fuel in motor oil? - Diesel Forum - TheDieselStop.com
Old 08-26-2006, 05:19 PM   #1 (permalink)
rcarroll's Avatar
fuel in motor oil?
Hello, this is my first post on this site there is alot of helpful info. on here. Anyways I purched a 6.0 in April it now has around 5500 miles on it. Yesterday I checked the oil and it was about 2 Qts. over full and smelled like diesel. The break in oil was changed at 3000 miles and replaced with Rotella T 15-40. I understand that this most is likeally an injector leaking. Has anyone else had this problem with the 6.0.
My other question is I installed a MBRP ehaust turbo back I have the cat in place but no muffler will ford void my warrenty or not work on my truck because of the aftermarket exhaust.
2006 F-350 XLT 4X4 ,SRW, 6.0 diesel, SC, LB, Red, 6 Speed, manual hubs, 3.73 limited slip, Snowplow package,Camper Package, Added upfitter switches,Edge CTS With EGT and fuel psi, SCT Xcal 3 tuned by Innovative, ARP Studs, South Bend Clutch , Huskey liners, MBRP exhaust, B&W gooseneck, Wet Okole seat covers, 35x12.50 Toyo M/T
rcarroll is offline
Old 08-26-2006, 06:40 PM   #2 (permalink)
Re: fuel in motor oil?
depends on your dealer? hopefully you have a diesel tech that you know. Ford is getting really annoying with the excuses to drop warranties. Hope it works out for you, have them hook up the IDS and test the injectors
gsosuperduty is offline
Old 08-26-2006, 08:30 PM   #3 (permalink)
Yes: They bought back my first truck because of this. You probabily have a bad injector. The early 03 had c-94 injectors witch were pron to have bad o rings. I don't know about 06's. I would not drive it(other than to the dealership). Play it save get it returned to stock first. ford is voiding warrenties left and right for modifications. They void it and the fight is on.
21999 F 350 super duty 7.3 Lariet 2wd srw white 78000 miles when sold. Very minor warrenty work. Used mainly for heavy towing
2003 F 350 Crew cab 6.0 Lariet. 2wd srw Arizon beige,Clearence lights,Adj Pedals,Heated Mirrors
Ordered 10/01/2002
Build date 1/20/2003
Dilvered date 2/14/2003
Dead and to the graveyard 4/15/2003 with 2700 miles
2003 F 350 crew cab 6.0 lariet 2wd srw Arizona beige,clearence lights,adj pedals,heated mirrors
Ordered April 22
Build date may 5
Delivered may 24
Towing 2001 36 foot coachmen 5th wheel prospera
Sold
Now towing a 36 foot carrige Carri lite 16k
5,2003. Towing 36 foot Carri-lite with 3 slides
jmurray3612 is offline
Old 08-26-2006, 08:57 PM   #4 (permalink)
Who changed the oil? If you did was 15 Qts put in? 15 Qts will show at the top or slightly above the top of the bulb on the dip stick. Also, I am not sure how you would accurately judge having 2 Qts to much with a 6.0 L dip stick. Also, remember that the truck must be on level ground or you will get an inaccurate reading.
RoyC
2005 Limited, 6.0L PSD, 4X2, Mineral Gray, 3.73 LS. Excursion Build date 02-08-05 6.0L 2005MY Engine Build date 01-03-05 Huntsville, Ala.
2005 50th anniversary Thunderbird Red with all
options except hardtop.
Old Ride: 2003 Excursion 6.0 L March 2003 Build 73,000 with no significant issues.
RoyC is offline
Old 08-26-2006, 10:53 PM   #5 (permalink)
FamilyRide's Avatar
Ditto on how did you measure 2 quarts high, and how much was put back in. I've never put more than 13 qt's back in and that puts it in the upper end of the hash marks.
Next, where have you been? [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Search back in '03 and '04 on fuel in oil. Major issue with some '03 trucks. It's an automotive legend now. [img]/ubbthreads/images/graemlins/wink.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 08-27-2006, 09:25 AM   #6 (permalink)
rcarroll's Avatar
I changed the oil myself, I putt 14 qts. back in this putt the oil level about 3/4 of the way up betweem the lines. Now the oil is up on the wire. 2 qts. a guess it could be a little more or a little less.
Do you think it would be worth the work to change the ehaust and downpipe back to stock. Thanks for all your help!
rcarroll is offline
Old 08-27-2006, 01:31 PM   #7 (permalink)
FamilyRide's Avatar
It would be humorous to see a dealer deny a warranty claim regarding fuel dumping into the crank case based on an exhaust system. If you were running it straight off the DP, they'd still put on quite the comedy act saying it was causing fuel dumping. And it does sound like an injector issue if indeed you checked the oil properly and it has indeed grown diesel fuel. I think it would be pretty obvious and it sounds like you have it pegged.
A dealer/Ford can't "void" a warranty. They "can" deny a warranty claim if they believe it's not something they are obligated to cover due to modification etc. etc.
If you were going in with drivability issues related to EGR, VGT, EP etc., an aftermarket exhaust that affects exhaust pressure would be more understandable, although quite the long shot on their part.
Old 08-27-2006, 06:34 PM   #8 (permalink)
Just to be sure there is fuel in your oil, draw a sample and send it in for a used oil analysis. I use Blackstone Labs, and there are several others that are good. That will give you the data to back up your claims and make it harder for Ford to ignore the concern.
My wife's 2004 regularly has 2% fuel in the oil. The dealer claims this is normal and within specifications. The oil level never goes above full, so I suspect the fuel is exactly replacing the oil consumed during operation.
Joshua
CoralDoc is offline
Old 08-28-2006, 02:34 PM   #9 (permalink)
I just had an injector replaced a few months ago, didn't say anything about my exhaust or intake. But then my dealership knows that the exhaust didn't screw up the injector! My exhaust system "could" legitimately be voided..........but really there would be no need for warranty work on my OEM exhaust...there is nothing wrong with it....setting in my garage, it's like, like brand new! [img]/ubbthreads/images/graemlins/grin.gif[/img]
_________________________________
The above information may be speculative, based on misinformation, contain inaccurate data or could be entirely tongue-in-cheek, depending on how litigious the reader may be, how much liquor I've consumed, the degree of stupidity and/or gullibility exhibited by any poster/reader I may respond to. Your mileage may vary. All civil rights reserved. LET'SROLL! 03 F-350 6.0 PSD, XLT, 4x4, CC, auto, skull billet grill, nurf bars, 4" lift, BFG 37x12.50R17, 8.5" Weld Wheels, tonue cover, keyless entry, supersonic alarm, painted bumpers, rear sensing, privacy glass, rear slide window, power everything, drive shaft red, 3.73 gears, camper/tow, block heater, Pro-Guard 7 intake, DPPI exhaust-no cat, Built: 1-13-03 Bought:4-11-03 Flash-06E17 7-5-06 [image] http://photos.thedieselstop.com/show...Truck_350_side [image]
njmjc is offline
