hard start when cold - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 11-17-2012, 08:50 PM Thread Starter
My buddy's 06 with 100k on it has been acting up.He says that when the truck sits overnight it starts kinda hard.After it starts it will run real rough,if he doesn't let it warm up and trys to drive away he has no power and it stumbles.If it has a chance to warm up it runs ok.
Any suggestions on what the problem may be.
He's just north of Tampa so if anyone knows a good shop let me know.
2011 f350 4x4 cc,Lwb
mopwr is offline
post #2 of 6 (permalink) Old 11-17-2012, 09:19 PM
Feedback Score: 2 reviews
This is where i would start.
Then if he needs repairs
FICM Repair.com - Your Source for FICM Repair
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #3 of 6 (permalink) Old 11-17-2012, 10:25 PM
Iam4MSU's Avatar
The Fuel Injection Control Module (FICM) has lead free solder connections onthe circuit board. Due to no lead, the solder is very fragile and will develop hairline cracks. These crack prevent full electrical connectivity thus reducing the voltage in the circuit panel. If you plug the truck in for a few hours to heat the engine and oil, the heat inside the engine compartment will cause the hairline cracks to tighten up thus providing the required voltage for the engine to run properly.
It may be hard to believe this but mine was doing the same thing. Check the voltage on the FICM and see if you have a low voltage situation. You may also have a P0611 code which indicates the FICM is on its way out.
Mine was just repaired at FICMrepair.com today and is on the way back to me. I should have it Monday or Tuesday.
2004 F250 Crew Cab King Ranch Lariat FX4 Saddle Leather 6.0 L FUMOTO Valve
AIRAID 4" straight No CAT No MUFF
Nitto Terra Grapplers All Terrain LT285/75R16 10 PR Everything else pretty much stock
NEW Ranchos installed 8/15/2010
WORK IN PROGRESS - R&R EGR COOLER, OIL COOLER, THERMOSTAT, TURBO BOLTS, GASKETS, ORINGS, and adding a COOLANT FILTER WITH NEW COOLANT AND FLUSH
Anyone Got Birds?
Will Travel to Hunt!
We are all just Village Idiots,
Enamoured with our own shadow,
Oblivious to the setting sun!
Iam4MSU is offline
post #4 of 6 (permalink) Old 11-20-2012, 06:38 PM Thread Starter
Thanks.....I'll let him know.
I do know that he did have the FICM replaced about a year ago.I suppose it could have gone bad again.The one he had put on was a refurb but i'm unsure from who.
Anyone know any good shops in the Tampa area where he could have this changed out.
mopwr is offline
post #5 of 6 (permalink) Old 11-21-2012, 06:54 AM
CAMPINGTOM's Avatar
Do you still have the name and number of the guy that I gave you a few months ago?
2005 F-250 6.0
4" Straight Pipe, CCV Reroute, Coolant Filter, Sinister EGR, Insight Monitor, SCT X3 (Tuned by Innovative)
Blue Spring, Atlas 40 FICM Tune
CAMPINGTOM is offline
post #6 of 6 (permalink) Old 11-21-2012, 08:06 PM Thread Starter
No ...Tom can't find where he put it and i didn't think to save it.
I'm going to suggest to Tom that he order one from FICMrepair ,take it to that guy in Tampa and have him do the sawp then Tom can send the core back.
My friend is on a fixed income(retired) and i sure hope his truck doesn't start to eat him up in repairs.He's got 104k on it and generally runs good except for this hard start issue when cold.
Thanks again for the name and number.
mopwr is offline
