Has anyone tried Hot Shot's Secret? - Diesel Forum - TheDieselStop.com
Old 01-21-2013, 06:53 PM   #1 (permalink)
Supporting Member
GIJOE0916's Avatar
I would like to try this product, but would like to know the opinion of members of this forum. Has anyone tried Hot Shot's Secret?
The bottle states to use this product in place of two quarts of engine oil. Is this safe?
GIJOE0916 is offline   Reply With Quote
Old 01-22-2013, 01:52 PM   #2 (permalink)
MikeL46's Avatar
My Photos: (14)
Dang, you need to resize your photo.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
106345 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline   Reply With Quote
Old 01-22-2013, 03:11 PM   #3 (permalink)
pwesseler's Avatar
My Photos: (5)
Never heard of it. (hahaha)
2007 F250 XLT 6.0L PSD 4x4
pwesseler is offline   Reply With Quote
Old 01-22-2013, 04:09 PM   #4 (permalink)
MikeL46's Avatar
My Photos: (14)
Try and do a search on this site for it, you will get hundreds of postings.
Mike
Old 01-22-2013, 04:30 PM   #5 (permalink)
when I was looking for a chemical solution to stiction, all the reading I did on these forums left me with the impression that HSS is useless, and RevX is the only way to go. Then after that I've heard of some Archoil product, but have little info on it.
I do recommend RevX, having used it twice, but if something cheaper THAT WORKS is found, I'd be interested.
2005 F-250 XLT SuperCab long bed 118k. ScanGauge II. 3X Fumoto's. Dieselsite filter. Delvac ELC. Rotella T6. Rev-X. Improved HFCM plug. Power Service every tank. 24" wipers. PIE. AutoEnginuity. Soon to install BPD EGR cooler, OEM oil cooler, STC kit, blue spring kit, NCHornet CCV.
Idahoser is offline   Reply With Quote
Old 01-22-2013, 05:41 PM   #6 (permalink)
Supporting Member
My mechanic and Amsoil have recommended and I have been using Amsoil Sabre Synthetic Outboard 2 stroke oil in the fuel tank at a 300-500 to 1 ratio. I have six 6.0s and have tried it in the last few months. My drivers think it is resulting in smoother running, better starting vehicles. We are using about 1/2 pint to 25 gallons of diesel.
Tim in Central Florida
2012 F350 CC SB Lariat Tuxedo Black w/RollnLock bed cover
2012 F350 CC Cab/Chassis with 9' Knapheid tool box
2006 F250 CC Lariat with ARE construction cap
2007 F350 CC Lariat with 8' Knapheid tool box
2006 E350 Extended Cargo Van
2005 F350 CC King Ranch with ARE construction cap
2005 E350 Extended Cargo Van
2004 E350 Extended Cargo Van
And, sorry to mention on this forum
Two 2012 Nissan NV3500 High Roof cargo vans
Cell1Diesels is offline   Reply With Quote
Old 01-22-2013, 05:43 PM   #7 (permalink)
Supporting Member
This is based on the theory that there is not enough lubrication in the low sulphur diesel we're buying.
Old 01-23-2013, 01:33 AM   #8 (permalink)
Send a message via Yahoo to homerun_const
My grandfather who is a diesel mechanic told me to use a little bit of ATF fluid in my fuel to combat stiction. When I had an issue I used a 1/4 to 1/2 pint in two consecutive tanks when filling up and it worked. I now put some in with fuel every 5 tanks or so as a preventative measure. I started this with about 80k on it and I now have 150k on it and it runs great.
Sent from AutoGuide.com App
homerun_const is offline   Reply With Quote
Old 01-23-2013, 05:32 AM   #9 (permalink)
Stiction is on the oil side, not the fuel side.
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD Billet WaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is online now   Reply With Quote
Old 01-29-2013, 10:12 AM   #10 (permalink)
I tried it for 3k miles, did nothing I will be getting my money back
06 F350 lariat PSD. 183K, EGR delete, straight pipe, ELC coolant, Scanguage, new oil cooler, high idle mod, leveled with 35" falken wild peak AT tires on factory rims.
marka904 is offline   Reply With Quote
Old 01-29-2013, 12:53 PM   #11 (permalink)
I've used it about 4-5 times, I've used REV-X 3 times, I'd go with REV-X
And yes, stiction is on the oil side, not the fuel side
DEESLVRGN is offline   Reply With Quote
Old 03-02-2013, 06:20 AM   #12 (permalink)
squid109mc's Avatar
I have used Hot Shot's Secret 3 times now and there was no noticeable difference with stiction with cold weather startups.
I then tried Archoil AR9100 and was amazed that it fixed the cold startup stiction issues quickly. Before trying the Archoil product I looked at Rev-x but the price point was a huge turnoff.
I wouldn't waste my money on any products from the company that makes Hot Shot's Secret. I think it is just another company with false claims.
2005 F-250 Lariat FX4 6.0L - Gonzo
2013 F-350 XLT FX4 6.7L Pimped out!
United States Navy Veteran...
squid109mc is offline   Reply With Quote
