Gauge lights flicker - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 02-27-2011, 05:41 PM Thread Starter
'03 6.0, when I turn the key on, all the dummy lights come on and the gauges will do a sweep, shortly after that all the lights accept glow plugs will cut out or flicker and the gauges will stay at wherever they were in the sweep when the voltage is lost. Im thinking its a bad ECM ground, I cleaned all the battery grounds at the frame,engine, and the one on the passenger side inner fender, but Im not sure where or how the cab/ECM grounds to the frame. Anyone have any insight as to what is causing this?
rckstr is offline
post #2 of 9 (permalink) Old 02-27-2011, 06:00 PM
sarnott140's Avatar
have you tested your batteries individually?
'06 F350 CC, SB, 6.0
Oxford white, scangauge 2, 3" lift, egr delete, stc upgrade, dieselsite coolant filter, high idle mod, skyjacker s/s,deezee nerf bars and drybox, 305/65-18 BFG all terrains, Hella driving lights and fog lights.
sarnott140 is offline
post #3 of 9 (permalink) Old 02-27-2011, 09:53 PM Thread Starter
They are showing 520 amps each respectively under load. Starter is bad, it was cranking so slow it had no chance of starting, replacing it tomorrow, but dont see how it could affect the gauges with just having the key on..
rckstr is offline
post #4 of 9 (permalink) Old 02-28-2011, 11:23 PM Thread Starter
Does anyone know where the rest of the grounds are? Surely it cant be just the 2 frame rails, engine, and the little one on the passenger side inner fender..
rckstr is offline
post #5 of 9 (permalink) Old 03-02-2011, 01:25 PM Thread Starter
Does anyone else think it could be the ignition switch itself? Anyone have ideas about the best way to test for that? If I could check power going into the switch and it is constant when the lights flicker, that would indicate the ignition, I believe..
rckstr is offline
post #6 of 9 (permalink) Old 03-17-2011, 07:14 PM Thread Starter
Still havent traced the problem down, does anyone have a wiring diagram for the gauges? Or a link to where I could find one? Its on 03, 6.0 .
Thanks!
2001 F250 crewcab shortbox 4x4, 7.3, 4R100, all stock so far..230K KM's
rckstr is offline
post #7 of 9 (permalink) Old 03-18-2011, 12:45 PM
there was a bolt recall/ground connection issue for the 03...I'll see if I can dig it up for you...can't remember the location off the top of my head...b
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 78,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/187,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline
post #8 of 9 (permalink) Old 03-18-2011, 01:06 PM
recall #04S15...bolt and ground strap lower right front side of engine...you may also want to look for a wire chafe issue for the tow haul/gear selector wire on the steering column/remove the plastic cover/remove ign. switch and look for the small bundle of wires where they contact the top of column..the wires that exit the base of the shifter...the chafe point could be the issue for the gauge flicker...b
post #9 of 9 (permalink) Old 03-18-2011, 03:05 PM
Banned
The connectors to the panel on top, they need to be cleaned.
See my instrument panel cleaning stuff.
Gearloose1 is offline
