra light gauges, rhino lined.
94 Ranger "Black STX" 7" lift, 35" BFG MT's. 4.56's, Locked F+R, Caged, winch, Onboard Air, to much to list
11% biodiesel. Excellent lubricity and it's included in every fill up where I'm at.
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
Powerservice and Fords additive.Honestly the Tk actually seems to run a bit better with Fords stuff [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img].Go figure.I get a Heck of deal on it though
I haven't been using any additive in my new truck...is this bad???
2007 FORD F-350SD 6.0L POWERSTROKE,Black,4x4,Fx4,Auto,Lariat,CC,SB,156 in.wb. tow command,upfitters,power moonroof and slider,backup sensors,chrome package,6 disk in-dash changer,heated leather,20inch polished forged wheels,completely stock except for Limo tints,rainguards and Rotella T 5w40 synthetic.
1999 Ford mustang cobra/procharged/heavily modified
1987 Ford mustang GT/many mods,project car
2004 F-350 6.0TD/xlt/4x4/Auto/supercab(traded-in)
Ford doesn't require the use of any additive. I am running my truck without it. If I start to have multiple problems, I will chalk it up to design problems with Ford and look elsewhere next time..
In my gasoline cars I don't buy expensive grades of gas--it is just money down the drain. I will bet and hope with the Ford it is a waste as well.
With my VW and Nissan diesels I racked up many a mile and never had any problems running without additives...
Truck Build Date: 03/05 Kentucky
Engine Build Date: 02/28/05 Indianopolis
Purchase Date: 8/05 Sold date: 01/31/07
MPG: 16.08 2007 ytd average; 29k miles
2005 F 250 PSD Crew Cab Long Bed XL Auto
Completely Stock Truck: No Modifications
15 days in shop; a factor in deciding to sell.
