Which Fuel Pump Should I get? - Diesel Forum - TheDieselStop.com
Old 02-04-2013, 03:13 PM   #1 (permalink)
So I am changing my injectors to 175cc/75 nozzles. Given the fact that I already have a driven diesel reg return, should I/do I need to replace my stock fuel pump? Previous tests i have done show under current conditions, up until WOT, the pressure stays at 65, while WOT drops to 58 (briefly) If so, which one? The AD 165 comes with a reg, but since I already have one, do I need one on the new pump or just the 150 without it? What should the fuel pressure be set to on the new pump if I need it?
'05 F250
egr delete, arp studs, updated down tube, powermax, driven diesel reg return, mbrp 4", rebuilt trans with billet converter, 155/75 sticks, matts full fuel tune from gearhead, and edge cts monitor
seamaster32 is offline   Reply With Quote
Old 02-04-2013, 05:16 PM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
I'd suggest a fuel sump and AD150.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline   Reply With Quote
Old 02-05-2013, 08:30 AM   #3 (permalink)
Derkperk's Avatar
Have to get a sump. My airdog hates life at less than 1/4 tank of fuel. I have the sinister sump but waiting for warmer install weather.
'05 F250 Lariat Crew Shorty Dark Stone FX4
AFE, MBRP single 304 4"w/ test pipe
ARP's w/ stock gaskets, Air Dog II 165
Driven Diesel Reg Ret fuel Kit
RCD Delete, 180/75's, 68mm VG Blow Jobby
Innovative Diesel Tuned SCT X3
Diesel Site coolant filter, Insight CTS
Overhead Auto Meters, Leveled
Homebrew traction bars
35x12.50x20 ATZ's on Ultra Mako's
Derkperk is offline   Reply With Quote
