Harpooning - Diesel Forum - TheDieselStop.com
Old 07-06-2009, 03:11 PM   #1 (permalink)
Harpooning
Whitch is easyer to do lift the bed or drop the fuel tank to Harpoon? Also do you cut both tubs off.Thanks
2006 F-250 6.0 SRW Supercab Lariat 4X4 ESOF 3.73 Gears, Short Bed Dark Stone Metallic & Arizona Beige, Crome Package, Tan Leather Interior.
coonman111 is offline
Old 07-06-2009, 09:08 PM   #2 (permalink)
I just unbolted the bed and jacked it up on the end by the cab. I put wood blocks in between the bed and the frame to support it and did the mod. Very easy this way.
Mark
bismic is offline
Old 07-07-2009, 08:30 AM   #3 (permalink)
mountainview's Avatar
Sorry to cut in! What is Harpooned?
2005 King Ranch 325 60 R20 C.C. XM SAT. Dark Green and Beige. Stock.
mountainview is offline
Old 07-07-2009, 09:12 AM   #4 (permalink)
LOOSEWHEEL's Avatar
Harpoon mod
2001 F350 CC SWB 6spd WHITE 8.5" on 37's. Currently getting a complete makeover......stay tuned.
Pics
'Everything is possible if you don't know what you are talking about'
LOOSEWHEEL is offline
Old 07-08-2009, 10:00 AM   #5 (permalink)
I've done two of them now. It took about 3 hours for the first one, and an hour for the second. Amazing how much faster it goes the second time. For both of them, we dropped the tank. Only had a few gallons in the tank each time so it was very easy to handle. Both were FX4 models so there was the skid plate to contend with.
If I remember correctly, 4 bolts for the skid plate, 4 bolts for tank mounts, remove filler and vent hose, fuel lines and sending unit. Open tank from top and cut off the vent tube drop only. I left about an inch on it.
Reverse procedure to re-install.
When pump shuts off now, I only have to trickle in the last gallon instead of the last 5. Overall, a very worthwhile mod.
Aaron
2004 F250SD 4x4, XLT Sport, FX4, Crew Cab
6.0L PSD, Torqshift, 3:73ls
Dark Shadow Grey, Power Cloth Captain's Chairs
Reverse Sensors, Heated Switched TT Mirrors,
Adjustable Pedals, Covermaster CMX Series Topper,
Bedrug Bedliner, Prodigy Brake Controller
Hensley Arrow Hitch, Ride-Rite Air Bags, Dashmat
X-Monitor Digital Gauges, Tach 1200 High Idle Mod Harpooned
Born on 1/21/04,
My Photo's
ABrown134 is offline
Old 07-09-2009, 01:59 PM   #6 (permalink)
Thanks guys Ill give it a try.
Old 07-09-2009, 03:40 PM   #7 (permalink)
FMTRVT's Avatar
My Photos: (16)
40 minutes when you get good
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
Old 07-14-2009, 10:46 AM   #8 (permalink)
I've done two of them now and dropped the tank both times.
07 CC LB FX4 TS 6.0 Oxford White, 4.5" DR lift, 315/70/17 BFG on 17x8 American Racing Mojave
Nubbs is offline
