HELP - NEED COMPLETE NEW REAR END WITH LOCKER
Hi Guys (and Gals as well as I know you'll remind me you're here if I don't).
Anyway, I need a GOOD source/supplier for:
A COMPLETE REAR END ASSEMBLY UNIT
for 2003 F-350 with 6.0L
VIN: 1FTSX31P83EB58000
REAR END CASE NUMBER: 3C347A195BA
3.73 Gears, Sterling 10.5" was OEM
AXLES: 3C3Z4602AR
5C3Z4A376F
FULL CARRIER ASSEMBLY
- with ABS Wheel Sensors
- with FLANGE for Rear Pinion
I need all the above - with tubes welded in - ready to install the whole thing in my truck.
I need a "Custom Build" as I want a "Detroit Air Locker" in this new axle assembly with 3.73 Gears. You'll probably notice that I had/have an ARB Air Locker installed initially - but - there are/were some SERIOUS problems that came out of that unit (sheared, shattered in peices and nearly killed me and a few other drivers on the road that day).
Anyway - 'nuff said on that and we'll let that alone and move on.
I NEED a COMPLETE REAR END ASSEMBLY that is a DIRECT FIT for the Above unit with 3.73 gears. I obviously already have an air pump, am wired and ready to go there, but I won't install another ARB Unit.
I AM OPEN to another type of Locker Unit - but it must be HEAVY DUTY and either AIR or ELECTRIC operated/engaged (I want to keep an Open Diff Option for towing on icy/bad roads so as not to fishtail).
I need a REPUTABLE company that will stand behind their product and won't try to rip me off in the process - as of awhile back, I was permanently disabled and yes, it's service connected (yep, another Disabled Veteran on the books) and we all know that doesn't pay too well.
My truck is at a Dealership right now (personal friend of mine thank God) and he will have his guys just install the new rear end unit when it arrives, but I need to have it delivered "ready to install" and that's all.
I do need both rear axles as well as the tubes, carrier housing, etc - basically everything you see when you look between the tires except for the brakes, rotors, calipers and tires.
I AM in crunch mode as I need my truck back now and I've been without it for 6 months while it was being reviewed/investigated by the NHTSA - that's ALL I can say openly at this point, but take heed to my situation and think 2x before doing an install with a certain product.
Anyway, please HELP - I'm getting the run-around over the web as I can't find anyone that does this (provide a complete rear end already built with a "Locker" already installed).
I need to order by the end of this week (it can take 2 weeks to get here, but I need to order and pay for it soon to get a "bill" in hand to give to "someone" to show my losses as well as get my truck back on the road).
Anyone?
Also, it would be delivered to:
Norwich, CT
PM's are fine as well, but generally when I'm looking for something on here - someone else is as well and it helps to share info.
Thanks !!!
2003 Ford F-350 6.0L Superduty Supercab XLT 4x4
SCT X3 Power Flash Handheld Programmer
Custom Perfomance Tuning done by Eric
Phone: 410-620-3020; Toll-Free 1-866-642-7844
ARB AIR LOCKERs w/onboard Air Compressor
- Dana 60 Front & Sterling Full Floating Rear 10.5" w/3.73 gears
Front 3" Leveling Lift / Rear 2.5" add-a-leaf
TOYO Open Country Mud Terrains 315/75 R16
Amsoil Series 3000 Synthetic 5W-30 HDD
AMSOIL SuperDuty Oil Filter SDF88
AMSOIL PCF-60 PowerCore™ Technology Air Filter
