Help with '04 Alternator replacement - Diesel Forum - TheDieselStop.com
Old 08-05-2009, 09:30 AM   #1 (permalink)
I have to replace the alternator on my 04 350. I need to know an easier way to get the belt off other than doing it the way that my Haynes manual suggest! Manual says to remove the radiator! Thanks racinpapa
racinpapa is offline
Old 08-05-2009, 06:39 PM   #2 (permalink)
Stand on RH side of vehicle (may need something to stand on), pull HARD on belt until tensioner has moved far enough to push the lock on the tensioner into place, release belt while holding lock in place until tensioner housing contacts lock, this will keep any tension from being applied to belt. Slip belt off alternator and replace, slide belt over pulling and tug on belt to release tensioner lock. Hope this makes sense....
djshum is offline
Old 08-05-2009, 09:01 PM   #3 (permalink)
Belt
Do it like DJSHUM said......
FK000@aol.com is offline
Old 08-06-2009, 12:11 PM   #4 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
I used a claw hammer to pull the belt from the alt housing then pushed in the lock. I then used the hammer across the fan shroud and engine to keep the belt on the pullies. First time took like 30 mins to figure out how to. Now it takes me longer to find the tools than to pull the alt.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
