This is in my '04 6.0 Excursion, 4x4 of course to make it difficult to get too.
I haven't gotten the water in fuel light in years. It recently came on though. I went to drain the separator and the plug is stuck and the hex socket head rounded. Last time it came on I was getting ready to get an oil change so I asked them to drain it while they were down there. I'm guessing they used an incorrectly sized driver to remove and replace the plug and in the process messed it up.
Options?
I've tried other sizes of drivers hoping to get it to budge, but nothing. There really is only enough room to get an allen key in there with the driveshaft in place.
If there weren't fuel inside I would just weld a nut to the plug and back it out with a wrench, but I don't think its such a good idea.
Any ideas?
Rob
Rob Ellis
'04 Eddie Bauer PSD Excursion
'94 5.8L Bronco
'68 5.0L Bronco
pick up a single 6 mm allen wrench and some JB weld, glue the single allen in the hole of the plug, reinforce with duct tape ect until it sets up, then remove the old plug, pick up the newer style plug that is extended out of the hole, there are many threads on here about it and the part #.
Good luck,!!
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter My Truck
I have seen a thread within the last 2 weeks on this. Search or I am sure someone will respond. I can tell you that the plug you want to replace it with is from IH #2589259C91. More of a thumb screw...
Good luck
And don't reef on It is the o-ring that accomplishes the seal, not how many foot-pounds you torque it to.
Wolf
Kentucky built 2004 Silver F-250 XL Reg Cab PSD, 4X2, bench cloth seat,air conditioning, 6 spd Manual, 3.73 LS,Line-X , FORD receiver, Prodigy brake controller,towing option,( put together on Monday, March 29, del April 9 2004) 62000 miles
Sorry, I searched and didn't come up with anything usefull or even close. For some reason the search engine on this forum never brings me anything usefull, unlike other forums.
I may try the JBweld. I tried it a number of years ago on a stuck recessed nut and didn't have any luck, but with a little patience that may just get this one out. Thanks
I will definitely get the thumb screw replacement plug
Rob Ellis
'94 5.8L Bronco
'68 5.0L Bronco
The WIF light isn't to remind you there's water in your fuel and to drain it..... The goal is to drain the HFCM frequently enough to PREVENT it from coming on.
Take Care
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
I am in the same boat as you. I am contemplating removing front drive shaft to allow more room, although I have never removed one before. Here is a link to a thread that I started a few weeks ago... look here
maps
Just my 2¢ Take it for what it's worth!
hope it works...the last one I bought from International was around 12 bucks....Ford wanted $25.oo the same part....Kevin
'04 F-250 Lariat CC LWB 2wd 6.0 Torqshift Dark Satin Green/Arizona Beige TRADED
07 F-250 Lariat CC LWB 4x4 6.0..Dark Stone/Arizona Biege Built 11/27 here on 12/06/06 picked up on 12/07/06...love the truck.....pictures soon...
That's what caused your problem. That plug should never be tightened greater than "just snug". The o-ring is the seal, and if you get carried away torquing it down, you'll have problems later.
If it gets to the point you need to take the cover off to drill out the plug, make sure you get a gasket kit before you take it off. The old one is NOT reusable, and you will have problems if you try to reuse it.
How is it so many people have a hard time getting an allen wrench into the plug? Sure the front drive shaft on mine is right there, but there is still plenty of room to get the short end of the wrench into the plug. Do some trucks have the drive shaft closer to the HFCM or vice versa??
2008 Tundra Crew Max Limited 5.7
2004 F-250 CC Lariat FX4 6.0 PSD with 132K miles (traded)
has anyone verified if the 2008 drain with lever is a fit for the 03-07's?
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
That's a question I'd like to see answered! If the 2008 plug won't fit, then my question is, do I have to remove the front driveshaft to install the IH plug? I've had one I got from ITP rattling around in my glovebox for a while.
__________________ Joseph, San Francisco Bay Area
'06 F-350 CC, King Ranch, FX4, 6.0 PSD/TorqShift, Dually, 4.30 Gears, Tow Boss, Loaded, Ford Remote Start/Alarm, No Performance Mods
Proud to be a member:
The Calif. Rifle & Pistol Assoc. (Life Member)
The National Rifle Association
What part of "shall not be infringed" do you NOT understand?
The 2008 HFCM is completely different, sadly. No go on a retrofit, without an insane amount of work.
The plug, despite being brass, develops enough corrosion around the threads to stick it a little bit even if it's not overtorqued (and this is why people who take it out monthly don't have the problem; no time for corrosion to build up.) It's isn't really sticking all that much, but the hex hole in the head, being brass, doesn't provide very much resistance to rounding either. The plug always loses eventually.
Ford's official replacement for our pickups is a steel plug. More likely to get a little corrosion, I suppose, but infinitely more resistant to rounding out the hole. So the plug wins, and the corrosion loses the torque battle.
The IH replacement is the way to go, though. No more depending on a stupid hex hole for putting torque on it.
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
