Fuel Pressue question - Diesel Forum - TheDieselStop.com
Old 11-09-2009, 07:31 PM   #1 (permalink)
Fuel Pressure question
I am looking to do a fuel pressure test. My truck has loss of power upon start up and when climbing hills in some cases (does not happen all the time) It has been getting worse. Ford replaced the FICM...still did not do the trick. EGR was also replaced. I am thinking that the fuel pump might be going. Any ideas as to how I can do so without taking it to Ford for a $250 test. Do they sell fuel test guages for not an arm and a leg? I can get a fuel pump for under $300. Would it just be a smart idea to just replace it
05 F350 CC Long Box 87K stock
Any suggestions would be much appriciated.
Mike821 is offline
Old 11-09-2009, 07:43 PM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
There is a pressure test port on the upper fuel filter housing. You will need an adapter and a gauge to do the check.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 11-09-2009, 07:49 PM   #3 (permalink)
Thanks HeavyAssault.....do I have to drop $200 on a basic kit or do they make a $40 dollar unit like they make for cars? Pep Boys here in NJ said they have one for $41. I am gunshy trusting that info...the kid looked not a day over 17 years old. Any suggestions for a guage? Do I need to test on the road or can I just start up and monitor the pressure while under the hood?
Mike821 is offline
Old 11-09-2009, 08:00 PM   #4 (permalink)
My Photos: (6)
Keeping the line clear of any edges or rotating objects you should be able to use any gauge kit. It needs to read over 60PSI and DO NOT run a line of fuel into the cab.
Old 11-09-2009, 08:54 PM   #5 (permalink)
If the truck is only acting up under heavy load then that's when you should be monitoring the fuel Psi . I use a Pressure Transducer from snapon that plugs into a graphing volt meter . This way no fuel lines are in the cab and Yes they are Very Expensive. I'm drawing a blank on the fuel psi spec but i think they shouldn't go under 48 psi under full load. Maybe someone can help us out here with a wide open throttle fuel psi spec . I think at idle its around 55 psi. Good Luck .
Winkman is offline
Old 11-09-2009, 09:58 PM   #6 (permalink)
teamroper60's Avatar
45-55psi is considered normal. It should never drop below 45psi, even at WOT...
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 11-10-2009, 04:15 PM   #7 (permalink)
I only have 40 psi on my gauge sometimes 42, any way to bump up the pressure without an FAss kit?
K3 F350 6.0l 4x4, Crew cab, Lariat, shortbox, T.red, 285 BFG All Terrains, Sirius Radio, SS Grille, Silverstar fog and headlights, Boost and Fuel pressure gauges-Lunar Series Autometer. KYB MonoMax shocks 5w40 Delvac 1 14.7 mpg town.
Sushibar is offline
Old 11-10-2009, 04:20 PM   #8 (permalink)
69cj's Avatar
Agreed, 45 psi min. @ WOT driving the truck. Not in neutral sitting in the driveway.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
