You can get one of these -
Fuel Pressure adapter and hose (for remote location of the sending unit (install lower than the fuel filter bowl test port that it connects to).
http://www.itpdiesel.com/store.php/products/60L_FP_Adapter
Also, DFUSER sells the fitting. Be careful on install of the fitting. Some people have torqued down on the fitting and cracked the filter housing.
Ford 6.0L Powerstroke Fuel Pressure Gauge Adapter Fitting
Normal fuel pressure will be probably around 60 psig (this is when the recirculation valve starts to open). Never go below 45 psig. Higher than 75 may risk o-ring failure.
The fitting you need is is: M12x1.5 to 1/8" NPT
Mark
