hard cold start: where begin? - Diesel Forum - TheDieselStop.com
Old 11-08-2012, 12:36 PM   #1 (permalink)
hard to start cold, have to glow plug 3-4 times.
No CEL displayed.
FICM recently replaced.
So where do I look, how diagnose? How hard is it to replace glow plugs or relay?
I have 100K miles.
thanks
canucklehead is offline   Reply With Quote
Old 11-08-2012, 08:18 PM   #2 (permalink)
dieselmac's Avatar
Once it does start, does it have a romp or lope sound?
What's your fuel pressure look like?
Scott
2006 F-250 PSD, Lariat
Mods: All the usual stuff
dieselmac is online now   Reply With Quote
Old 11-08-2012, 08:28 PM   #3 (permalink)
yes, it does lope after cold start. And Ford mechanic told me one injector was starting to act up but only when cold and was fine when warm, so not to worry about it right now.
it runs rough cold and once warm, it starts easy and runs better.
oops, forgot to answer you...I have not checked fuel pressure and don't have the specialty tools to do that.
Old 11-08-2012, 08:35 PM   #4 (permalink)
dieselmac's Avatar
You probably have injector stiction. When the oil cools, it thickens. Thicker oil plus some contaminants are too much for the spool valves in the injectors to overcome. As the oil warms up, it thins out and the spool valves operate normally.
You could try a product called Rev-X. It'll help clean out some of the junk in the spool valves. Switching to a synthetic 5W40 will help some also. But more than likely, you're eventually looking at some new injectors.
Scott
Old 11-08-2012, 08:51 PM   #5 (permalink)
thnx dieselmac.
I'm due for an oil change. I was going to switch to 10-30 like many say I should do. Is 5-40 synthetic both thinner for cold start & thicker for heat? I might also give Rev-X a shot. Just not sure which of these many products actually do what they claim they do.
Old 11-08-2012, 10:57 PM   #6 (permalink)
Feedback Score: 2 reviews
These motors need a 5w40 Syn and use only Ford filters. This may help also.
I would try this first, just me
ARCHOIL PRODUCTS SPOKANE - HOME
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline   Reply With Quote
Old 11-09-2012, 01:19 PM   #7 (permalink)
hey 2stroker, thanks for the info.
have you ever tried Rev-X, as suggested by dieselmac?
Over the years I have tried several different friction modifier products like Slick 50, BiTron, PTFE resin, etc... They were on different vehicles. I can't say I noticed all of the claims they made. My friend says they're all snake oils.
I want to believe it will work, but I dunno. I will definitely try the 5-40 synthetic.
Old 11-10-2012, 01:09 AM   #8 (permalink)
No I have never tried it, I have used Amsoil 5w40 Syn with a by-pass right from the get-go and change oil at 5k. My 6.0 about 99% of the time pulls my 5er so when it is running it is working it's not a grocery getter. I buy the best oil I can the way I look at is (you pay to play)
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
Old 11-10-2012, 01:36 AM   #9 (permalink)
2 stroker i just looked at your sig. How do you like yer '06 compared to the '97?
Old 11-18-2012, 01:04 PM   #10 (permalink)
I know this post is a little old, but wanted to give my 2 cents. tried rev X last winter helped stiction a little, but was still there. This september tried archoil. When stiction showed up at about 55 degrees. Didnt get fast results but now with a couple thousand miles its been as low as 27 degrees and the stiction hasnt showed back up.Hope this might help someone out and save the price of injectors or at least delay it till to a more convient time.
2stroked out is offline   Reply With Quote
Old 11-18-2012, 01:56 PM   #11 (permalink)
wedge45's Avatar
No CEL displayed.
I have 100K miles.
thanks
Call Ed .. @ FICM repair.com
it probably has to do with the Voltage and your batts ... I spoke to him for an hour ysterday, and boy did I learn alot.... wedge
2006 f-350 Lariet, LB, 6" Fab-Tech, 35 toyo's on 18" MKW, Banks Turbo back Exhaust, AFE Cold Air intake, Atlas 40 by FICM repair
wedge45 is offline   Reply With Quote
Old 11-18-2012, 05:24 PM   #12 (permalink)
My king ranch had the same problem a couple years ago and it was the injectors. I changed the oil with synthetic 5w40 instead of 15w40 and added Rev-x. It started perfect every time and got rid of the lope. The rev-x is a little pricey, but nothing compared to eight injectors
2006 F-350 SRW LB King Ranch Crew Cab
4" lift with 35" Pro Comp Xtreme tires
SCT Livewire custom programmer
K&N FIBK cold air intake system
4" turboback exhaust with a 7" monostack
2001 F-250 XLT SRW SB Supercab
Bone Stock(For Now)
strokin231 is offline   Reply With Quote
Old 11-19-2012, 05:19 AM   #13 (permalink)
Midnight Trucking Interview... on Vimeo
97 F250 PSD Xcab 4X4 rebuilt trans,precision converter, tugger shift kit, hughes pan,4" bigboar exhaust. 3 gauge pillar, trans,pyro,boost. add a leaf 260,000 miles 06 F250 Xcab 4X4 powerstroke, juice with attitude CTS that's great. 140,000 miles, 5 " Diamond eye redneck Fartpipe with cat. rolling on 20" grapplers. Gone but not forgotten, 04 Cobra Mustang. Better known as the Corvette Killer. 2.93 pulley, 438/466 HP/TQ.
scootdog is offline   Reply With Quote
Old 11-19-2012, 06:56 AM   #14 (permalink)
Junkers88's Avatar
Dang it. I went with the 10w-40 Rotella T5 synthetic since I couldn't find the darn 5w-40 T6 anywhere in town. Truck still lopes at cold starts below 30 degrees but it doesn't lope as bad and smooths out a lot quicker. Added the RevX yesterday and am headed on a 20 hour road trip today to go home. We'll see how she does.
05 F350, 6.0, K&N intake, Magna Flow 4", Edge Insight CTS, Sinister bypass coolant/oil filter system, Sinister EGR delete, more to come!
Junkers88 is offline   Reply With Quote
Old 11-19-2012, 10:46 AM   #15 (permalink)
scootdog, interesting link. I like the $$ back guarantee they offer.
