Re: Help with knocking noise
Looking for a little help here. During any driving condition, even when removing my foot from the brake at a stop, I'm hearing a knocking noise coming from behind the rear seat, on both sides of the truck. It sounds as though the noise is coming from between the box and the rear of the cab. When it's bad it is really loud and almost a constant knock, knock, knock.
Please tell me someone is experiencing the same thing? My dealer thinks I'm nuts
CoryG
That is a little vague alright. Can you give more specifics? i.e. when it does it, what speed, turning, level ground. I would check anything that is moving under those conditions, u-joints or drive shaft carrier bearing. One time my mothers car had this weird knock when I stopped and I could not figure it out. I drove around for about 30 minutes, checked differential and suspension and could not find anything wrong. Later I went to put something in the trunk and she had a bowling ball loose in the trunk [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]. That is a learning experience [img]/ubbthreads/images/graemlins/eek.gif[/img].
Good Luck
TasMan
2004/04 Engine,King Ranch,F-250,4x4,SWB,3.73 LS, Adjustable pedals,Reverse sensor,Moon roof,clearance lights, Power rear window,Heated seats,Bedliner, DPPI T-409 Turbo Back, AFE Pro-Guard7, C-Bet'r mirror, Fumoto drain valve, AIC, Extange Tonneu, Lund SS Interceptor, Siver Star Bulbs, Harpooned tank, SUV double wiring harness, Bright Box, Clifford RS 3.5 alarm, 3" Edge Plush Ride, Bilstein Shocks, Westin Sportsman CPS Grille Guard, XM Commander wired in with a PIE Adapter, Eagle 137 series rims and Bridgestone Revos 285/75-16, Husky Liner Mud Flaps.
http://community.webshots.com/user/tasman3721 UpDated 27 October 2005
Retired Chief Warrant Officer 4
