good power lots of smoke - Diesel Forum - TheDieselStop.com
Old 12-02-2008, 07:25 PM   #1 (permalink)
just spent 12K a month ago getting a head gaskets replaced and the entire cooling system (I know ouch) on 2004 F-350 and now the truck is blowing so much smoke we won't drive it. Is the most likely cause the injectors.
Any sugestions would be apprieciated.
Xstream is offline
Old 12-02-2008, 07:27 PM   #2 (permalink)
Smoke analysis
White smoke:
Caused by unburned fuel passing through the engine. Some white smoke is normal on cold start-ups.
Excessive white smoke could be an indication of inoperative glow plugs, loose injectors, low compression from worn rings or bent connecting rods, or coolant leak into the cylinders--head gasket or injector well sleeves.
Black smoke:
Caused by excessive fuel for the amount of air drawn into the cylinders. Some black smoke on hard accel or at higher altitudes is normal.
Excessive black smoke could result from restricted intake or exhaust, inoperative leaking or weak turbo, intake hose(s) leaks, leaking or worn injectors, fuel return or supply restriction, stuck Exhaust backPressure Regulator valve or solenoid. Also PCM inputs such as BARO MAP ICP or EBP sensors.
Blue or blue/white smoke:
Caused by insufficient fuel or oil consumption. Normal when engine is cold or idling for extended periods.
Excessive smoke could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, worn or leaking injector o-rings, thermostat stuck open, oil consumption, or plugged crankcase depression regulator valve. Also PCM inputs such as MAP or ICP sensors.
2000 7.3 Power stroke turbo,165k miles. Bull dog tuner. Air raid cold air intake.
galexander is offline
Old 12-03-2008, 09:57 PM   #3 (permalink)
The most common part that fails that causes excessive white smoke is the EGR cooler. Check to see if the degauss bottle is still full. If its empty its probably the cooler.
bwhalen is offline
Old 12-04-2008, 12:34 PM   #4 (permalink)
JIM_C's Avatar
My Photos: (5)
Agreed. Do you know if they replaced the oil cooler as well? The coolant passages in the oil cooler get clogged (which is why a lot of us run coolant filters) and starve the EGR cooler downstream. The EGR cooler overheats and fails when the exhaust hits it, leaking coolant into your intake and cylinders. The white smoke could be burning coolant.
That may have been your truck's problem to begin with.
2003 F250 XLT CC Long Bed 4x4, 6.0 w/Auto
JIM_C is offline
Old 12-04-2008, 01:44 PM   #5 (permalink)
Are you useing coolant ? what does the smoke smell like? this simple thing can point you in the right direction quickly.It is one of the three fluids Fuel,Oil or coolant.You should have some type of warrany with this job and I would go back to the place that did it.
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline
