Help!! Leaking 6.0 - Diesel Forum - TheDieselStop.com
Old 11-17-2009, 10:11 AM   #1 (permalink)
Help!! Leaking 6.0
Hey guys, I have a 05 6.0 that has been leaking what seems to be a yellow liquid (coolent???) toward the back of the motor. Some days it will not leak at all, and some days like today it will leak a 7" puddle, the puddle will be under the starter it looks like it is leaking from above the starter on the block, but im not 100% sure. Can anybody help me!! THANKS
05DIESEL is offline
Old 11-17-2009, 10:45 AM   #2 (permalink)
69cj's Avatar
Sounds like the egr cooler hose. Orange hose in top engine valley just to the left of the oil filter. They like to leak on cool down for whatever reason. Probably contraction.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-17-2009, 11:01 AM   #3 (permalink)
Black05's Avatar
What 69CJ said.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
Old 11-17-2009, 11:13 AM   #4 (permalink)
Thanks guys I will take a look at it when I get home and let you know!!
05DIESEL is offline
Old 11-17-2009, 11:57 AM   #5 (permalink)
If it is that hose have you guys changed one before? Just wondering if it is hard? Do you guys think it could be a gasket? I wouldnt think so, do to the fact that the engine runs good and is not smokin or anything. Thanks again for all your help
05DIESEL is offline
Old 11-17-2009, 10:12 PM   #6 (permalink)
I looked at that hose and it looked ok, no leak. Think it could be a bad gasket? Even though the truck runs good. It was leaking a little when I got home from work, I got under the truck for a good while to see if I could pinpoint the leak with no luck, it just looks like it is coming out of some where above the starter on the block unless there is a hose or something on the back passenger side of the engine that could cause it to be leaking down the side. Thanks again for the help!! really want to figure it out so I dont have to bring it to the ford dealer!!!
2005 / 6.0 / Lariat / Crew Cab
High Idle Switch
05DIESEL is offline
Old 11-18-2009, 06:36 AM   #7 (permalink)
The hose 69cj is talking about is on the passenger side and buried - very hard to see. I sure don't know how you can do a visual on it and say it is OK.
Mark
bismic is offline
Old 11-18-2009, 11:40 AM   #8 (permalink)
Ok that works, I thought I had found that hose in the valley.. I will have to really get in there and find it if possible, is there any tricks to be able to get in there and see it? Again thanks for all the help!!! If that is the problem is it a big job to fix?
High Idle Switch
05DIESEL is offline
Old 11-18-2009, 12:36 PM   #9 (permalink)
Black05's Avatar
Check the intake area around the hose and you will likely find coolant there. The hose you are looking for is approxiamtely 3-4 inches long and should be orange (or blue) in color. I had the same leak and saw nothing leaking out of the hose visually, but the area around it was wet and dirty. HTH.
Texas Proud.
Black05 is offline
Old 11-18-2009, 01:39 PM   #10 (permalink)
Thanks Black05 I will look at it today when I get home! Was your leaking down the back of the engine on the passanger side too?
High Idle Switch
05DIESEL is offline
Old 11-18-2009, 02:37 PM   #11 (permalink)
Black05's Avatar
Yes, and dripping from the starter area.
Texas Proud.
Black05 is offline
Old 11-19-2009, 10:15 AM   #12 (permalink)
Well I looked at the area under the hose and it looks moist and dirty!! So I will be changing it out within the next couple days thanks!!!
High Idle Switch
05DIESEL is offline
Old 11-19-2009, 11:30 AM   #13 (permalink)
69cj's Avatar
Let us know how it goes.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 12-11-2009, 03:27 PM   #14 (permalink)
Well I just replaced the hose yesterday, and it stoped leaking thanks for all the help!
High Idle Switch
05DIESEL is offline
Old 12-11-2009, 03:31 PM   #15 (permalink)
O5diesel - Did you get the replacement at ford and if so what was the price and part number? Was it pretty straight forward? Mine just started with this current cold snap.
stroked5o is offline
