Grease Fittings - Diesel Forum - TheDieselStop.com
Old 08-05-2009, 08:49 PM   #1 (permalink)
Derkperk's Avatar
Grease Fittings
I'm wondering how many zerks are there? I know of the two on the front U joints, is that it? Thanks...
'05 F250 6.0l Lariat Crew Shorty Dark Stone FX4
AFE, MBRP single 304 4"w/ Cat test pipe,
Overhead Auto Meters
Diesel Site coolant filter, Leveled
35x12.50x20 ATZ's on Ultra Mako's
Innovative Diesel SCT X3
Running Eric's X Street tune
Derkperk is offline
Old 08-05-2009, 09:48 PM   #2 (permalink)
I think that is all that your year model has.
I have heard (not confirmed) that earlier year models may have some in the following locations:
3B410Tie rod end (outer, RH)
3304Steering sector shaft arm drag link
3B411Tie rod end (outer, LH)
Mark
bismic is offline
Old 08-05-2009, 10:28 PM   #3 (permalink)
Draglink, and any replaced balljoints.
Ljutic SS is offline
