Heater Problem??????????? - Diesel Forum - TheDieselStop.com
Old 01-25-2008, 10:52 AM   #1 (permalink)
Angry Heater Problem???????????
04 F350 6.0 110,000mi. bone stock
All right here are my issues, the heat will not work at low rpm's and it will only start blowing hot when the engine rpms are over 2,000. I have checked the coolant and that is fine. a few months ago I had to add over a gallon of coolant, I took it to the dealer and they said that everything checks out, 0ne day later it started billowing white smoke I took it back in and they replaced a egr hose and I have'nt had a problem since. Thermostat? head gaskets? please help
hunting247 is offline   Reply With Quote
Old 01-25-2008, 12:22 PM   #2 (permalink)
what does the temp gauge read,Possible thermostat issue or could even be a waterpump going out.But ususally you will get a overheat issue if its pump related.The clutch fan is Not stuck on is it?
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline   Reply With Quote
Old 01-25-2008, 12:36 PM   #3 (permalink)
Temp gauge (stock) is at the normal position and fan is not on. the outside temps have been about 0 degrees if that matters
Old 01-25-2008, 02:25 PM   #4 (permalink)
same problem
My wife just called me and reported the same problem. All gauges normal but no heat. Temp today was at -7. Anyone with any ideas?
03 Excursion 4WD w/ edge juice box. Wifes truck so all stock otherwise.
00 F-350 V-10 5sp
06 Yamaha Rhino SE
04 Yamaha Raptor
04 Yamaha YZ 125
04 Yamaha TTR 125
04 Haulmark 18ft cargo w/ air, heat, bunk beds.
Swarn2racing is offline   Reply With Quote
Old 01-26-2008, 05:38 AM   #5 (permalink)
Heater problem
Hey,Guys
If you truly have luke warm air blowing from your vents, and all fluids are at the correct range when the engine is cold and sat overnight.I would say the thermostat is stuck open meaning the engine block cant heat enough water/coolant to supply heat when the system is basically wide open
and full flowing. The thermostat is designed to not let full flow until an desired temp @195 give or take.
mike
06 f350 cc lb dually 6.0 4x4 6speed lariet. Straight piped,S&B cold air intake,timbrens.B&W hitch,rihno lined.
02 softail deuce
07 articat 700 le 4/4
06 silverback fth wheel 36 foot
DieselDoctor22 is offline   Reply With Quote
Old 01-26-2008, 09:19 PM   #6 (permalink)
overfly's Avatar
My Photos: (16)
Have the heater core flushed out at any radiator shop. Probably plugged up. You can check by feeling the heater hoses. Both should feel fairly warm at operating temperature. If one is noticeably cooler than the other that is your problem.
2006 F350 - Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline   Reply With Quote
Old 01-27-2008, 09:55 AM   #7 (permalink)
Teebird's Avatar
I believe these trucks have a valve that does not allow the coolant to flow to the heater core in the air conditioning mode. It is controlled by the little vacuum pump. I would check to see if your 4wd works as the hubs are controlled by the vacuum pump. I am not sure why it wouldn't work below a certain rpm but it could be that the little vacuum pump is going bad or has some leaks or a bad electrical connection.
2003 F250 XLT 4x4 Sport Crew Cab,
Built May '03, Bright Red, 6.0 Auto, ESOF 4x4, 3.73LS, 4.5" Edge Lift, 315/75-16 BFG KO A/T's, Polished/Clear Powder Coated Diff Covers, Weld Cheyenne 8 Wheels, Line X, Overhead DVD, Torza Tonneau Cover, 30' Fleetwood Gearbox Travel Trailer
Teebird is offline   Reply With Quote
Old 01-27-2008, 09:58 AM   #8 (permalink)
Excavator's Avatar
My Photos: (11)
yes trace the heater hoses from engine and see where the hot hose get cold and BINGO
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, BTS Trans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline   Reply With Quote
Old 01-30-2008, 06:55 PM   #9 (permalink)
hunting247,
I too had that exact same problem with my 03 6.0l. When the engine temp. was normal and the truck was brought down to an idle, it was just like the a/c was turned on. Only noticed this problem during the cooler weather.
Truck was constantly using a small amount of antifreeze and would never stay at the "new" fullmark. Also appeared that the engine temperature would reach "normal operating" range a little faster than normal.
I bought a digital thermometer and kept track of the temperature coming out of the vents in the cab. Temperature would drop by 40 deg F when the truck was at an idle and temperature out of heater vents didn't seem to correlate with engine temp?
Ford did some "cooling system" tests which they determined that the head gaskets were in fact leaking (cooling system would overpressurize under acceleration). Ford had changed out the EGR cooler a few months previously to try to resolve this issue also.
Now with new head gaskets, problem is solved, I have heat in the cab at an idle once more!!!
Hope this helps,
Selbeep
2003 F350 4x4 CC SB 6.0
Selbeep is offline   Reply With Quote
Old 02-12-2008, 10:32 AM   #10 (permalink)
Send a message via AIM to Larry202br
Originally Posted by Selbeep View Post
hunting247,
Hope this helps,
Selbeep
My truck is doing a similar thing. I noticed I was a little low on coolant, and I replaced about a 1/2 gal. I'm getting a little bit of puking, and a whistling noise under hard acceleration, and sudden throttle release. The heater started working again when I re-filled the coolant, but I'm concerned about the loss of coolant. do you know what the over pressure psi was?
2004 F-250 Lariat, srw, short bed, 4x4, Purchased in Feb. of 2006. 6.0, auto, 3.73.
Larry202br is offline   Reply With Quote
Similar Threads
Problem w/Automatic Heater/AC Control GunRunner 1999-2007 General Questions 2 01-02-2008 12:09 AM
Heater problem Ironhide 99 & up 7.3L Power Stroke Engine and Drivetrain 8 09-16-2007 05:57 PM
Block heater problem. DIESEL73 99 & up 7.3L Power Stroke Engine and Drivetrain 4 02-17-2007 08:44 PM
AC/Heater Blower Speed Problem yoodmdkd 1999-2007 General Questions 4 11-21-2006 06:21 PM
AC/Heater Blower Speed Problem Again yoodmdkd 1999-2007 General Questions 4 05-02-2006 04:12 PM
