I have a 2003 6.0 Liter. The other day i got in it ann tried to start it up. The starter was dragging like the batterys were low. So i plugged it in and let it charge all day Saturday and Saturday night. I got in it Sunday and it was doing the same thing. So i took the batterys out and had them tested. They were perfect. So i took the starter off and had it tested, it was also perfect. I am at a loss for words here.. Can anyone help?
High Pressure Oil Pump (HPOP) problem. The injectors need oil pressure, without it, they won't fire and it won't start.
2005 F-350 LARIAT 6.0 PSD SRW AUTO FX4 (removed) CC SB White, International emblems, Tow Command, Upfitters, Line-X, ScanGauge, Pioneer Appradio, Banks Technicooler and intake w/Zoodad, Dieselsite coolant filter (w/RMI-25), braided 4x4 lines, Mag-Hytec trans pan & diff covers, Fumoto oil valve (Motorcraft 15W-40), Knurled HFCM drain plug, Britebox, EZ-Down tailgate, BedStep, MBRP 5" cat-back (6" tip), Putnam class V hitch with 1upUSA bike rack, TransferFlow 30 gal toolbox tank + 46 gal midship tank = 76 gals total with Stanadyne Performance additive and FPPF cetane improver... the rest is all stock you nig-nogs. 64k miles, 1600+ hours.
Waiting for "BigTurbo" to help me install: Dieselsite Trans filter kit.
Mine sounded like that.. But that could have been because they actually were dieing in my attempts to start it soo many times... Was the Low pressure Oil Regulator... mines an 05'... had to take it to dealer to get it fixed...
look at coolant level, egr cooler failing can cause water to get to cylinders and the starter will not have an easy go of it to turn over an engine with coolant in cylinders assuming the battery cables and other things already mentioned have been verified as good.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
I was thinking the injectors may have filled up a cylinder with diesel fuel that is why I mentioned checking the oil.
__________________ 2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Donaldson M085171 Muffler,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Transgo Equipped 4R100, Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer,
Timbren Overloads, Code L Front Springs,
Bilstein Shocks, BFG Commercial TA Rubber,
Hella 700FF Driving Lights
Well yesterday i changed the starter and it was still dragging so i called a as buddy over with his code reader. The computer was not throwing out any codes so i had him try to start it while i was watching the motor. Turns out the AC compressor was locked up and the belt is having to pull across a pully that is not moving. Which will not turn fast enough to ignite the engine.
