I see a similar thing, but its not exactly the ambient temp. It is due to the amount of time it takes to warm up the diesel. And in the afternoon the engine still has some heat in it from the morning run, and the air is warmer so it warms up quicker.
Using the ScanGuage I can see the mileage on the fly. After warmup, ambient temps do not affect mileage enough to notice. But, boy that cold engine uses alot of fuel.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
