help with my hcfm removal - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 03-06-2013, 02:04 PM Thread Starter
I cannot figure for the life of me how to get the electrical clips off. I broke the snap on two of em already. The one to the rear came right off, the one at the drain broke and refuses to come off and the one on the pump, i tried to lift the tab, push down on the tab and pull and nothing worked so far. I do not want to snap the fuel pump pigtail. pics or a video would be helpful. i have searched and searched but i cannot find the video I had.
2003 F350 crew cab 4x4 , 295's on 17's, performance MFG coolant filer, Blue spring, new HFCM, FICM, Batteries and Alt. SCT performance tune, 128k on engine 12/13. Stock everything else.
ryhed is offline
post #2 of 11 (permalink) Old 03-06-2013, 03:35 PM Thread Starter
Well, I got the main harness unplugged but now when i remove the fuel rail from tank to pump it just runs and runs and runs. how do I stop it while changing my pump. I am parked facing down hill. i am not able to move it now. I ended up plugging the line loosely with a vac line plug shoved inside fuel line, but I can't get the last line off on the hcfm to tank return line. any tricks here? I've been hosing it with a straw and brake cleaner the soaking it in pb blaster then trying to prod out any dirt. At least I know my tank pickup line is free flowing.
ryhed is offline
post #3 of 11 (permalink) Old 03-07-2013, 05:12 PM Thread Starter
Ok I got it figured out. The top line is a push button release, no need for the fuel line removal tool.
1. Disconnect main fuel bowl harness forward the pump. With a little sweet talk she'll come right out.
2. Bring out your catch can and release the fuel lines. The front two use the fuel line separator, I believe the back two are push button, I know the top one is(hcfm to tank).
Plug tank to hcfm line, you may not have to but mine kept gravity feeding due to my parking downhill. I used a rubber vacuum plug and wedged it inside the fuel line.
3. unbolt the 3 frame rail bolts, push back your lines and wriggle it to the front of truck and slip it around the front drive shaft if you have one. I did rip the soft lining between the dive shaft and the pump a little, no big deal, fix with black gorilla tape.
ryhed is offline
post #4 of 11 (permalink) Old 03-07-2013, 05:33 PM Thread Starter
Upon disassembly of the fuel bowl.......
Found this turd in the filter bowl
Name:	2013-03-07 16.27.55.jpg
ID:	17585   Click image for larger version
Name:	2013-03-07 16.28.06.jpg
ryhed is offline
post #5 of 11 (permalink) Old 03-07-2013, 05:35 PM Thread Starter
Then I found my fuel heater in pieces and a bunch more turd in the drain compartment. I hope this helps the next guy out. It drove me nuts to only be able to work on it 30 minutes at a time due to my hands freezing. Oh and I got diesel soaked every time.
Name:	2013-03-07 16.31.27 (1).jpg
ID:	17601   Click image for larger version
Name:	2013-03-07 16.28.19.jpg
ryhed is offline
post #6 of 11 (permalink) Old 03-07-2013, 06:37 PM
Tough job, I hope you get it whipped. FWIW the current replacements do not have the fuel heater so don't sweat not getting that hooked back up.
Brian
MC5C is offline
post #7 of 11 (permalink) Old 03-07-2013, 09:32 PM
OT
OT's Avatar
Ry..curious, why did you pull hfcm? Surprised to see that much junk inside. Any idea how/why? Tks. for pic/info.
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #8 of 11 (permalink) Old 03-08-2013, 04:27 AM Thread Starter
truck was running with no power, no codes, did a fuel pressure test after it died in driveway after a filter change and found less than 10 psi. I'm hoping that's all it was.
ryhed is offline
post #9 of 11 (permalink) Old 03-08-2013, 12:26 PM
Be sure to do the Blue Spring upgrade to the fuel pressure regulator too.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #10 of 11 (permalink) Old 03-08-2013, 01:32 PM Thread Starter
Fixed it was the fuel pump.
Cross thread for the questions that came up.
hcfm removal help - Ford Truck Enthusiasts Forums
ryhed is offline
post #11 of 11 (permalink) Old 05-17-2015, 03:17 PM
check fuel pressure under a load --- and 2 fuel filters in tank (WATCH!)
https://www.youtube.com/watch?v=i3UKgw0iGKQ
Antisama is offline
