Old 08-08-2009, 09:50 AM   #16 (permalink)
I have 35's and put in 4.56's brought my rpm's up by 300 while crusing at 75mph. I live near the mountains and wanted better towing ability. It definitely brings the motor to its proper torque range. I strongly recommend it.
mtblueford is offline
Old 08-08-2009, 02:45 PM   #17 (permalink)
Are you guys swapping the gears yourself, or paying somebody to do it? How hard of a job is the swap. I'd love to get the 4:30 out of my dually.
Current:
06 F350 dually crew 4x4 lariat, tow boss, every single option available.
07 Dodge 3500 Cummins 4x4 Larime with h2 wheels and 315-70-17 tires.
SOLD: 05 Dodge CTD/610 SLT/Quad Cab, Auto, 4x4, Loaded. 17"x9.5" Weld Cheyenne, 315-70-17 BFG AT/KO, Airaid intake, X to the Z illerator.
SOLD:
01 PSD Supercab XLT, manual 4x4, loaded, Fab-Tech 8" lift, high angle drive line (snapped the stocker towing 10k#), dual shocks, 37-12.5-16 SSR, 16x10 Eagle Alloy 589, Diablo stock/57/100, 4" exhaust, Open element/ZooDad, triple a-pillar, Sonnax/Tricum, Kodiak Sidewinder's, Wicked Wheel, A.R.E. Impulse shell, sp-exhaust brake.
http://f1.pg.photos.yahoo.com/ph/dmkhnr/my_photos
trailers/toys
6.5'x12' 12,000gvw dump trailer
25' Enclosed V-nose snowmobile trailer
24' Eliminator Daytona
22' V-Pro Sky Supreme
Dan_K is offline
Old 08-08-2009, 05:46 PM   #18 (permalink)
krazykaboom's Avatar
My Photos: (9)
MTBLUEFORD What are you running for RPMS at 75 with the 4.56's out of curiosity? My EGTs just keep climbing if I'm pulling anything or going up inclines unless I kick it down and cruise in 4th, then I'm staying at around 900 degrees. I'm hoping that the new gears will help with all that and allow we to cruise in 5th comfortably.
Dan K - I don't have the mechanical ability to swap them out myself. If I could I would in a second vs. pay some tech down the street 800 bucks to do it. Anyone in the Quantico VA area have any recommendations for installers? What type of gears should I look into???
07 F250 Lariat, 6.0L, 8" Fabtech lift, 38" Toyo M/T's, fender flares, Edge Platium, Magnaflow exhaust, K&N Aircharger, Pioneer Nav/DVD, JL Amp w/ stealth box console, rhino lined, Recon light bar, Recon aux lights, Aries SS bull bar, Viper SST alarm/remote start, Amp Research step bars, K40 Radar
krazykaboom is offline
Old 08-08-2009, 07:18 PM   #19 (permalink)
KRAZYKABOOM i am running 2200 rpm. If you look at the torque curve for the 6.0 you will see thats where its power is. Also with rpm's your egt's will stay in check. The torqshift is a good tranny but its 5th gear i believe is a 1 to 1 ratio which it totally drops the truck out of its power curve.Although a chip will help there is no substitute for the rpm's you need,believe me i pull in the mountains all the time.I was having the same problem as your talking about.I PAID 1700.00 with gears here in montana i used yukon gears been in for 2 years now no problems.
Old 08-10-2009, 01:02 PM   #20 (permalink)
JW350's Avatar
My Photos: (29)
5th gear in the TorqShift is 0.71 to 1.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, 37x13.5x17 Tires, 4.88 Gears, Turbo-back Exhaust, Gauges, Air Bags...
JW350 is offline
Old 08-10-2009, 03:17 PM   #21 (permalink)
My Photos: (9)
2200 RPM at 75!! That's sound a heck of a lot better than 2000 at 60-65. It sounds like a set of 4.56 is the way to go. I have been quoted similar prices for the install in the Virginia area as well. What is everyone view on 4.88 gears. Is that a bit tall for my application? I don't want to slap on the 4.56 and then be dissappointed when I buy a boat (don't tell my wife) next year and it doesn't pull like it should. I suppose if you are running the 4.56 in Montana terrain, I should be satisfied.....thoughts?
Old 08-10-2009, 03:18 PM   #22 (permalink)
My Photos: (9)
How do you like your 4.88 gearing? Are you towing alot? What are you running on the interstate for RPMs?
Old 08-11-2009, 11:14 AM   #23 (permalink)
JW350's Avatar
My Photos: (29)
I like 4.88 gears with 37" tires for how I use my truck. My toy hauler is approx 13,000 lbs and my destinations take me up steep grades and over mountain passes. Truck feels dialed...
I have a local commute (no freeway). When I am unloaded on the freeway, I hold 80 MPH at 2,600 RPM the entire trip. The 6.0 likes RPM.
You stated earlier that you do not tow much, if ever. But, you may get a boat? I recommend 4.56 gears with your 38" tire setup.
JW350 is offline
Old 08-11-2009, 04:49 PM   #24 (permalink)
My Photos: (9)
Thus far 4.56 has been the recommended gear set for my setup. I am by no means towing the weight you are, so IMO the 4.88 would be too tall and not allow me to cruise comfortably on the interstate. Thanks for the all your help...now it's on to pricing.
Old 12-31-2009, 09:01 AM   #25 (permalink)
i have a question. i have a 2004 F 250 4wd PSD. i am looking to add some gear for towing reasons. i have stock tires and no lift or anything. what would be a good gear for me and do you have to change the front and rear or just the rear? the truck is used for towing 90% of the time.
shane1220 is offline
