Head stud torque specs
Are the specs for the studs the same as the bolts? The paper with my studs say 3 even steps to 245 ftlbs. I assume 80 pounds each time...80, 160, 240? Any help is appreciated.
Also, I replaced the HPOP fitting with the new threaded style. Has anyone ever used the plastic jig that comes with the kit? The one I had was beveled on one side...making the fitting turned up a little. I did not use it, I just made sure it was level with the pump. Also, should I have used loctite on any bolts in the fitting or pump?
Another note, my 05 has 42K miles on it and the heads had to be surfaced to the tune of 8 thousandths. Is this normal? Thanks for the help.
2005 F250 XLT Super Duty Crew 4WD. White/Silver. K&N intake. Hypertech programmer. No muffler. Stock everything else. Other trucks: 1979 Kenworth W900A, 1982 Kenworth Cabover (BJ and the Bear) 1997, 1998, and 2000 Kenworth W900's. All Caterpillar Power. 1979A model just got marine application 2-piece pistons, nozzles, and ATAAC. Sure is sweet!!! 500 to the ground, and no smoke!
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
