fuel pressure - Diesel Forum - TheDieselStop.com
Old 10-11-2009, 04:39 PM   #1 (permalink)
turbo_2006's Avatar
fuel pressure
How much fuel pressure does the 6.0 put out? Looking to put a fuel pressure gauge in didnt know what size to get.
New truck 2003 F-350 Reg. Cab 6.0 auto 4x4
4 inch exhaust, SCT X3 custom tunes, bored .40 over, heavy valve springs, heavy push rods, elite diesel cam, full egr delete, auto meter gauges, blue spring, Jesse Warren injectors 190cc @75%
Old truck 2006 F-250 CC SB 6.0 auto 4x4
4 inch exhaust
SCT X3
auto meter gauges
window tint 5% front and back
front windsheild 20% top to bottom
with a 5% strip on top
turbo_2006 is offline
Old 10-11-2009, 05:12 PM   #2 (permalink)
Get a 0-100 gauge. You need a minimum of 45 psig and any pressure above 75 psig can danage o-rings.
The HFCM puts out 100 psig and a regulator begins to open up at 60 psig to recirculate fuel back to the HFCM to keep the pressure from exceeding the 75 psig.
Mark
bismic is offline
Old 10-11-2009, 09:44 PM   #3 (permalink)
turbo_2006's Avatar
Is the best place to get fuel pressure readings is at the fuel filter the one on the motor correct?
4 inch exhaust
SCT X3
auto meter gauges
Old 10-11-2009, 09:54 PM   #4 (permalink)
teamroper60's Avatar
Yes, at the test port.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
