Getting a new turbo - Diesel Forum - TheDieselStop.com
Old 08-03-2009, 04:59 PM   #1 (permalink)
Getting a new turbo
Well,
After 1 week with the new to me truck, it's been to the dealer twice. They just called and said it needs a new turbo. I'll be back up and running Wednesday.
Got to updated my sig with truck specs.
I've got 4:30 gears, anybody change them out to 3:73 for mileage? I bought the truck to tow a 26' fiver, and its a little overkill for my 9-10k# trailer. I'll either swap gears, or go with taller tires to drop the r's at hiway speeds.
Current:
06 F350 dually crew 4x4 lariat, tow boss, every single option available.
2000 F250 crew 4x4 lwb leather
SOLD:
07 Dodge 3500 Cummins 4x4 Larime with h2 wheels and 315-70-17 tires.
05 Dodge CTD/610 SLT/Quad Cab, Auto, 4x4, Loaded. 17"x9.5" Weld Cheyenne, 315-70-17 BFG AT/KO, Airaid intake, X to the Z illerator.
SOLD:
01 PSD Supercab XLT, manual 4x4, loaded, Fab-Tech 8" lift, high angle drive line (snapped the stocker towing 10k#), dual shocks, 37-12.5-16 SSR, 16x10 Eagle Alloy 589, Diablo stock/57/100, 4" exhaust, Open element/ZooDad, triple a-pillar, Sonnax/Tricum, Kodiak Sidewinder's, Wicked Wheel, A.R.E. Impulse shell, sp-exhaust brake.
http://f1.pg.photos.yahoo.com/ph/dmkhnr/my_photos
Dan_K is offline
Old 08-03-2009, 07:15 PM   #2 (permalink)
imsolidstate's Avatar
Keep the gears.
I have 3:73 gears but I want to change to something in the low 4s and add a locker when I can afford it. I pull a flatbed with a bobcat and a three horse living quarters trailer. I live in Colorado, lots of hills and the speed limit is 65 most places. Problem is, with the 3:73s the engine wants to shift all the time at 65. I can't build boost and get any power until I shift and get some RPMs, and then by the time I get back up to speed it's in overdrive again. At 75 things are okay, the turbo is much more responsive and you shift less but it really wants to go faster. I'm not comfortable going 80+ in a horse trailer with three horses. I'd need way bigger brakes for all the brake-checking a**holes.
2004 (2003 motor) F-350 CC LB King Ranch DRW.
imsolidstate is offline
Old 08-03-2009, 07:21 PM   #3 (permalink)
One thing I forgot to mention is if you aren't making enough boost because you don't have enough RPMs, your EGTs skyrocket. I run 1200-1400F EGTs regularly when towing up hills. I've cleared 1400 a few times. If you shift down and get RPMs back, EGT cools right off.
Old 08-03-2009, 07:32 PM   #4 (permalink)
jdoggett's Avatar
I know what you mean about new turbo, just had one put in mine, 05 34000 miles just quit pulling 13000# fifth wheel
jdoggett is offline
Old 08-04-2009, 12:11 AM   #5 (permalink)
Whats the tallest tires you guys have seen on a stock dually? Thinking 285-75-17 but not sure if they are too wide? I run just over 2200rpm at 70 mph, so the tire change should get me a tick over 2000 r's at same speed.
The truck came with brand new tires so I'll have to figure something out with these.
Current:
SOLD:
SOLD:
Dan_K is offline
Old 08-06-2009, 07:36 PM   #6 (permalink)
Got the truck back yesterday afternoon, went to move the 5ver, brought truck home only to wake up this morning to a puddle of oil. Truck is back in the shop 3rd time in less than 3 weeks.
Called dealer where I purchased the truck and expressed my disapointment, they said they'd call back with a solution. I hope they don't tell me to trade it in on the cash for clunkers program.
Current:
SOLD:
SOLD:
Dan_K is offline
Old 08-06-2009, 08:35 PM   #7 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Man, these 6.0 stories just keep on coming, Ford should get them all back.....
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
