Had the death wobble now what to do to fix it - Diesel Forum - TheDieselStop.com
Old 04-20-2009, 09:25 PM   #1 (permalink)
350r powervalve's Avatar
Send a message via Yahoo to 350r powervalve
I think im out of warranty at 40k miles and theres a golden brown fluid running down the driver side frame rail and i think its power steering fluid im not sure. i checked the res. and its a little low but not low enough to make that much fluid come out. the motor oil in my truck is black so i know its not that, could it be a turbo boot coming lose ? have not had the wobble for about a month it seemed to appear when going about 45mph around aturn and hit a little hole in road that started it.
2005 F350 6liter drw,longbed,4x4, crew cab lariat,gray with ground effects, rhino liner,chrome door handles, sct coming
350r powervalve is offline
Old 04-20-2009, 09:29 PM   #2 (permalink)
MikeL46's Avatar
My Photos: (14)
Death Wobble is almost always the track bar.
At least in my case, turning the wheel stopped or prevented it by taking the play out of the steering. But, when going straight and hitting a bump - I learned why it is called DEATH WOBBLE!!
And it was the track bar. Get underneath and have somebody turn the wheel back and forth. See if you can find some play somewhere.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 04-21-2009, 12:37 AM   #3 (permalink)
sarnott140's Avatar
ya if its stock its probly the trac bar. I had the death wobble real bad after i got a 3 inch lift installed but the caster change is what caused it.
'06 F350 CC, SB, 6.0
Oxford white, scangauge 2, 3" lift,dieselsite coolant filter, high idle mod, skyjacker s/s,deezee nerf bars and drybox, mudflaps, 305/65-18 BFG all terrains, Hella driving lights and fog lights.
sarnott140 is offline
Old 04-21-2009, 01:25 AM   #4 (permalink)
Banned
I had death wobble with my 6" pro-comp. A set of expensive DR stabilizers and no more death wobble at all.
I also had the fluid running down the drivers side frame rail. Ended up being the hydroboost pump. Not sure of the cost because it was replaced under warranty.
Banshee365 is offline
Old 04-21-2009, 05:15 PM   #5 (permalink)
Before you spend any money make sure your front tires are inflated well. That is the very first thing on the service bullentin and it fixed mine.
2006 F-350 flat-bed 6.0L PowerStroke. 4" Turbo-back exhaust. One bed-plate leak fixed.
cla511 is offline
Old 04-21-2009, 10:47 PM   #6 (permalink)
Derkperk's Avatar
Got a letter in the mail this week from FoMoCo regarding the wobble. It said to make sure your tires are inflated to the proper pressure. That's a fix?
'05 F250 6.0l Lariat Crew Shorty Dark Stone FX4
AFE, MBRP single 304 4"w/ Cat test pipe,
Overhead Auto Meters
Diesel Site coolant filter, Leveled
35x12.50x20 ATZ's on Ultra Mako's
Innovative Diesel SCT X3
Running Eric's X Street tune
Derkperk is offline
Old 04-22-2009, 09:31 AM   #7 (permalink)
My Photos: (6)
Send a message via AIM to blizzardwarrior7
Most people I know dont purposely air down there front tires for street use, so I think thats B.S. Your best bet is to install a dual Stab. Kit, or if you've already got one, to check your trac bar, and make sure its torqued to spec.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
Old 04-22-2009, 10:44 AM   #8 (permalink)
nightmoves's Avatar
What about his fluid leak.
11'F-250 Superduty XLT-Premium Package Crew Cab,Short bed,Ingot Silver ,6.2,Auto,4x4,18"wheels,3.73 gear's
nightmoves is offline
Old 04-22-2009, 11:35 AM   #9 (permalink)
I drive across the same bridge where I could reproduce the wobble every time several times a week and since I pumped the front tires up like they should be it has not done it since and that has been over a year. The front end of these trucks are extremely heavy and you need 55-60 psi in your tires. The tires that came on the truck new recommend 65 psi for max load.
cla511 is offline
Old 04-22-2009, 05:16 PM   #10 (permalink)
This! It is most likely the tire pressure or tires themselves. Mine started after I had my tires rotated and they didn't adjust the pressure when they switched them from the front to the back. It went away completely with a set of new tires also.
2004 6.0Powerstroke ExtraCab. Indigo Blue over Tan, Super Chip, AT's
2007 6.0Powerstroke CrewCab. Silver, Chrome package, SuperChip, MBRP Cool Duels Turboback
Burper/Puker
2 Degas Bottles, 3 Degas caps, 1 EGR Cooler, 1 Oil Cooler, 2 O-rings.....still puking.....
Also, two speed sensors, and about 13 damn tail light bulbs.....
StrokinTiger is offline
Old 04-23-2009, 04:30 PM   #11 (permalink)
I also got the letter this week but a few weeks back I noticed that my Steering dampner was leaking, so I bouht a new one, put it on and it seems to be fine now. Maybe I am lucky...maybe I should have gotten the newer one with the upgraded bracket.
What is the track bar? Where is it and what is the torque setting on it so I can check it.
2006 F250 King Ranch PSD, ARP Head Studs, EGR Delete, 4" Turbo Back no cat
Rollingrock is offline
Old 04-23-2009, 08:48 PM   #12 (permalink)
Thanks everyboby for the info, my plan is to beef up the front end with some aftermarket stuff and then put some 22.5 alcoas on it
Old 04-23-2009, 09:52 PM   #13 (permalink)
Gotrox's Avatar
My Photos: (6)
If a new steering stabilizer fixed it, the problem is still there. whatever is worn is still worn and its going to come back, probably a lot worse. Almost every part connected to the front steering or suspension can cause death wobble. Anything that can wear and cause either play or a vibration can set it off.
2003 F-350 - 4x4, 6.0L, Auto, 52250 miles, Straight-piped, AFE filter, ProSport gauges, leveled, pro-comp 16x10s, 35" Nittos
Gotrox is offline
Old 04-26-2009, 07:41 PM   #14 (permalink)
On a project last summer we had several late 90s dodges and several new dodges. Every time a steering stabilizer was jerked off or wore out the vehicle would shimmy until we replaced the stabilizer. As I understand it after the 70s when spring bushings got soft a stabilizer is needed to prevent shimmy. I see the theory behind this but our '88 350 did not have a stabilizer and it didn't shimmy. It also had extra springs all the way around.
For the leak I would fill the PS reservoir to the full mark. If it drops the source of your leak is found.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0
'06 40' prairie schooner 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'88 F350 Crew SRW (now parts)
'85 F7000 mechanic service, 3208na CAT
'97 Aerostar 4X4 Extended 4.0
'93 Sable 3.8
'92 Taures 3.0 sold
'84 Bronco II 2.8 4 speed 4X4
'84 Ranger 2.8 2X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
Old 04-27-2009, 12:04 AM   #15 (permalink)
I have dealt with death wobble on several trucks and from my experience it is from one of few things. 1, Not enough caster. Common on '05 up SD with a lift. 2, track bar/rod worn out. check for play. 3, incorrect toe angle. I have found they work good with about 1/8" to 3/16" in. 4, High offset wheels or short backspacing. 5, Balance tires. if you have 2 tires that wobble due to balance the truck could feel as if it is falling apart. 6, Steering damper. This thing does not fix problems. It just dampens them. If leaking I would replace it but the stock one should be adequate. The steering damper just absorbs the steering wheel so that if you hit a curb or drive offroad the wheel is not yanked right out of your hands. For the leak I would clean the truck up well and keep an eye on it.
04 GMC 3500 4x4 dually LB7 duramax 04/04 F250 12/20/03 build date, XLT Supercab longbed 6.0l, 4X4, 3.73lsd, FX4 pkg, torqueshift, ESOF, silver/med. flint, 6cd, back up sensors, rear slider, camper pkg, big mirrors w/ heated/pwr glass, Sold
04/04 F350 Crew Cab long bed 6.0L lariat FX4 46K Sold
1998.5 Dodge 3500 4x4 dually 24valve cummins 160K (sold)
2005 Lance 835 Cabover Camper
1999 Sanger DXII ski boat
1975 Dodge RamCharger (sold)
1990 Sanger DX ski boat
1991 Dodge W350 Cummins SRW (sold)
pwrstrokn2004 is offline
