Gear Choices ???????? - Diesel Forum - TheDieselStop.com
Old 05-04-2009, 07:14 PM   #1 (permalink)
2006f350psd's Avatar
Ok guys someone has to be able to help me i need more low end in the truck and have decided to do fornt and rear gears along with and auburn posi in the rear and of course mag hytec front rear and trans since iam already in for a 2000 dollar buying spree i need help with the gear choice i run 37x13.50 20s on my truck and just ordered a new set of super swampers which will be in on friday so the question is 4.56 or 4.88 lets here the opinions from all of you guys running any of these my fuel mileage already blows but on the highway i really dont want the truck screaming thanks in advance
2006 F350 Lariat
MBRP 4 inch turbo back
Roush cold air
Pro Comp 8in XXS lift
20 in Moto Metal rims
Tons More
2006f350psd is offline
Old 05-04-2009, 08:13 PM   #2 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
4.30 gears unless the 37's are a stepping point for taller tires. The 4.30's will be better if you ever go bacl closer to stock and will give you a little more hiway speed in the rpm sweet spot
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 05-04-2009, 08:15 PM   #3 (permalink)
HeavyAssault's Avatar
My Photos: (6)
4.56s would be agreat fit but if you ever dropped down the tire size the RPMs will kill you on tjhe HWY.
Before you dump $2k on gears and fancy pantsy covers why not add a real HP gainer? Get rid of that HPyrjunk and use and SCT with a custom tune.
What else do you have for power gains?
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 05-05-2009, 11:39 AM   #4 (permalink)
JW350's Avatar
My Photos: (29)
Do you tow heavy with your truck?
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, Fox Shox, 37x13.5x17 Toyo Open Country MT on Weld Evo Velociti XT, 4.88 Gears, MagnaFlow Exhaust, AMP Research PowerStep, Auto Meter Cobalt Gauges (EGT Boost Trans), ScanGaugeII, Firestone Air Bags/Compressor/Tank, BulletProofDiesel EGR Cooler, Valvoline lubricants, Final Charge Global ELC, DieselSite Coolant Filter
JW350 is offline
Old 05-05-2009, 08:06 PM   #5 (permalink)
The 37s are it if i put 39s on the cutting begins and i never thought of 4.30s thats a good idea
2006 F350 Lariat
Roush cold air
Tons More
Old 05-05-2009, 08:11 PM   #6 (permalink)
I dumped the hyperjunk when i studded the heads and have just been running it stock with a MBRP straight piped 4 inch and a roush cold air kit everyone says the sct but i need someone who knows what there doing with the tunes and everybody has someone diffrent to tune it so iam a little lost and was just thinking of going with a banks six gun. The motor is basically brand new with the turbo,cooler,egr valve,heads,injectors and everyother little thing done at 45k and now only has 46 on it so iave been doing a little research on programmers adn diffrent people your input would help me to.
2006 F350 Lariat
Roush cold air
Tons More
Old 05-05-2009, 08:12 PM   #7 (permalink)
The truck dosen't tow at all so iam not overly concerned about that
2006 F350 Lariat
Roush cold air
Tons More
Old 05-05-2009, 09:14 PM   #8 (permalink)
Don't do the six gun i have two buddies that blew their 6.0's on that honestly the sct would be your best bet but if you want something like the Banks Get the Bully dog Triple dog downloader its best for fords other then sct... And it has free downloads to keep everything up to date.... Im running stock gears with that and i have no problem with low end torque!!
NMPOWER is offline
Old 05-05-2009, 10:03 PM   #9 (permalink)
Get a sct. Use cale at bts or go with innovative diesel and erics tunes. If for some reason you ever want a different kind of tune you will not be tied to just one guy writing files. That is what is nice about the sct. From what I have read those are the two top recomended tuners... I run some of spartans tunes since they are free
2006 f250 4x4
crewcab short bed
lariat 6.0psd
soon to have isspro
fire/air/trans/fuel
else
Old 05-06-2009, 08:13 PM   #10 (permalink)
How are the spartan tunes ive heard some good things and some bad so iam just wondering?
2006 F350 Lariat
Roush cold air
Tons More
Old 05-06-2009, 08:19 PM   #11 (permalink)
The low end was good at stock height with stock tires but the tires and the 3.73 gears just kill it now but it will still leave 200 foot marks
2006 F350 Lariat
Roush cold air
Tons More
Old 05-06-2009, 08:31 PM   #12 (permalink)
Well im not running 37" tires but with my set up the 35's i use has No lag or lowend torque problems.. Its honestly not as good as the SCT but for adjusting on the fly it has treated my truck perfect... Just ask the guy in his brand new 09 cobra i beat by a half truck langth.....
NMPOWER is offline
Old 05-07-2009, 08:58 PM   #13 (permalink)
Nice iam definitley gonna look into the SCT more
2006 F350 Lariat
Roush cold air
Tons More
Old 05-07-2009, 09:59 PM   #14 (permalink)
Thats a good choice... I still cant pull the power that the guys with SCT have... Something all you guys who get hard about outdoing a dodge might like...My buddy has a 05 cummins (Bigger turbo, injectors, intake, 5k dollar trans and fuel pump) Still has one hell of a time keeping up with an 06 6.0 With just the street tune and a Fass...
NMPOWER is offline
Old 08-07-2009, 01:11 PM   #15 (permalink)
krazykaboom's Avatar
My Photos: (9)
I am having the same dilemna with my 07. I'm running an 8" lift with 38" Toyos with an Edge but do not have the low end power with the stock 3.73LS. EGTs are close to astronomical if I put it under load on the highway. I don't tow often (next to none) but I want the best possible option for what I'm running. It's my daily driver (never off road) and some highway. What's your ideas guys. Who is running a 4.56 or 4.88 and can give me some feedback?
07 F250 Lariat, 6.0L, 8" Fabtech lift, 38" Toyo M/T's, fender flares, Edge Platium, Magnaflow exhaust, K&N Aircharger, Pioneer Nav/DVD, JL Amp w/ stealth box console, rhino lined, Recon light bar, Recon aux lights, Aries SS bull bar, Viper SST alarm/remote start, Amp Research step bars, K40 Radar
krazykaboom is offline
