HELP!!! Can't get CAC tube back on intake - Diesel Forum - TheDieselStop.com
Old 08-05-2009, 07:06 PM   #1 (permalink)
line3500's Avatar
I took off the EGR valve to clean it and also took off the CAC plastic pipe on the intake pipe and cleaned all that. Now I can't get the CAC pipe back on. It just won't go! Is there something special I need to do or some angle I need to push it in? I have tried until I almost have a hernia or pop a blood vessel and it will just not go. Any ideas?? thanks!
Alex Strand
2010 F350 6.4 DRW 4x4 FX4. Lariat ultimate package, homelink, 3.73 limited slip, line-x bedliner. white platinum metallic tri coat with 2 tone adobe and camel leather interior. Born on date: 09/2009 Delivered 5/27/10 with 43 miles
Currently 76K on the clock as of may 11'
Mods:
*Scan Gauge II
*CAT/DPF stock exhaust
*Recon cab, mirror, and fender lights
*High idle Mod
*20K Curt 5th wheel
*100 gallon aluminum flush mount fuel tank with direct fill into factory tank.
*Flush mount tool box
*Tinted windows
*Airlift bags on rear with compressor and 2.5 gal tank
Traded 2006 F350 SRW 6.0 Lariat, Loaded
*15K Reese 5th wheel
*110 gallon fuel tank w/ 18gpm pump
*high idle
*banks 4" dual monster exhaust.
*Ford OEM navigation 6CD audiophile radio.
*Dieselsite coolant filter.
American by birth, Teamster by the grace of God!
Teamsters local 399.
line3500 is offline
Old 08-05-2009, 07:54 PM   #2 (permalink)
line3500's Avatar
Come on guys surely someone has taken this pipe off before and put it back on. I need help, can't drive the truck without it. thanks again
Alex Strand
Mods:
*Scan Gauge II
*High idle Mod
*20K Curt 5th wheel
*Tinted windows
*high idle
line3500 is offline
Old 08-05-2009, 11:00 PM   #3 (permalink)
I've been there. Here's a little trick.....loosen clamp and slide down cac tube, there will/should be a metal ring around cac tube underneath clamp, slide it down tube out of way, use a micro torch or something similar to SLIGHTLY heat plastic where clamp tightens down, then push cac tube on.
djshum is offline
Old 08-06-2009, 12:16 AM   #4 (permalink)
Put the tube on the intake elbow as best as you can, put a pry bar against the tube using leverage from the left side engine lift bracket eyelet. Pops right on.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline
Old 08-06-2009, 01:36 PM   #5 (permalink)
line3500's Avatar
Thanks for the replies! I got up this morning and took the tube out of the truck and put the intake on the ground and took the tube and pushed down on it and it went right on. What a bit*h! I guess its that way to keep from coming off. Anyway it runs just fine now. And my EGR valve looks like new. :-)
Alex Strand
Mods:
*Scan Gauge II
*High idle Mod
*20K Curt 5th wheel
*Tinted windows
*high idle
line3500 is offline
Old 08-06-2009, 05:03 PM   #6 (permalink)
Banned
Glad you got it on.
For future referance... Less than an hour usually isn't enough to gather replies on a new post. We all have lives too and can't sit on the forums waiting for the second a new post comes up. Patience really pay's off. If you need imediate help without waiting a service rep at the stealership may help out. Not trying to be harsh but some things take time.
Banshee365 is offline
Old 08-06-2009, 09:01 PM   #7 (permalink)
line3500's Avatar
I hear what you are saying, but on the contrary I have seen quite a few posts where there were answers quite fast. Plus I made the most in the evening when people would be likely to be on checking email and forums etc.. Anyway I don't want to get into an argument or anything, I do notice there are lots of people on here that are quick to tell someone they are wrong or correct them. So I will take what you said under advisement. thanks.
Alex Strand
Mods:
*Scan Gauge II
*High idle Mod
*20K Curt 5th wheel
*Tinted windows
*high idle
line3500 is offline
