Head Gasket Replacement Denied - Diesel Forum - TheDieselStop.com
Old 12-09-2008, 12:56 PM   #1 (permalink)
601HP's Avatar
Folks,
I've been away from this site for a while, but I had an experience yesterday and am curious if others have experienced this issue.
In December 2007 my head gaskets were replaced under warranty. I provided head studs that were installed at that time.
Now in December 2008 and just 4,000 miles later, it seems I need head gaskets again.
Here's the glitch. The dealership is advising me that Ford has refused to replace the gaskets under warranty because HEAD STUDS were installed in December 2007, instead of factory Ford head BOLTS.
Have any of you been denied this type repair for this specific reason?
David
2004 F350 Lariat, CC, LWB, 4x4, Dually, 6.0L w/ TorqShift, 4.10 LS, Dark Charcoal Gray, Permatech sprayed liner, A-pillar pod with 3 Isspro gauges, windshield-mount gauge pod with 3 more Isspro gauges, AIC, Jason cap, and PIAA fog lamps, mounted as aux. back-up lights. Billet badges. Alpine radio, a bunch of JL Audio and Sirius stuff.
<font color="blue">Photos</font>
601HP is offline
Old 12-09-2008, 01:13 PM   #2 (permalink)
Tell them to prove, without a doubt and that would hold up in court, that the ARP studs caused headgasket failure. The headbolt design (stretching) is a known issue, hence the updated torque sequence and values in TSB# 08-11-03. There is a known issue with the cylinder head gaskets (TSB# 08-11-03. Do you tow or load it up? Mods? I can't see head gaskets failing with studs after 4,000 miles unless the truck wasnt diagnosed properly before or now. It's possible the cylidner head flatness wasn't checked correctly previously or that it's being diagnosed incorrectly right now.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline
Old 12-09-2008, 02:10 PM   #3 (permalink)
601HP's Avatar
The studs were installed.
I also wonder if there was a head tolerance issue not addressed during the gasket replacement last year.
I have towed a 5,000 pound load twice in the past 12 months. I can't remember planting my throttle foot to the floor, AT ALL, during the past 12 months.
My situation is still in the "evaluation" stage. I stopped by the dealership yesterday and described how my degas cap whistles annoyingly, but only while the engine is cold. As it warms to near operating temperature, the whistling stops. (I experienced this same thing prior to the head gaskets being replaced in 2007. When the gaskets were replaced, whistling stopped.)
Here's what I was told this morning by the dealership. Ford will have the dealership perform the following 4-steps evaluation.
a. Inspect the degas bottle cap to be operating at proper PSI. Warranty will replace if necessary!
b. Check for a leaking EGR cooler. Warranty will replace if necessary.
c. If the EGR cooler has not failed, then check the oil cooler for failure. If the oil cooler has failed, warranty will pay for replacement.
d. If a, b, and c are not the problem, then head gasket failure is likely. If the engine is torn down and the gasket/s are the problem, Ford will refuse to warrant the gasket replacement job account the head studs having been installed prior.
I find this to be another Ford side-step, as I'm fully aware of the factory bolt stretch issue, vs the known higher tensile strength properties of an ARP head stud.
My truck does not go into the shop for inspection and repair until Dec. 22nd. I'll post the results here.
David
601HP is offline
Old 12-09-2008, 03:20 PM   #4 (permalink)
OT
OT's Avatar
Be prepared for worse, but hope for the best. Maybe h.g. are ok/maybe not? You'll probably get replies/speculation etc. on your problems. Meantime, update later with facts. Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 12-09-2008, 08:00 PM   #5 (permalink)
Did they happen to send the heads out for machining the last time the h.g's were replaced?
2005 F250 - stock
2008 Yamaha R1 - stockish
2002 Audi A6 Quatro - 2.7 turbo
2010 Camaro SS (wifey's) - Hauls
Angrywasp is offline
Old 12-09-2008, 09:08 PM   #6 (permalink)
Justin C.'s Avatar
Angrywasp is on it. Most likely nothing can be done because ultimately it seems like Ford and the other brands do what they want when it comes to warranty. The only thing that may help is that the dealer messed up by not sending the heads out for machining (assuming that's what the problem is, and I'd about guarantee it is). According to the mechanics I've talked to, the heads are always warped, and if not planed, you will just blow the gaskets again regardless of whether or not studs are installed. Not sure if that will help with your dealer, but maybe worth a shot.
Justin
Justin
1997 F-250 Power Stroke
- 230k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, BDP live tuned
2005 F-350 Power Stroke (work truck) - 220k
ARP Studs, PHP 40 hp flash
Justin C. is offline
Old 12-10-2008, 12:55 AM   #7 (permalink)
dwc032's Avatar
When I had my head gaskets done a couple months ago, I asked the dealership if I bought the head studs would they put them in. They told me no and that it will void my waranty if they do. So, I hope all works out with your ordeal.
dwc032 is offline
Old 12-10-2008, 02:19 PM   #8 (permalink)
FMTRVT's Avatar
My Photos: (16)
Anytime you change any of the repair parts from the stock, Motorcraft supplied items you get into this area. Your asking the company to warranty something that was not under their control.
After saying that, the heads should have been machined flat. So I would check the repair order and history and make sure that was done. If not, then that is the most likely cause.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
Old 12-10-2008, 07:31 PM   #9 (permalink)
Lightningfast01's Avatar
My tech said I had to come back to him so he could work with Ford if I had gasket probs again. But the short story is Ford is not responsible once you asked for non OEM stuff. Ford is not playing these days, they deny anything they can and have zero leniency... I did studs because I expected to go over 100K and knew the stock bolts would fail again. I bet your heads were warped and they did not do a proper repair.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
Old 01-14-2009, 06:15 PM   #10 (permalink)
TxFireman1972's Avatar
Any update?
TxFireman1972 is offline
Old 01-14-2009, 06:24 PM   #11 (permalink)
Originally Posted by TxFireman1972 View Post
Any update?
removed remark
Luke_ is offline
Old 01-14-2009, 07:43 PM   #12 (permalink)
OT
OT's Avatar
Tx...601 says his ride goes in Dec.22. But cause this thread came up again..got me to thinking.
In my case (I didnt see) but tech. & shop foreman said water was spotted dripping on mine (between head/block) so no brainer on bad h.g. But...
Blown h.g. can cause coolant leak..(maybe oil?) but, certainly loss of compression would occur. Right/Wrong?
Q..If right..why isnt a compression test mentioned during diagnostics? Just curious. TIA
OT is offline
Old 01-14-2009, 07:48 PM   #13 (permalink)
head gaskets on 6.0s dont leak externally they leak compression into the cooling system under a very heavy load when the cylinder compression is high. what you see leaking between the block and head is probly just the egr cooler to oil coooler hose it just runs down the back.
compression test is out of the question it would have to be done wot full boost driving down the road.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 01-16-2009, 09:02 AM   #14 (permalink)
601HP's Avatar
I canceled the Dec. 22nd shop work for my truck. Several days before the scheduled visit I decided I had mis-diagnosed the problem. I hope that decision was the right one.
David
601HP is offline
Old 01-16-2009, 04:18 PM   #15 (permalink)
Eli
David
And.....
06 XL 250 6.0 Auto 4x4 Shortbox, Ex-Cab, 94k miles, SCT with Magnaflow cat-back. Studs, oil cooler, egr cooler at 93k.
95 XLT SC 4X4, 3.55, 5 spd, 290k miles, Bullydog extreme chip, Maddog Stage II injectors, Bullydog Propane, Tymar Intake, 4" exhaust, Walker BTM,H-Max DP, exhaust brake, LUK, 2.5 lift with 285's on 8 Weld Typhoons/air bags.
Eli is offline
